Signal Lights Not Working?
Signal Lights Are Not Working.
Moniqmoniue81
FORD EXCURSION
Interesting Article.. Just Keep Adding More Crap To...
Https://www.vehicleservicepros.com/industry-news/service-repair/news/53059354/car-thieves-now-use-the-vehicles-headlamp-ecu-to-bypass-...
Steve W.
No Power Going Uphill, Hissing Sound From Engine, And...
When Driving Up To A Summit The Vehicle Lost Power Going Uphill And A Hissing Sound Started From The Engine When Trying To Accelerate. The...
Kylie Jermain
Turn Signal Issues, Blinking Fast?
My Turn Signal Flasher Blinks Fast When Activated But My Fuse And Bulbs Are Fine. Looking Online I'm Seeing Mixed Things So Thought I...
frank0314
Clicking Sound When In Gear, Why?
When In Gear There's A Clinging Sound, Why?
Leobardo Mendoza
GMC CANYON
More Power, I Would Like To Change Transmission To A...
The Vehicle Listed Above Comes With A K20z5 It Has A Cvt In It Though, I Was Just Curious To See If I Could Mount The Old Manual...
Ben3303
2023
HONDA HRV
Starting Issues?
My Car Listed Above Is A Super Beetle Convertible That Didn't Crank Over. I Diagnosed And Replaced To Original Starter. The Starter...
RAR3
1979
VOLKSWAGEN BEETLE
Engine Vibration After Replacing The Fuel Pump With A...
The Vehicle Listed Above, Ecotec 2.4l. Background: I Successfully Replaced The Timing And Balance Shaft Chains, All The Sprockets...
amanaman1
Has Some Power But Dash Lights And Right Headlight Not...
We Drove The Truck Listed Above Lt Model To The Store And Came Out And Went To Start The Truck And Got No Dash Lights, No Crank, No Start...
mcqueensara1981
Freeze Plug
I Have A Water Leak And Found A Freeze Plug In A Little Valley Just Behind Or Under The Oil Cap. The Leak Appears To Come From The Other...
Jessica Anne Branch
NISSAN MAXIMA
Timing From The Aspect Completely Off?
Can't Tell If There's Timing Guides Or Not. There's Plenty Of Pictures Of The Side I Don't Need. So, It's Completely...
David Carkeek
Timing Chain Making Noise When Starting?
The Timing Chain Was Completed In January 2023. Slowly Over The Last Month-2 Months I’ve Started Hearing Rattling And Now It’s Getting...
Dez66
AUDI Q7
Codes C0290, C0205, C0298, And C0292, Steering Not...
The Steering Wheel Will Stop Taking Drivers Input And Turn Every Which Way By Itself. While Driving (at Both Highway And Slower Speeds) The...
BT161
CADILLAC ESCALADE
HVAC Blower Motor Not Working?
There Is No Air Coming Into The Cab Of The Car. We Turned It On, And It Didn’t Come On. We Checked The Switch, And It Was Good. The...
Dawn Trueblood
TCC Solenoid, Code P0741?
My Car Shakes Very Aggressively When Shifting Into Higher Gears And Sometimes Down Shifting, I Got A Code Read And The Code P0741 Came Up....
yugiflash5
SATURN SL2
The Engine Will Not Rev Past 3,000 RPMs?
Well, This Truck Has Sat For A Couple Years, I Have Been Fixing It Up. I Got It Running But Idle Comes And Goes And It Will Not Rev Past 3...
Colefincher
No Ground Signal At Pin 85 On Air Conditioning...
The Air Conditioning In This Truck Stopped Working At The End Of Last Summer. When I Switch On The Ac On The Truck It Only Blows Hot Air...
2500HD-Bman
Burping The System
The Temperature Gauge Was Jumping Back And Forth. The Check Engine Light, Water Temp Light, And Traction Control Light Came On. I Changed...
Brooklyn Hunt
Will Not Start, Oil Drip On Crankshaft?
Hello, I Will Explain As Best As I Can. Thank You In Advance For Your Time. Engine Light Came On, Showing Camshaft Code. The Guy At The...
Pauciello1031
While Driving There Was A Pop Noise, Smoke Was Coming...
Yesterday My Car Was Making A Grinding Noise And Slowed Down As If The Brake Was Being Applied Every Time I Drove. Today I Decided To Try To...
Ashton Oper
Code P0443, After Replacing Purge Valve Twice With New...
Hi, Code P0443. I've Replaced The Purge Valve Twice And I Still Get This Code. The Purge Valve Also Makes A Clicking Noise When It'...
Suspecctt27
Engine Codes 52 And 71?
I’ve Recently Purchased A 1995 Sc300 And Was Retrieving The Codes 52 And 71 From The Ecu. I’m Not Very Familiar With This Car Yet So I...
LR_sc300
21 IMAGES
LEXUS SC 300
Code 67, Check Engine Light On?
Scanner Code 67. Neutral/drive Switch Circuit Open. What Does This Mean And How Do We Correct So It Will Pass Smog?
Nathanb40
Suspension
When Driving At Lower Speeds I Hear Clanging Noises Like Metal To Metal When I Hit Bumps In The Road I Have Already Done Replaced My Sway...
Tom Jr Pettry
SCION XB
Car Starts At 2,000 RPMs And Then Drops With Warm Up...
After Cleaning The Throttle Body At Start It Has 2000-2200 Rpm, Which Decreases 3 Seconds To 1,500 And Then Gradually Decreases To The...
MaxVas
673
674
675
