Blinker Switch Replacement?
I Think My Blinker Switch Went Out I Ordered A New One But It's A Multipurpose One Meaning It Has A Cruise Control Switch On It. Now My...
Aj Frauenthal
PONTIAC SUNFIRE
Does Not Start And No Communication With The Computer...
I Have The Car Listed Above Ss Model, Which Will Not Start Or Communicate With The Computer Trow The Obd2 Port I Have Checked All Grounds...
Gentry12
Popping Sounds When Accelerating Or Braking And Going...
I Need To Know Why When Accelerating Or Braking And Going Slow And Take A Turn Usually Results In My Car Making Some Weird Popping Sound In...
Daniel Nelson2
CHEVROLET MONTE CARLO
Rattling/Roaring Noise Under Hood?
There Is A Loud Rattling And Roaring Noise Coming From Under The Hood When In Idle And Acceleration.
savrose99
NISSAN JUKE
Why Does It Not Go Past 2,000 RPMs?
When I Press On The Gas It Does Not Go Past 2,000 Rpms, And It Does Not Accelerate.
Kris1123
TOYOTA MATRIX
Torque Converter Stopped Working A New One Was...
The Torque Converter Went Out In It A Week Ago And A New One Was Put In. The New One Lasted 3 Days, So Now It's Being Replaced Again....
Abhemi
Car Stalls Then Crank No Start?
I Am Having A Few Problems With The Vehicle Listed Above, But The Main Ones Are Stalling And Cranking But Not Starting. They Are Both...
toomanycarproblems
GMC ENVOY
Intermittent No Crank?
Sporadically, My Truck Will Not Crank. There Doesn't Seem To Be Much Of A Pattern. If I Disconnect The Battery For A Few Minutes To A...
Neo4318
20 IMAGES
Diesel Engine Rattles For A Minute Then Goes Away?
The Engine In My Car Makes A Rattling Noise When I Accelerate, But Then It Goes Away After Maybe 30 Seconds. It Only Happens For A Short...
Papercut
VOLKSWAGEN PASSAT
Vehicle Will Not Accelerate When Transmission Is...
Vehicle Will Not Accelerate In Drive Or Reverse But Will Accelerate In Park And Neutral.
amariea112806
NISSAN MURANO
Just A Reminder :)
When A User Asks A Question On An Old Thread That Does Not Pertain To Their Make, Model, Or Issue Please Have Them Start A New Question...
Ken L
Codes P1793 And P1000?
Okay, The Car Is Showing A Couple Of Issues; The Battery Light Comes On A Few Minutes After Turning The Car On And Stays On While Driving...
jag2006
JAGUAR X-TYPE
Replaced Oxygen Sensor For Code P2096, Now There Is A...
In A Day The Car Suddenly Started Running Rough, Rpm Bouncing, At Idle 2 Times As It Stopped It Quit Running. The Code Reader Said P2096...
Smooey22
SUBARU OUTBACK
What Are The Engine Torque Settings?
Please Assist With All Engine Torque Settings For The Vehicle Listed Above B10s.
Conrad Van Schalkwyk
CHEVROLET SPARK
Stabil Trak, Anti-lock Brake And Service Engine Lights...
I Started The Car And Was Driving Across The Parking Lot, When The "service Stabil Trak" Light, Anti-lock Brake Light And Service Engine...
Rick Clowers
Turn Signal Switch Is Broken ?
I Have Indicator Stick For Mx5 Nc Mazda, But I Have A Mazda 6 Gy 2005 Model. Will The Part Fit In The Gy?
Keishamb
MAZDA 6
On A Rebuilt Head, How Do I Time The Camshafts Before...
How Do I Time The Camshafts Before Installation?
Welderdude58
48 IMAGES
Charging Problem?
I Am Only Getting 2.5 Volts From Battery Connection On Alternator To Positive On Battery. Alternator Bad? Ecu Or Maybe Fusible Link? Please...
Richarde
MITSUBISHI ECLIPSE
Why Does Engine Light Stay On
Check Ingine Light Comes On
Anna Rau
CHEVROLET CAPRICE
Oil On Spark Plugs?
I Had Put On About 8,000 Miles And I Got A Misfire In Cylinder 3. So, I Changed All The Spark Plugs And The Coil Pack For That Cylinder....
cball999
Shut Off While Driving, Engine Will Not Crank Or Start...
My Car Listed Above Was Driving Fine, Then Completely Stopped On The Road And Then Won't Start. Will Not Turn Over.
Shannonkane
PEUGEOT 306
AC/Heat Blower Motor Not Working?
Heater And A/c Started Out Working Only On Certain Settings Then It Quit Completely. Replaced Resistor, Blower Motor, Harnesses, And...
watsty2
CHEVROLET COLORADO
No Crank, No Start
Attempt To Start Car And While Key Is In Crank Position, Nothing Happens. No Crank, No Start, Dash Light Dont Dim. Has New Starter And...
Azn4yah
Wrapped 30-amp Circuit Breaker With Foil, Heard A Loud...
A Friend Wrapped 30 Amp Circuit Breaker With Foil, He Said It Didn't Fit In Tight Enough, It Started Okay, Heard A Loud Pop, And Now...
Cari tindell
No Crank, No Start?
Hello, Car Started With No Crank, No Start. On Start Dash Would Dim And Found Battery Low On Charge And Starter Seized. After Charging...
Azn4yah
20 IMAGES
665
666
667
