High Beam Headlight Are Not Working, DRL Module?
High Beam Headlights Not Working.
Jeremiah Harrison
Charging System, Battery Drains Overnight?
Charge Battery. The Car Starts And Runs Fine. Alternator Putting Out Over 14 Volts. Everything Seems Normal. Park The Car Overnight And The...
ropar47
KIA RIO
A/C Compressor Short Cycling?
The Car Has A Compressor That Is 5 Years Old, And Brand-new Condenser And All New Lines. The Evaporator Is Original. Pressures Are Normal...
cannon1349
Test
Test Question
hdgene
CHEVROLET CAPRICE
Need Pinout Wiring Diagrams For Bcm Connectors?
After The Installation Of A Gps With Starter Disable, Menu Control And Media Buttons On Steering Wheel No Longer Function. Steering Wheel...
Tinman_gz
Rough Idle At A Cold Startup And Sounds Like It Is...
The Vehicle Listed Above Is A Wagon. It Has A Very Rough Idle At A Cold Startup And Sounds Like It Is Misfiring Badly. After A Brief Minute...
elski
Headlights Not Working?
Only The Bright Lights Work On The Car, But All The Bulbs Were Replaced. Just Trying To See What Would Be Causing The Normal Lights Not To...
Doughboy561
KIA OPTIMA
Neutral Safety Switch?
I Need To Know What Letter Wires I Need To Cut And Connect Together On My Truck Listed Above C3500 Heavy Duty With A Nv4500 5 Speed. If You...
Cookiemonsta1025
CHEVROLET CHEYENNE
Possible Battery Or Alternator Issue?
Back Again With Another Potential Issue. This Morning I Woke Up To An Absolutely Dead Car While Yesterday It Was Driving Perfectly Fine. As...
Jgonzo2398
How To Check The Fuel Filter?
Trying To Find Out How To Check If Fuel Filter Needs Replacing Without Having To Drop The Whole Fuel Tank. All Signs Point To Fuel Filter Or...
Louise74
HOLDEN BARINA
2010 Sierra, GMC
Trying To Find The Engine Harness Diagram For My Ls Swap I Have 6.0l 6190 Gen Iv Ly6
Bill Williams2
Engine Will Not Idle After The Actuator, Throttle Body...
Car Won't Run Unless You Have Gad Pedal Depressed And Stay On It When You Let Off It Shuts Off. Then At Other Times It Will Start And...
Dicksonred2
LEXUS GS 300
Rough Idle And Shuts Off?
At First No Problems. After 10 Minutes It Will Run Fine Until You Slow Down Then It Wants To Stall Out But Not Every Time. But Also, Will...
Juggalo45
Right Rear Wheel Locks Up While Driving?
I Lucked Into A Retired 1984 Army K20 Pickup. There Are Some Things That It Needs That I Know About And Can Fix. One Problem Is Beyond Me...
marauder4
1984
Running Lights Won’t Turn Off
Just Started Happening My Running Lights Won’t Turn Off Unless I Unplug The Light Switch That Turns Them On And Off Even When Doing That...
Etxcalvin
Engine Cooling?
I Got The Water Pump Replaced (5/19) In My Truck After It Went Out Last Week At A Local Shop, And After Driving It Over The Weekend And On...
LB15
Transmission Valve Body Replacement Or Repair?
Good Afternoon, First Of All I Want To Thank You For Your Time. The First Symptoms I Have Experienced Were When Hitting Speed Over 60...
Mann551
INFINITI G35
Transmission Not Shifting Properly?
My Transmission Shifts Fine First Gear Second Gear Sometimes Third And Fourth When It's Cold, Then Every Once In A While, It'll...
Michael1966
High Idle RPMs And Exhaust Smoke?
Hello, My Mother Has Been Starting The Truck Once A Week To Keep The Battery Charged And Today It Started To Have A Higher Sounding Idle...
Matt Crouse
SUBARU SAMBAR
Codes P0018 And P0019, Engine Cranks But Will Not...
Just Replaced The Starter Was Running Fine Until The Starter Went Bad, Now It Just Cranks And Won't Start. I Have 2 Codes P0018 And...
Popmumbles
BUICK ENCLAVE
Locate Part# 88150-07030 On A 2021 Toyota Avalon
I’m Trying To Locate The Computer Assembly, Driving Support Unit (part# 88150-07030) On A 2021 Toyota Avalon. Can Anyone Help Me Locate...
deepnadig
TOYOTA AVALON
deepnadig
TOYOTA AVALON HYBRID
Locate The Part Number 88150-07030 On The 2021 Avalon
I’m Trying To Locate The Computer Assembly, Driving Support Unit (toyota Avalon Part #88150-07030). Can Anyone Help Me Locate It And...
deepnadig
Trouble Code 0420, Engine Runs Bad When The Service...
I Keep Getting This Code Coming Up When The Service Engine Soon Lights Up. Without The Code On, The Car Runs Well But When Light Comes In...
16dshantal
A/C Compressor Clutch Only Engages When Relay Is...
Hey There. I’m Looking For Some Guidance As I’ve Been Going At It With This A/c For A Year Now. Two Compressors, High Pressure Switch...
JustinfromCT
CADILLAC ESCALADE
642
643
644
