Brake Rotor Size?
So, For My Vehicle Listed Above Limited, I Ordered Some Rotors, And They Were Too Small (297mm) And I See They Also Have The 319mm And...
EmilianoG19
Codes
Why Didnt My 2004 Erexpidition Never Shot A Trouble Code For Bad Fuel Pump, But Did Shoot Out P0171, P2195, P2197, P0174
Lo Brownn
Intermittent Engine Cranking Issue?
So, About 2 Weeks Ago My Car Started To Have Problems Starting. It Sounded Just Like A Battery Dying. (The Drain Battery Light Didn't...
chrgray24
Rear Bumper, Some Kind Of Connector?
Car Was Hit In The Back While Parked, Some Kind Of Bracket With An Electrical Connector Was Hanging From The Rear Bumper On The Driver'...
justjames
MERCURY MARINER
10-amp A/ C Clutch Fuse Blows?
Hi Guys, A Little While Back Maybe 200 Miles Ago The A/c Started Blowing Warmish Air, Checked The Fuse Box And Found The A/c Clutch 10-amp...
imaflyingkiwi
CHEVROLET COLORADO
Lost Key And I Need To Move The Car, Is There A Way To...
I Have No Clue What I Have Done With The Key, Can I Start It Any Other Way? I Need To Move It Before It Gets Towed. Like Take The Switch...
willtt
Vehicle Vibrates And Makes Noise When The A/C Is...
Whenever We Turn On The A/c The Vehicle Starts Vibrating In The Front Engine And Makes A Loud Noise. The Radiator Fans Would Start To...
JennJim
After Hitting A Curb, Is It Possible To Change Out The...
Hello, I Have The Vehicle Listed Above S. I Hit A Curb, And The Passenger Lower Control Arm Is Bent, Causing The Sway Bar And Axle To Rub...
AshaA
30 IMAGES
2023
KIA RIO
Is There A Seal On Rear Of The Transmission?
I Am Almost Done With Putting The Transmission Back In But I Went To Add Some Fluid And It Only Took 1/2 Quart Before It Dripped. I Cannot...
JAGUAR XK8
Code U0100?
Hello, I Have The Car Listed Above That Will Not Start Sometimes And I'm Getting A Code U0100 Ecm Lost Communication. I Wanted To Know...
dougparks567
BUICK LA CROSSE
Lost Key
I Need To Move My Car Can't Find How Can I Start It Without A Lock Smith I'm Not Worried About The Car I Just Need To Get It Started...
willtt
Slid Into A Curb
Hi I Recently Slid Into A Curb And The Wheels Sticking Out Past The Fender On The Front Left Side Ive Changed The Wishbone And The Track Rod...
erin0799
VOLKSWAGEN GOLF
A/C Only Blows Out The Defrost And Floor Vents?
When I Turn The A/c On It Won't Blow Out Of The Dash Vents But Comes Out Of The Defrost And Floor. What Would Cause This? When It Was...
Paul Malaska
GMC SAVANA
Dashboard Lights Flashing After Replacing Starter?
A Few Weeks Ago, The Car Refused To Start. I Tried Jump Starting It For About An Hour Or So And It Started Up Eventually. The Car Was Just...
ps9964
ACURA MDX
Where Is The Oil Filter Located?
Where Is The Oil Filter Located On The Car Listed Above Ls?
Jester620
A/C Blowing Warm And Cold Air?
When Turn On The A/c Its Blow Warm Air About 10-15 Minutes And Then Cold Air Come On For 5, 10 Minutes It Gets Warm Again.
mmichael
Shuts Off For No Reason At All Sometimes Hard To Start...
I Can Be Driving Down The Highway Or Sitting At A Stoplight, The Truck Will Just Shut Off. Turn It Over Starts Sometimes It Won't Start...
Montecarlo6454
CHEVROLET AVALANCHE
The Engine Was Running Fine, Then It Backfired And...
Engine Running Fine Backfired And Shut Off. Now Spins But No Fire. Replaced Distributor. Still No Fire. Help Please.
Billy Johnson
NISSAN HARDBODY
Code P0420, Catalytic Converter?
I've Had To Get Both My Catalytic Converters Replaced 1-2 Times Each. Totaling 3 Replacements. I’m The 2nd Owner Of The Vehicle, The...
Libby McCallon
Changed The Distributor And Plugs And Wires All New...
Truck Was Running Fine Changed The Distributor And Plugs And Wires All New Now Won't Start.
Robby Thicksten
16 IMAGES
Drive Axle Replacement?
Hello! So, I'm Trying To Replace My Drive Axles On My Car, And After Watching Your Video And Ordering The Part Off Of Rock Auto. I...
zlilleodden
CHEVROLET VOLT
Leaking Coolant?
In The Video It's Leaking But I Don't Know If It's The Water Pump, Is It?
Polk
SUBARU SVX
Trying To Locate The Computer Assembly, Dri...
I’m Trying To Locate The Computer Assembly, Driving Support Unit (part# 88150-07030) On A 2021 Toyota Avalon Hybrid. Can...
deepnadig
TOYOTA AVALON HYBRID
Diagram Wire?
Help Me.
FY1221
LEXUS IS 250
Code P061c, Engine Does Not Idle?
Code P061c Just Had Throttle Body Installed, Because Poor Acceleration, Stalling Below 10 Mph. And Below 1 Rpm. Wrench Light Was On ...
sbrackens
641
642
643
