A/C Compressor Clutch Only Engages When Relay Is...
Hey There. I’m Looking For Some Guidance As I’ve Been Going At It With This A/c For A Year Now. Two Compressors, High Pressure Switch...
JustinfromCT
CADILLAC ESCALADE
What Are The Camshaft Cap Bolt Torque Specs?
Just Need The Cap Torque Specs For The Camshaft And Also Rocker Arms. Please
Mweaver76
HONDA CIVIC HYBRID
Steering Jerk To The Left When Braking?
Short Version: My Beast Jerks Hard To The Left While Braking. This Has Happened Twice. The First Time, I Skidded Into A Retaining Wall....
MomSlam
Can’t Shift Into Gears Below Neutral 2,4, R
Been Having An Issue Shifting Into The Gears Below Neutral For A Little Bit Now. But After Doing A Burnout In A Gravel Parking Lot, It Won...
Beaterbeater
MAZDA PROTEGE
Beaterbeater
MAZDA PROTEGE
Car Constantly In Limp Mode And Throttle Not...
I Have The Car Listed Above 300i And The Throttle Not Working And Car In Constant Limp Mode. I Have Changed The Following Parts Below As...
uzomakiy
BMW 330
What Does The 4th Code Mean?
Would Any Of These 3 Other Codes Cause Hesitation? Fuel Injection Regulator Helped But Still Getting A Hesitation On Dead Stop Acceleration...
BobbyB69
CHEVROLET VENTURE
Question 3
What Does The 3rd Code Mean? Thankx
BobbyB69
CHEVROLET VENTURE
Question 2
What Does The 2nd Code Mean? Thankx
BobbyB69
CHEVROLET VENTURE
Apparent Engine Management Issues?
Starts Easily And Has No Power To Back Up My Driveway. Idles Well Revs Smoothly But Has No Power.
Conecaster
KIA SPORTAGE
First, The Radio Quit, Then The Gear Shift Letters...
My Truck Listed Above Xlt Is Having Some Issues. First, The Radio Quit, Then The Gear Shift Letters Quit Showing Up, Then The Advance...
jns80864
Car Trembles When Under Power Especially While Turning...
Iv Replaced All 3 Motor Mounts. Driver Side Cv Axle And Wheel Bearing Assembly. The Front Tires R New But Back Are Old. Would The Rear Tires...
Robert Clark2
Engine Stalls Out After Starting, Brake And ABS Light...
When I Start My Car, The Engine Stalls Out, After Keeping The Revs Up For A Few Seconds And Letting It Settle Into Idle The Car Will Be...
RJ Stevens
CHEVROLET MONTE CARLO
Engine Coolant Hose Pops Off With Too Much Pressure?
Hello! About A Month And A Half Ago, I Hit A Pothole That Caused Me To Have To Replace The Front Strut Spring Assembly, And Now I'm...
jtwolf91
BUICK RENDEZVOUS
When I Put In The Key There Is No Power?
The Key Will Turn All The Way To Start But Will Not Turn All The Way Back As It Should. The Brake Pedal Is Up All The Way And Hard Cannot Be...
Barbara Hammond
GMC ENVOY
Smoke From Glove Box, Now Vents Do Not Work?
Had The A/c On Blast, Suddenly The Vent Stopped, And Smoke Came From The Glove Box, Car Runs Fine Otherwise. Here Are All Of The...
Linearlynn
Will Not Stay Running?
Car Drives And After About 10 Minutes It Shuts Off. It Starts Back Up With Little Surge, But You Have To Gas It. If You Let Off, It Shuts...
Evelyn Sanders
BUICK CENTURY
OBD Codes 14 And 34, Engine Turns Over Fine, But Not A...
Engine Turns Over Fine, But Not A Hint Of Firing. Obd Codes 14 And 34.
sdplasko
MERCURY GRAND MARQUIS
Engine Misfires At 3,000 RPMs?
When In Park My Engine Is Fine Until I Reach 3000 Rmp And Then It Starts To Stumble Like It Is Misfiring. What Could It Be?
Jim Donovan
Wheel Bearing Grease?
Had To Answer The Questions The Way I Did To Get To This Page; Wanted To Know What Wheel Bearing Grease You Guys Use And Get A...
mtrdudes
2024
CHEVROLET EXPRESS
Whine/high Rpm/weak Acceleration
The Whine Persists Unless I’m Already In 4 Th Gear High Speeds No Whine Only In Low Speeds 1st 2nd And 3rd
Sami1064
BMW 328
Alternator Not Charging?
Okay, So, My Car Does Not Hold A Charge For Some Reason. I Just Recently Replaced Both The Alternator And The Battery. Both Were Bad. The...
Jparis2001
Whining Noise And High Rpm / Weak Accelaration
So Everytime I Start In Morning Without Letting It Warm Up Gears Hold To Long When It’s Warmed Gears Hold Just Not As Long But Always Weak...
Sami1064
BMW 328
Transmission Swap/Interchange?
Can I Put A 2005 4 X2 Transmission In The 2007?
Jasson Jones
Code P0128, How Do I Fix It?
Okay, Y'all, Pray All Are Well. Saturday Morning Drove It To Parts Store And Back. All Good. She Takes It To The Store And The Dang...
BobbyB69
CHEVROLET VENTURE
643
644
645
