I would start with a full tune up, here is a guide to help:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Here are other possibilities for the problem:
Ignition system: The rough idle and misfiring could be caused by issues within the ignition system. Check the spark plugs, ignition coils, and ignition wires for wear, damage, or improper functioning. Replace any components that appear faulty.
Fuel system: A problem with the fuel system could also cause rough startup and misfiring. Check the fuel injectors for clogs or malfunctioning. Inspect the fuel filter for blockage. Consider performing a fuel system cleaning or using fuel additives to remove deposits.
Air intake system: Make sure the air intake system is clean and free from any obstructions. Inspect the air filter and clean or replace it if necessary. Check for any leaks or loose connections in the air intake system that could disrupt the air-fuel mixture.
Engine coolant temperature sensor: A faulty engine coolant temperature sensor can lead to incorrect fuel mixture during cold startup, resulting in a rough idle. Consider testing or replacing the coolant temperature sensor.
Idle air control valve (IACV): The IACV is responsible for controlling the engine idle speed. If it's malfunctioning or dirty, it could cause rough idle during startup. Clean or replace the IACV if needed.
Vacuum leaks: Examine all vacuum lines for leaks, cracks, or loose connections. Vacuum leaks can disrupt the air-fuel mixture and cause rough running conditions. Repair or replace any damaged vacuum lines.
Please go over this guide and get back to us.
SPONSORED LINKS
Thursday, May 25th, 2023 AT 9:00 AM
