Cranks, But No Start, No Spark?
I Checked For Spark With A Spark Test And There Is No Spark, But A Test Light Works. Replaced Crankshaft Sensor With An Oem Part. Getting...
sm2023
INFINITI QX60
Knocking Noise While Accelerating?
Hello, When I Accelerate From A Stop It Will Make A Knocking Noise From The Front (sometimes) And Also At Low Speeds. I Just Got A Tune...
Cj777
Changing Front Struts
Hello I Have Done Extensive Font End End Work. Or By The Time I'm Done I Will Have. I've Asked A Lot Of Questions And Always Gotten...
JC-842
How To Replace The Front Struts?
Hello, I Have Done Extensive Font End Work. Or By The Time I'm Done I Will Have. I've Asked A Lot Of Questions And Always Gotten...
JC-842
Starts And Runs For A Few Seconds?
The Truck Starts But Does Within A Few Seconds And The Fuel Gauge Doesn’t Move Off Of E But Has Fuel.
Jamess10
How To Disable Passkey-III (3) Anti-Theft System?
Has Anyone Found A Solution On How To Disable The Gm Passkey-iii (3) Anti-theft System, Which Uses A Transponder Inside The Head Of The...
TEXACA
BUICK RENDEZVOUS
Leaking Coolant Before Heater Core Hoses?
What Assy Do The Hoses Connect To?
keith.snyder1
CHRYSLER CIRRUS
Transmission Will Not Shift Passed Third Gear?
So, My Vehicle Has Been Giving Me Some Transmission Issues. In Order To Get The Vehicle To Move, I Have To Shift It Into 1st And Then Work...
Toph520
ISUZU TROOPER
The Serpentine Belt Came Off While Driving, After...
I Put The Old Belt Back On And Noticed The Belt Was Riding Off The Side Of The Belt Tensioner Pulley A Bit. So, I Replaced It With A New...
Jhenson1
BUICK CENTURY
Turn Signal Light Not Working Properly?
I Have The Truck Listed Above With A Led Strip Will Dynamic Turn Signal. When I Hook Up The Wiring To The Turn Signal It Doesn’t Work. The...
Austinani15
TOYOTA TACOMA
While Driving My Car All Lights And Windows And...
All Lights And Windows And Dashboard Shut Off While Driving.
Vr6$$
VOLKSWAGEN GOLF
Oil Leaking Into Cold Air Intake?
I Have The Vehicle Listed Above Xl Denali. The Short Version Of The Problem Is I Have Oil Coming From The Passenger Side Valve Cover "...
Bboylilrob
22 IMAGES
Manual Transmission To Automatic Transmission...
I'm Trying To Convert My Transmission To An Automatic. I Have A Whole Donor Vibe That's A 04 Fwd. The Whole Wiring Harness/system Is...
RJCZPCABCLPC
PONTIAC VIBE
Not Getting Fuel To The Fuel Rail?
I'm Not Getting Fuel To My Fuel Rail And My Pump Isn't Turning On. The Code Is Fuel System Circuit. I Pulled Out The Pump And Tested...
robert6121975
Will Not Start Is It The Fuel Pump Or Regulator?
My Car Ran Out Of Fuel. The Person Driving Burn Up The Stater, Replaced, New Battery. Car Will Not Start. I Need To Know If It Is The...
Mxt
MERCURY MILAN
Radiator Fan You Could Hear The Fan On For About One...
I Have A 1986 Buick Grand National. I Had To Have A New Radiator Put In. Before When The Car Was Shut Off You Could Hear The Fan On For...
Mary Lengyel
BUICK REGAL
Will Not Idle After Starting The Engine?
The Vehicle Listed Above Is An Lt. It Will Start, Run For A Couple Seconds And Then Shuts Off.
Garrett Vaska
After Replacing The Clock Spring This Morning There...
I Replaced The Clock Spring This Morning With The Same Identical Part Number And Now Additional Error Codes Are On The Screen But Not On My...
Stephen Dailey
VOLKSWAGEN TIGUAN
Shut Off While Driving, The Engine Cranks But Does Not...
I Drove 5 Miles On A Very Rough Compacted Bumpy Gravel Road That Rattled The Organs Inside My Body Enough To Make Me Feel Like It Was Doing...
Evette Whitmyer
TOYOTA T100
Steering Angle Sensor Internal Circuit?
Hello, Good Evening, The Vehicle Display Light On The Dashboard, When The Scanner Was Connected It Display "steering Angle Sensor...
Blessing Ewobor
TOYOTA SIENNA
Transfer Case Wiring Diagram Needed?
I Recently Replaced My Transmission And Transfer Case And I'm Having Problems Figuring Out Where All The Wire Connectors Go On My...
Kevin Young2
Transmission Will Not Shift Into Third Gear?
Car Won't Go Into 3rd Gear. Start Off In 2nd Gear Then As Rpms Rise Move Gear Shift To D To Skip 3rd Gear Or Car Will Go In N And I...
Jaylynne321
HONDA CRV
Stalls Out Backfiring, Will Not Start Back Until It...
Stalls Out While Driving, When It Stalls It Loses All Pedal And Is Backfiring Something Awful Too Once It Completely Dies It Takes Forever...
Kayleigh Perry
Burned Wires Under Steering Wheel?
Hello, I Recently Replaced The Clutch, Oil Filter, Battery And Ignition Switch To The Car. Yesterday, Once I Got Back Home The Car...
dgfortugno
AUDI A3
The A/C Vents Are Not Blowing Out Air?
When You Turn It On The Only Air That Comes Out Is From The Defrost Vents And The Only Speed Of Air That Works Is 5 But It's Barely...
Berndj16
619
620
621
