How Do I Release The Tab Holding The Fuel Vapor...
How Do I Release The Tab Holding The Fuel Vapor Canister In Place Under The Vehicle?
jbs49120
BUICK REGAL
Desperately Needing Help.
I'm At A Dead End For The Problem With My Nissan Altima. I Have Changed The Starter, The Alternator, , Changed All The Sensors (more...
LouPolanco
Passenger Door Speaker Short?
For Some Reason, The Passenger Door Speaker Seems To Have A Short. It Has Very Little Power, But Sometimes It Will Be Working Fine Until I...
Tmreger2022
HYUNDAI ELANTRA
Turns Over But Will Not Start?
Replaced Fuel Pump After It Quit Running And Sat For A Year, Was Told Pump Was Bad. My Brother-in-law Replaced The Pump 2 Years Ago And The...
Tinyscott2
Dashboard Warning Lights Stay On When You Put Car In...
Dashboard Warning Lights Stays On When You Put Car In Gear.
Slingbd
Free Training
Https://www.wtitraining.com/classes/online/lunchtime Take A Look At The Classes They Are Holding, Might See Something Interesting.
Steve W.
Aftermarket Remote Start Compatibility?
I Was Wondering If A Ultra Start U1172xr Pro Is Compatible With My Vehicle And If So, Could I Possibly Get A Wiring Diagram And Do I Need A...
Dollabill25
HUMMER H2
Touch Screen Freezing And Restarting?
The Touch Screen Turns On Then Restarts About 20 Seconds Later. The Touch Screen Works For About 2 Seconds Then Freezes. Then It Will...
Smlegend4
Rear Differential Thumping When Turning From A Stop At...
So I've Got The Problem Isolated To The Rear Differential. Unplugged The Connector To The Rear Differential Solenoid, Noise Gone....
Dbogy
Crank Shaft Position Sensor, How To Test For Power?
Either I Am Not Getting Power To The Sensor, Or I Need Help Testing The Power To It. It Reads.345 Volts.
Eric1build
MAZDA 6
Rattle Or Thumping Noise From Rear Differential When...
I Know It Is From The Rear Diff Based On A Previous Post Where You Helped Someone By Having Them Unplug Rear Diff Solenoid To Isolate. So...
Dbogy
Anyone Have Any Ideas On This One?
Customer Has 2008 Gmc Yukon Xl 6.2l Denali That He Just Did Rocker Arms, Pushrods And Lifters. All Oem Parts. Now He Is Getting Oil In The...
Brendon S
Overheating After Replacing The Thermostat?
I Had The Thermostat Replaced On It, The Cooling System Bled Out, And Oil Changed On It. It Still Overheats Going On The Interstate. I Don...
MaJalesya
MERCURY GRAND MARQUIS
High Pressure Fuel Pump?
Leaking Gas, Replaced The Fuel Pressure Sensor, Fuel Pressure Regulator. It Now Leaks Gas. From The Picture Right Beside The Fuel...
Michael Delaney
VOLKSWAGEN PASSAT
Intermittent Starts, Transmission Not Shifting?
Sometimes The Car Will Not Start I Get No Power At Ignition. Horn, Cigarette Lighter, And Headlights Will Work. No Dash Lights No Power...
rudygia
When Starting The Car, The Start Grinds?
Whenever I Start The Car, The Starter Grinds, My Dad Thought It Was Just The Starter And Just Replacing The Starter. I Learned That It...
Sanchez555
Call Starter Grains While In Park Or Neutral
2009 Hyundai Sonata 210000mlie. Whenever I Start The Car The Starter Will Is Grind My Dad Thought It Was Just The Starter An Just Replacing...
Sanchez555
Where Is The A/C Drain Located?
Dears, Do You Have A Diagram Where Is The Location Of A/c Drain Hole Under The Car? Thanks In Advance.
wish30
FORD COUGAR
Clutch Safety Switch?
I Go To Start The Car I Push The Clutch In, And It's Still Acts Like The Clutch Is Not Pushed In To Start It All The Power Comes In On...
Wildboy53
PONTIAC SUNBIRD
When Making Tighter Turns It Feels Like The Back...
I'm Not Honestly Too Sure On The Year Or Mileage, It’s Not My Truck. When I Make A Turn Into A Parking Lot Or Spot It Feels Like My...
browningdev
Truck Shuts Off At Idle?
So, My Truck Runs Fine When I’m Driving But When I’m Coming To A Stop Or Already Stopped It Will Just Shut Off. The Dash Lights Will...
dftba.16
Brake, Battery And Master Warning Lights Staying On...
Okay, So, After My Car Setting Not Started And Not Driven For A Little Over A Year Now Due To A Cv Axle Issue That's Now Fixed. I Had...
Misswimms77
NISSAN MURANO
Car Lurches Forward When Shifting The Transmission...
Motor Revs Okay When In Neutral, But When I Shift The Transmission Into Drive, The Car Lurches Forward Harshly And Stalls. Mechanics Don...
paulmason
ALFA ROMEO MITO
How To Replace The Sensors On Transfer Case?
I Know There Is A Vehicle Speed Sensor And Shaft Output And Input Speed Sensor For The Other 2. My Question Is, Are The Output And Input...
Hd1200
Engine Will Not Turn Over Located A Bad Starter Fuse...
Every Time A New Fuse Is Installed It Blows Immediately. Please Help. Recently Purchased This Car From A Guy Who Said The Car Wasn't...
Jr Payne
618
619
620
