Diagram Of The Fuel Sender Unit In The Reservoir...
I Would Like To Have A Diagram Of The Fuel Sender Unit In The Reservoir, How The Fuel Pipes That Need To Be Connected. Fuel Does Not Reach...
Andrin Atem
TOYOTA LANDCRUISER
Reverse Shift Clunking?
Followed Your Instructions And Replaced The Tcu. Seems Better, But Still Clunks Going Into Reverse. Also, The Speedometer Doesn't Work.
Miriam Brown
HYUNDAI SANTA FE
After Hitting The Brakes Hard, The Dashboard Lit Up...
I Was Missing A Left Turn, Nobody Was Behind Me And I Hit The Brakes A Little Hard To Make The Turn. Dashboard Lit Up. Abs, Skid Control...
pbuonomo
TOYOTA HIGHLANDER HYBRID
Specs For Factory ~4" Infinity/JBL Mid Dash Speaker?
The ~4" Mid Dash Speaker Is Making A Noise Akin To When The Insulation Of Or The Foam Has A Loss Of Integrity And Will Replace It. I...
The D of W
KIA SORENTO
Brakes Clunk, Could It Be A Design Flaw?
I Have A Moderately Loud Clunking Noise From Underneath (i Think) My Vehicle When Maneuvering At Slow Speeds In And Out Of Parking Spots...
bobnjan
NISSAN ROGUE
When My Vehicle Gets Hot It Loses Power Timing Retards...
I Get Cam Sensor Malfunction. Just Replace Cam Sensor For Same Fault Code. Drive 10 Miles With A/c On Makes It Worse. Installed Correct...
Jeffrey Wolff Sr.
KIA OPTIMA
Theoretical Possibility Of Transponder Chip Cloning?
Dears, I Would Like Ask You A Question About The Theoretical Possibility Of Key Cloning. As I Have Read On The Internet About Making An...
wish30
FORD COUGAR
Possible Transponder Error (cranking But No Spark)?
Dears, I Had This Problem About Two Years Ago, It Happened Twice In Couple Of Months, So Now I Thought It Is The Right Place To Ask For...
wish30
FORD COUGAR
Other Causes For Powertrain Control Module 2 Mil...
This Is The Second Time I've Had The Vehicle Replace Rear Sensor In The Back Fine For 8 Months Now I Have That Fault Code And Is Not...
rokstarr311
Right Front Parking Light Will Not Turn Off Even With...
I Have Replaced The Relay And Fuse And The Light Still Will Not Turn Off. I Have Taken The Bulb Out, So I Don't Drain The Battery.
toddnoggle
2014 Police Interceptor Back Window Won’t Go Down...
The Rear Windows On Both Passenger And Driver Side Work From The Back Switches. I Can Roll Up The Back Windows From The Driver Side Main...
Rachel Lewis
No Power To The Instrument Cluster?
The Other Day I Was Going Through A Drive-through And I Turned My Car Off So I Could Hear The Radio At The Window. When I Stuck The Key Back...
Tmag89
BMW 328XI
Where Is The Camshaft Position Sensor B Circuit Bank 2...
Need To Know Location Of Camshaft Position Sensor B Circuit Bank 2.
Bark613
FORD F-350
Car Will Not Start?
Battery Is Good. It Doesn’t Do Anything When I Turn The Key. No Clicking Or Any Attempt To Start.
Dusty Malloy
DODGE STRATUS
Diagram Or Schematic That Shows Where Each Wire Goes...
My Fuse Box Underneath The Dash Is Only Partly Working. It Seems There Is No Power To The Fuses In The Middle Of Box. The Outside Fuses Work...
Vanmang20
CHEVROLET VAN
A/C Blower Motor Resister Replacement?
Hello, I Have The Vehicle Listed Above Se. I Live In Az Where It Gets To Be 120 Degrees Hot And I Had My A/c Go Out, All At Once With A...
baergrub
DODGE AVENGER
Engine Fault Service Now?
I Have The Vehicle Listed Above S, That I Installed A New Battery In January. The Owners Manual Mentions The Battery Monitor System But...
Sarahportiz
Turn Signals Blowing Fuses?
Car Keeps Blowing Fuses, Have Replaced Everything On This Car Associated With The Issue (relay, Fuses, Switch, Wires, Etc, ). Mechanic...
aguynn
Stalls
Truck Stalls When Idling And When Driving But Not All The Time. Have Replaced Spark Plugs And Wires Throttle Body Position Sensor And Air...
Susan Harmon
FORD EXPLORER SPORT TRAC
Starter /
Went I Turn The Key All The While Nothing Happen. It Won, T Start At All
dennismarques
How Many Valve Cover Gaskets Does My Car, And How...
Was Told That My Car Needs Valve Cover Replacement. It Was Supposedly Replaced In 2018 And Then Again In 2020. Do They Need Replacing That...
Sandidee
LEXUS IS 250
Power Steering?
So, I Have Had This Car Since The Beginning Of 2020. And Whenever It Started Getting Cold That Same Year By All The Sudden One Day, Had My...
JNicole
Clicking Noise When I Start The Engine That Stops In A...
Hvac Rear Actuator?
charrell5
LINCOLN NAVIGATOR
Cat Temperature?
Truck Running With Small Miss. I Checked Cat Temperature Upstream Bank 1 256 Degrees Downstream 420 Degrees Bank 2 Upstream 242 Degrees...
Donnie H
Code P0128, Possibly Related To Over Filling Freon, Or...
The A/c Was Blowing Hot. Condenser Pulley Engaged. Added 32oz Can Of Freon To Low Side. The Needle On Gauge Was Dropping As I Was Adding It...
Norinradd88
610
611
612
