Hardwire Dashcam, New Radio With Backup Camera...
Hi, I Just Had Another Hit And Run While My Car Was Parked. The First Time In My Corolla Last July Was 7 Days After A Not At Fault Accident...
Talonluvswifi
Hot Air
Just Filled Freon Possibly Beyond Capacity @ 77, Blowing Freon Out Sporadically, Lowered Freon To 55 To See If The Pressure Is Less Freon...
Terra1
Wheel Arch?
I Just Bought This Car As A Cheap Run Around Been Fine Until Today When Noticed A Scraping Noise When Turning To The Right, Looked And...
Ryo438
VAUXHALL ASTRA
Does Not Stay Running?
Sometimes It Starts Then Cuts Off In Between 10 To 20 Minutes.
Jerry tomokins
CHEVROLET VAN
Code C0306, Transfer Case Shift Issues?
I Have A 2003 1500 Hd. I Had A C0306 Code But The Service 4wd Light Only Came On When Driving In The Rain. I Was Preparing To Drive On The...
Wayne Shannon
Body Control Modular?
Trouble Starting Windows Going Down On Its Own, No Sound On Stereo, Horn Blows On Its Own, Check Engine Light On And Service Brake System...
Crystalalford87
Anti Theft Systems
I Had To Replace The Key So I Purchased A New Key Cylinder And Key From The Gm Dealership. The Car Doesn’t Start, Just Reads Disabled...
maren.kh
A/C Not Working Properly?
My A/c Blows Cold On The A/c Function But Does Not Work On Any Other Function Such As Max Or Defrost Etc. When I Come To A Stop Or Slow...
Hannah2023!
CHEVROLET BLAZER
Car Bucks Really Hard/jerks/hesitates?
While I'm Driving My Car, Randomly The Car Will Do A Major Jerk Or Hesitation And Lose A Lot Of Power In The Moment. It Does Not Do It...
Jordan Christopher Brock
KIA SPECTRA
Left Turn Signal Flashes Rapidly, Front And Rear Bulbs...
Today (7-1-23) I Noticed When Using The Left Turn Signal The Lights Flash Fast (all Lights Appear To Work), The Right Is Still Typical. I...
tech2020
Transmission Not Pulling?
After Finding That The Transmission Cooler Was Leaking Into Radiator And Fluids Had Mixed, I Replaced Radiator, Drained Trans Fluid And...
spjordan2
CADILLAC CTS
Abs/traction Light Will Not Reset?
Changed Hub And Sensor, Wiring Under Scuttle Panel Was Damaged (repaired Now) Live Data On Diagnostic Machine Shows Speed For All Four...
Sugg5y
VAUXHALL CORSA
Do You Have To Gravity Bleed Brakes?
Do You Have To Gravity Bleed Brakes After Compressing Caliper Back Or Is Okay Not To?
Chris Kirby2
TOYOTA SIENNA
Overfilled Oil, White Smoke
I Accidentally Overfilled My Oil. I Drained A Bunch Of It And Got It Back To The Appropriate Levels But It's Still Blowing White Smoke...
felilla
Overfilled Oil, White Smoke?
felilla
Seven Fuel Issues??
Vehicle Can Only Creep A Few Feet In 4wd High Before Stalling And Crapping Out. Will Probably Only Move A Few Inches In 2wd Before Stalling...
john87cj7jax
1984
JEEP CJ7
Starting Disable Due To Antitheft Deterrent
We Purchased A Lock Cylinder With A New Key From The Gm Dealership. We Do Not Have The Old Keys. We Have Done The Relearn Procedure Several...
maren.kh
How Do I Remove The Engine Oil Pan To Replace The...
How Do I Remove The Engine Oil Pan To Replace The Gasket?
Robert Gonzalez
1979
I Get In The Car To Leave The Battery Is Always...
I Have Replaced The Starter And Have A New Battery. Still When I Get In The Car To Leave The Battery Is Always Drained. When Trying To Jump...
Carolyn Reinschmiedt
CADILLAC DEVILLE
After Replacing The Transmission Filter And Fluid The...
I Replaced The Transmission Filter And Fluid On My Wife's Car. Got It All Back Together, Filled It With Fluid And The Car Won't...
Rebeljrw
NISSAN MURANO
How Many O2 Sensors Does My Vehicle Have And Where Are...
O2 Sensors.
Sam Musselman
FORD F-450
Hesitation When Driving?
The Car Is Not Misfiring But There Is Hesitation When Driving. The Shop Said It Was Coming From The Engine But Needed A Lot More Time To Dig...
SUBARU OUTBACK
Engine Coolant Temperature Sensor Location
Looking For The Location Of The Engine Coolant Temp Sensor On A 2017 Malibu 1.5l
dvdorr2
Coil Fuses Keep Blowing As Soon As I Crank The Engine?
Even Coil Fuses Keeps Blowing As Soon As I Crank It.
Julian1
BUICK ENCLAVE
Where Is The Igniter Located?
Where Is The Igniter Located On The Pre-runner I Cannot Find It, Does It Have One? I Am Burning #3 Coil Out Put New One In Burns That One...
Kevin Roy2
TOYOTA TACOMA
589
590
591
