The Key Got Locked In The Ignition Switch?
We Were Able To Remove It. Got A New Ignition And Key. Put It On. We Noticed The Dash Does Not Light Up At All With The New Ignition And Key...
Dwight m
How Do I Identify What Number Valve My Engine Is?
I Want To Ask How Do I Identify What Number Valve My Engine Is? Vin 1ftnx21l74ea98698.
phipster39
My Engine Would Run Hot While Idling?
I Only Had 2 Relays In My Vehicle. My Engine Would Run Hot While Idling. So I Put A Relay In The 3rd Place Which Was Empty But Was Labeled...
Helpme87
GMC ACADIA
Head Lights Not Working?
Both My Headlights Don't Work. The High Beams. Could It Be A Fuse If Both Are Out At The Same Time?
Julie Gomez
HYUNDAI VELOSTER
ABS Block?
Hi, I Replaced The Abs System With A Used Unit Due To Costs Etc. After A Couple Weeks I Noticed My Brake Fluid Reservoir Level Going...
pbuonomo
TOYOTA HIGHLANDER HYBRID
After It Was Turned Off It Did Not Start Again?
My Vehicle Started To Act Up On The Way Home (loss Of Spark Or Fuel). I Made It Home, But Then The Truck Would Not Start. I Towed It To The...
2001 Explorer
I Lost The Key To My Truck And Drilled Out The...
Well, The Ring With The Wire On It Was Damaged And A Wire To The Box Below Was Knocked Loose, What Should I Do?
Chrismayes
Misfiring/Backfiring/Poor Acceleration?
When Starting It, I Have To Wait A Few Seconds, Or It Won't Start. When Initially Accelerating, It Is Sputtering And Backfiring, As...
Bmg731
MAZDA MPV
Brake Lights Stay Dimly Lit While Car Running?
The Brake Lights Stay Dimly Lit While The Car Is Running. The Cruise Control Is Also Not Working. When The Brake Is Pressed They Light Up...
slowhand454
FORD CROWN VICTORIA
No Response At Starter?
Can Not Get The Starter To Respond. When You Activate The Start Button While Holding The Brake, Error Displays On Dash Engine Fault...
Jackwrn
Brake Lights Stay On Dimly When Car Running
My Brake Lights On My 03 Crown Vic Base Model Stay On Dimly While The Car Is Running. While The Headlights Are Off, The Taillight Brake...
slowhand454
FORD CROWN VICTORIA
All Power Windows Do Not Work?
No Sound, No Response. Everything Else Electrical Is Fine. Dealer (dodge) Says I Need To Replace The Junction Fuse Block Relay At A Cost Of...
durangododge
16 IMAGES
DODGE DURANGO
Power Windows Stopped Working
All Power Windows Stopped Working. No Sound, No Response. Dealer Says I Need Junction Fuse Box Relay Replaced $1039.
durangododge
DODGE DURANGO
C1268 ABS Motor Relay #1 Circuit Failure
I Have A C1268 Abs Code Scan With Diagnosis Motor Relay #1 Circuit Failure. Center Dif And Battery Lights. Doesn’t Drive Right - Steering...
TxRancher
LEXUS LX 570
How To Remove The Second Row Seat To Access The Fuel...
I Have To Replace The Fuel Pump And It's Under The Second Row (rear In My Car) Seat. I've Searched Everywhere But Can't Find The...
rlgriffinx
KIA SORENTO
Engine Fan Not Turning On Until 226°F, Sometimes It...
Hello, I Own The Car Listed Above R/t. My Car Has Been Recently Overheating To 226°f Then I Hear The Engine Fan Kick On. Sometimes It...
Eddie.rock
Car Running Hot, Overheating?
Yeah, My Car Is Overheating. I Took The Radiator Out Flush It Out Snow Regularly Nowhere The Heaters Not Getting Hot Do You Think It's...
anthony0910
NISSAN MAXIMA
No Key Detected After Bad Accident With Shift Knob?
Well, It All Started When The Driver Of My Suv Stopped Very Fast And Decided To Turn Off Vehicle While Still In Drive Mode And Some Shifted...
Aj94
How To Replace The Tensioner Pulley?
Hello, I Need A Diagram Or Any Help To Replace The Tensioner Pulley.
lionell8732
MERCURY MILAN
Codes P2096, P0137, P013a, O2 Sensor DTC Issues?
So, I Got Codes P2096 And P0137. Autozone Said Run Cataclean To Clean Catalytic Converter. The Code Went Away Then Came Back After A Day Or...
DangeRuss7
SCION FR-S
A/C Blower Is Not Working?
I Have Checked All The Fuses And The Power Is Good. I Checked The Positive And The Negative Lights In The Blower Is Active But Not Working.
Makanaki007
DTC Issues
So I Got Codes P2096 And P0137. Autozone Said Run Cataclean To Clean Catalytic Converter. The Code Went Away Then Camd Back After A Day Or 2...
Russell Dickinson2
SCION FR-S
Code P0722, Where Is The Output Speed Sensor Located?
Hi, I Have The Car Listed Above Limited And It Has The Code P0722 Low Voltage In The Transmission Speed Output Sensor, I Don't Know...
Yadier99
The Engine Barely Starts When It Does Start It...
My Good Running Vehicle Listed Above Was Recently Stolen And Recovered. The Damage That Ensued Was A Broken Door Lock Cylinder And Damaged...
z28makanic
CHEVROLET BLAZER
Color Code Wires
I Need Color Code For Fuse Box
Marckey
590
591
592
