Electrical Issues With Vic And Digital Instrument...
I Just Purchased The Car Listed Above That Has Sat For Roughly 5 Years. I Got A Good Deal On It And I’m Trying To Fix This Electrical...
jay-doug
OLDSMOBILE TORONADO
The Air/Fuel Ratio Is Stuck At 1:1 And The Engine RPM...
Recently Had To Replace The Crankshaft Position Sensor (ckp) And Attempted To Perform A Crankshaft Variation Relearn (p0335). The Relearn...
NOLA Jax
GMC CANYON
Jumping And Bucking Upon Acceleration?
I Have The Truck Listed Above 1500. It Starts Fine, Idle, Fine Shift Into First Gear, Fine, When You Shift Into Second And Accelerate It...
kevinscott1985
Crank Sensor Replacement?
Hi, I Am Going To Change The Crank Sensor On My Car Listed Above. Advice On Any Special Tools And If This Is Something That A Lot Of Other...
StrictlyDimes
LINCOLN TOWN CAR
Massive Coolant Leak And Engine Smoking?
It Is Smoking From The Engine Bay Near The Air Filter, On Top Of Engine, Has A Major Coolant Leak That You Can Only See Under The Car At...
bradensplanet
CHRYSLER CONCORDE
Left Side A/C Blowing Hot Air?
My Car A/c Is Working Fine But Suddenly The Left Side Blows Hot Air And The Right-side Cold Air. I Tried To Reset It And It's Working...
ramzith1
MERCEDES BENZ S600
High Idle?
At Startup, 2,000 Rpms, After A Few Minutes, 1,300 Rpms, In Gear With Brake 1,100 Rpms, Let Off The Brake And Just Apply Throttle And...
Boofer22811
Car Turns Over, But Will Not Start?
Can A Lock Smith Program The Key And So On As Good As A Dealership?
DaleM Miller
The Gauges Will Drop To Zero, The Service Vehicle Soon...
The Odometer And Shift Indicators Work Fine Though.
Figgy&Trixie
BUICK CENTURY
Turns Over No Start
Vehicle Stopped Starting, Chuggs Sometimes For A Moment, Turns And Turns Will Not Run. Can A Lock Smith Program The Ignition As Good As...
DaleM Miller
Wondering If A 2014 Chevrolet Traverse Has Freeze...
Wondering If A 2014 Chevrolet Traverse Has Freeze Plugs. I Went To My Local Autozone And Nothing Came Up In Their System.
Smith0211
CHEVROLET TRAVERSE
Does This Vehicle Have Freeze Plugs?
I Went To My Local Autozone And Nothing Came Up.
Smith0211
CHEVROLET TRAVERSE
Po171 Code
Car Hard To Start In Morning But Runs Fine Afterwards. Just Bought Car A Few Months Ago. Already Replaced Maf Sensor But Code Still There
bfern8642
Code Po171?
Po171 Code. Car Hard To Start In Morning But Runs Great Afterwards.
bfern8642
New Ignition Key Lock Cylinder Programming?
The Ignition Key Lock Cylinder On Vehicle Was Replaced With A Key Lock Cylinder Off Of An Expedition Will I Be Able The Program The Key To...
EM Leilani Ps
Crankshaft
I'm Having Trouble Finding Where My Crankshaft Sensor Is To Replace It
fionaarnett
HYUNDAI TIBURON
Braked Hard And The Front Driver's Side Wheel...
I Braked Hard And The Front Drivers Side Wheel Has Moved Backwards.
David Mcqueen
VAUXHALL CORSA
New Ignition Switch?
Put In New Ignition Switch And Key Goes To Acc But Doesn’t Go Any Further.
Kat82
SATURN SL1
Bloody Old 93 Magna Won't Start
My Old Uncle Wayne Loves His 1993 Mitsubishi Magna. Made In S.A ( South Australia). With Us Living In Adelaide He Is Persisting With This...
nakkas44
MITSUBISHI MAGNA
Brake Fluid Coming Out Of The Caliper Bleeder Screw?
This Is A 1998 Ford E-150 Econoline Club Wagon. I Tried To Replace The Front Caliper Bleeder Screws Because They Were Rounded Off. I...
carfixes
FORD E-SERIES VAN
Lifter Tick/ Rocker Tapping Noise?
I Had The Lifters Replaced About 2 Weeks Ago To Fix This Issue, But It Hasn't. When The Truck Is Idling It Doesn't Make Any Lifter...
Lamp3553
CADILLAC ESCALADE
A/C Not Cooling?
A/c Has Stopped Blowing Cold. I Noticed Over A Few Months That The Ac Would Stop Being As Cool For A Few Seconds But Then Would Operate Fine...
Kevin Felty
FORD FREESTYLE
Throttle Body Fuel Delivery Problems
I Have A 1998 Gmc Suburban And It Had Sat For Several Years Before I Got It And Now I'm Having Fuel Delivery Issues. I Replaced The Fuel...
rb.burnside
GMC SUBURBAN
Clunking Sound While Driving?
While Driving At Slower Speeds And On Slightly Uneven Ground, There's A Clunking Sound Like Something Is Broken. I've Looked Under...
juanemmanuel
My Truck Is Making Oil!
Hi And Thank You For Helping, We’re A One Vehicle Rv Family That Just Moved From Pa To Az. Had Injectors, Hpop, Ipr, Cps, Etc...
groundhogy
588
589
590
