Brakes, Guide Pins Are Rusted And Will Not Move In Or...
And My Gas Mileage Has Went Out The Window.
Timsisneros
Belt Tensioner Installation Instructions Needed?
My Old Belt Tensioner Busted Off Somehow While Driving. I Need To Install The New One, But I'm Not Sure How To Install It And If I Need...
cnangle
Transmission Is Experiencing Rough Shifting?
A Few Months Back My Car Threw A Code That Said, Shift Solenoid From 5 To 4 Was Malfunctioning. I Stopped The Car, Turned It Back On, And...
mgurule16
BMW 530XI
Heater Circuit Low For All O2 Sensors?
Recently Purchased This Car Broke Down As A Project To Fix Up Myself, The Only Codes It’s Showing Is The Heater Circuit Low For All 4 O2...
Noah.b.111
No Power Up Steep Hill, Low Speed?
I Do A Lot Of Fishing In The Back Country. My Trailer Weighs 1,800 Lbs And Another 500lbs Of Gear In The Bed In The Bed. My Truck Works...
Happyfisher
Grinding Noises When Put In Gear?
Delay Between When Foot Placed On Gas Pedal Or Brake About 6-8 Seconds. Gas Pedal Has To Be Pushed Hard And Car Barely Moves.
jacalf96
Parasitic Drain?
Hi, Using A Fluke Multimeter I Think I Have Chased Down The Parasitic Drain However, In Diagnosing I Used A Hot Lead Tester As Well. I Can...
B.L SHLEPROCK
28 IMAGES
Replacing Tensioner Belt?
This Is The S Model. I Have Seen A Lot Of Videos Which Show Different Versions Of The Tensioner, So I Would Like To Get The Right Info For...
MINI COUNTRYMAN
Reinstalled The Cruise Control Servo, And The Cruise...
I Just Reinstalled The Cruise Control Servo Into The Pickup (had To Repair The Rubber Diaphragm). Everything Is Plugged In, But The Cruise...
twebb101
1984
How To Conduct An A/C Reset?
Recently My Van Overheated Because The Cooling Resistor Went Bad. Now A/c Is Not Blowing Cold. How Do You Reset A/c? I Would Like To Check...
luisperez9310
Passlock Feature
Did So.E Transmission Work Replaced 4 Selenoids A B 3 4 And The Vvt. All 5 Were Above The Transmission Pan, So I Removed It. Test Drove...
Monte Hammar
Wheel Sensor Wire
I Found That The Front Right Side Wheel Sensor Wire Was Unplugged, But I Couldn't Find The Rest Of The Wire. The Sensor Wire Was Just...
Abdul Sabith
Engine Knock?
Hello, I'm A Mechanic At An Independent Shop And I Recently Took Over Someone Else's Job Because They Quit. The Other Mechanic Had...
ONNIK1966
Where Is The Bleeder Valve Located?
I Am Trying To Locate The Bleeder Valve In My Car, And I Can't Find It.
Jujubee59
W212 Om651 Engine A/C Wiring Diagram Needed?
Good Day I Have A Problem, After A Small Fire Of Engine Bay I'm Installed New Engine Harness, Car Runs No Issues Just A/c Not Working...
Lietuvis
17 IMAGES
MERCEDES BENZ E220
Sunroof Will Not Close?
I Opened Up The Sunroof On My Ride Home And When I Stopped The Glass Would Not Close. I Popped The Switch And Checked It With My Meter, And...
Ronson
Electrical
My Windows And Power Mirrors Didn’t Work So I Replaced The Fuse And That Solved The Problem. Then After Checking The Rest Of The Fuses And...
JamieRussell
A/C Blows Hot Air?
The Compressor Clutch Does Not Engage. The A/c Fuse Is Good But There Is No Power To The Control Side Of The A/c Relay. I Suspect It Is The...
Weeder
Turn Signal And Hazard Lights Stopped Working?
My Indicators And Hazards Lights Have Stopped Working, The Bulbs Still Flash When I Lock My Van So I Know It's Not The Bulbs And The...
Brendon93
FORD TRANSIT
A/C Discharge Hose Needs Replacing?
What Needs To Be Removed To Change The Hose?
marlette11
CHRYSLER PACIFICA
Starter Solenoid Wiring Diagram Needed?
My Battery And Starter Quit Working At The Same Time. I Have Changed Them Both. My Problem Is That When I Turn The Key On, All The...
John Fullilove
The Driver's Side Door Intermittently Does Not...
Drivers Side Door Sometimes Will Not Open From The Outside Or Inside Handle.
tomjjonas
CHEVROLET 2500
Steering Column Swap?
Hello, A Friend Of Mine Just Recently Bought A 1993 Chevy Beauville Van But Unfortunately, He Didn't Even Get The Van Home When He...
Riperez1027
CHEVROLET VAN
Shuts Off After The Engine Has Warmed And Will Not...
My Car Has Been Sitting For About 3 Years, I Charged The Battery, And It Fired Right Up. After Idling For About 3 Or 4 Minutes It Shut Off...
David442Simon
MERCEDES BENZ ML320
A/C Compressor Noise?
When The A/c Is On, And The Compressor Is Running There's An Intermittent Clicking Noise Appearing To Come From The Compressor. This Is...
Jeff Herman
VOLKSWAGEN JETTA
584
585
586
