A/C Stopped Working?
So Today, The Girl's Car A/c Went Out, Blowing Hot Air - I Went To Harbor Freight And Bought This Pittsburg R134a A/c Manifold Gauge...
JetTheGuru
Changed And Programmed Key Sentry Immobilizer And Now...
Changed And Programmed Key Sentry Immobilizer And Now Engine Doesn't Want To Turn On?
Sofia Lerma
No Start
Put A New Starter On But The 40 Amp Fuse Keeps Blowing What Should I Do
Simmie Smith
Alarm Enabled After Wrong Key Used?
My Husband Replaced The Motor And Battery In The Car Listed Above. He Put The Wrong Key In, And The Alarm Went On. We Tried Taking The...
Sindy73
SATURN SC1
Poor Acceleration And White Smoke, Engine Will Not...
I Started My Car Today And It Seemed Fine. Last Night It Was Fine. I Noticed That The Fuel Light Was On Through, But It Wasn't On Last...
Cegan84
PEUGEOT 307
Stuttering When Driving Uphill?
My Car Sometimes Does This On Flat Road But Always When Going Uphill. I'm Not Sure If This Is Considered Stuttering But As Soon As I...
Allison Brockman
How To Recharge The A/C?
Changing Out An A/c Line That Had A Pinhole In It Since 2018. What All Needs To Be Done Now To Recharge?
Dan Hooks
Where Is The Speed Sensor Located On A Cobra...
This Truck Had The Transmission Replaced Before My Brother Bought It. I Have Spent Hours On My Computer Looking For Information On What I...
Pati Muth
FORD TRUCK
Stuck In High Gear After Period Of Time At Highway...
Hi, E320 3.0 V6 Diesel. Drives Great Around Town. When On Highway, Gets Stuck In Overdrive, Will Not Downshift When You Step On Gas To...
ryan.tim.j
MERCEDES BENZ E320
Crank No Start Issue?
Replaced Cam Shaft Sensor And Coil Packs As Well As Plugs And Wires. But Now It Doesn't Start But Gets Power. It Ran And Drove Great...
Brandon234
Horn Not Working?
I Have No Horn From Steering Wheel Or The Key Fob.
bryant.arlt
While Driving There Was A Pop And Transmission Will...
Hello, I Was Heading To Work About A Week Ago And There Was A Pop Or Like Air Rushing Sound And My Truck Will Not Engage In Any Gear Almost...
Jay117
Check Engine Code P0456?
Check Engine Light Came On, Code Given Was P0456. The Gas Cap Seemed A Little Loose I Replaced It. How Long Does It Take For The Light To...
Shelbyp
Where Is The A/C Compressor Relay Located?
I Just Replaced My A/c System And There Are No F Codes Popping Up. I Need To Know Where The Relay Is For The A/c Compressor. Preferably A...
Eggbeeter
CADILLAC SEVILLE
After Installing A New Radio, The Turn Signal Clicks...
I Installed A New Gm Radio In My Truck Listed Above And Now The Turn Signal Clicks Loudly Through My Door Speaker.
Mike Fagar
No Crank No Start Issue?
New Starter, Good Battery. When I Turn The Key The Dash Lights Come On, I Can Jump Start Using A Screwdriver. Fuel Pump Kicks On As Well....
Lupasmommy
Will Not Start, Where Is The Crankshaft Position...
My Car Quit Running I Because Of The Symptoms Started Maybe The Electric Fuel Pump I've Changed It, And It Still Won't Start. It...
TDAD58
HVAC System Is Stuck On Defrost?
The Car Is Currently Stuck On Defrost. I Know That It Has At Least 2 Actuators Associated With The Hvac System, But I Need Help Locating...
Gamergaming1313
PONTIAC G6
Vacuum Diagram Needed?
I Am Looking For A Vacuum Lines Diagram To Properly Repair And Replace Multiple Small Brittle Vacuum Lines.
Forester1
Code P0320, Check Engine Light Blinking Eight Times...
First I Will Say I Am Very Dumb About Cars But I Will Explain What I Know The Best That I Can. My Check Engine Light Came On A Week And A...
Elizabeth Charlton
Particle Filter Light Turns On And Vehicle Goes Into...
Hi, I Have The Vehicle Listed Above Tdi, I Started Having Problems When Going In A High Rpm. It Gives Me The Particle Filter Light And...
xetoxi
AUDI A4
Happy 4th!
Hope All Of You And Your Families Have A Happy And Safe Fourth Of July! Enjoy! Brendon S.
Brendon S
What Is The Fuel Pressure For This SUV?
What Is The Fuel Pressure For The Vehicle Listed Above Xl Model, Flex Fuel With āzā Eight Digit Of The Vin, Not Running And Running? I...
Native11
The Hand Brake Light Or The Brake Warning Light Always...
Checked The Handbrake Switch And It Works Fine, And The Brake Fluid Is At The Max. I Have Also Unplugged The Brake Fluid Reservoir Sensor...
Abdul Sabith
Instrument Cluster Pin Wiring Diagram Needed?
Can I Please Get The Instrument Cluster Wiring Diagram For This Car Listed Above?
Abdul Sabith
585
586
587
