Panel Lights Blank
My Entertainment Panel Went Dark. Radio Works Via Steering Wheel. No Air/heat Lights On Buttons, Air Is On From Previous Setting But Will...
1seer7
2022
Lost Entertainment Light Visual?
My Radio Is Working Via Steering Wheel Controls But Have A Blank Screen, My Air Is Working Where I Had It Saturday But Lost Lights On Knobs...
1seer7
A/C Warmer On Driver Side Than Passenger Side?
I Bought This Car A Month Ago For $260. It Has Been Sitting For A Year Or 2. Car Fires Up In Half Of A Crank, Even The First Time After...
TheMailMan
BUICK CENTURY
Idling High In The Morning, Took About 4 Minutes To...
2010 Mazda 3, 1.5ls Takes About 4 Minutes 40 Seconds For The Rpm To Drop From 1600rpm Where It Start From, To Slightly Less Than 1000rpm...
Misheck Banda
Transmission Code P0780?
Could You Give Me Any Advice At All Speed Sensor Lock Up Solenoid? Anything Helps, It's Our Only Car And I'm Losing Work Every Day...
Betsy05
Misheck Banda
The Car Engine Suddenly Started Sounding Like A...
The Car Started Sounding Like A Motorcycle All Of A Sudden. I'm Not Sure What Is Making The Engine So Loud. There Is No Check Engine...
crazyknarf175
HYUNDAI ACCENT
Truck Start Then Dies
I Recently Bled The Fuel Lines On The Injectors Because There Was Air In The Lines. The Truck Starts But Dies After A Few Seconds And Won’...
Rubengr541
Code U0028, Pinout For PCM/ECU And The ABS Pump Needed...
I Have A U0028 Code And My Car Shows The Abs Light And Traction Control Light On The Dash. A Code Scanner Says It Cannot Communicate With...
benzonium
A/C And Heater Has Low Volume Of Air Being Pushed...
My Truck Has Had This Issue Since I Purchased It A Few Years Back. When I Turn On The Ac And Or The Heater The Airflow Is Minimal. I Have...
Jr Payne
Engine Shuts Off At Idle?
It’s Long But Any Help/advice Is Greatly Appreciated. So, Two Months Back I Was Driving, And My Engine Just Shut Off While At A Fast-...
angieeg
Code P0087, Where Is The Fuel Rail Pressure Sensor...
The Car Listed Above Is An Sho, Check Engine Light, Code P0087. I Already Replaced The Fuel Pump 3 Months Ago, Need To Replace Fuel Rail...
Rcflyer519
17 IMAGES
Possibly Warped Rotors And Brake Pads?
Whenever I Step On My Brakes While Going Downhill At Speeds Higher Than 50 Mph My Steering Wheel Starts Shaking And When I’m Stopping My...
MakinzieG97
KIA OPTIMA
Car Would Not Start After Installing A New Battery?
We Took The Car To Autozone And Tested Things To See Why The Car Wouldn’t Start After Getting Battery Jumped Enough To Get There. Bad...
emundy
DODGE JOURNEY
How To Properly Recharge The A/C System?
A Hose Blew And Freon Leaked Out 5 Years Ago. I Replaced The Hose And I Think I Am Ready To Recharge, Or Do I Have To Clean The System Out...
Dan Hooks
Hatch Door And Glass Will Not Unlock?
Rear Hatch And Glass Will Not Open. I Do Not Hear Them Unlocking. I Have Changed The Hatch. I Have Power At The Lock Plug. I Think I Have...
Dave Harman
Weird Knocking When Turning (full Lock) Left And Right...
When I Turn Left Or Right And I Reach The Full Steering Range In Either Direction, There Is A Fairly Loud, Clunk Knock Sound. The Sound Is...
Ryan Severn
TOYOTA TACOMA
MakinzieG97
KIA OPTIMA
Rear Differential Replacement/swap?
This Truck Was Recently Gifted To Me. The Only Thing Known To Be Wrong With It Is That The Rear Differential Is Going Out On It. I've...
olivereric423
Where Is The Ecu Located?
I Am Looking For The Location Of The Pcm Or Better The Ecu Location.
Camp.
TOYOTA SEQUOIA
Starter Wiring?
My Question Involves The Starter Signal Wire. I Am Guessing That It Attaches To The Small Stud On The Solenoid. Not The Bigger Stud That The...
John Fullilove
After Replacing The Throttle Body, The Red Lightning...
So Red Lighting Bolt Still Coming On After I Changed My Throttle Body What Can It Be? Need Help!
Ikmason
DODGE CALIBER
Where Is The Camshaft Position Sensor Bank 2 Located?
Hello, I’m Trying To See Where The Camshaft Position Sensor Bank 2 Is Located.
Iriahmichelle
NISSAN MAXIMA
BCM Wiring Diagrams Needed?
The Truck Listed Above Is A 2500hd With Duramax, Sle Trim. I’m Looking For Bcm Wiring Diagrams. Door Ajar Switch Wires Specifically....
Devins0202
Where Is The Wire Connection For The Number 2 Plug?
I Only Find 1, 3, 4, 5, 6.
Bob Bryant
BUICK PARK AVENUE
583
584
585
