Instrument Cluster Comes On, But The Engine Will Not...
When I Turn The Key Fob The Instrument Cluster Comes On But Won’t Crank Or Anything. Just Acts As If The Battery Is Drained. Check Battery...
Jere Lebowsky
CHRYSLER TOWN AND COUNTRY
Citreon Nemo Cuts Out In Idle And Struggles To Start
Citreon Nemo 1.3 Diesel Cuts Out When Slowing Down. Always Struggles To Start But Drives Well With No Power Loss. No Fault Codes From Plug...
Matt Treherne
CITROEN VAN
Where Is The MAP Sensor Located?
I Am Looking For A Diagram Of The 1993 7.4l 454 With Sensor Locations. I Believe I Have A Bad Map Sensor.
Zack Lowell
Wiring Diagram With Dual A/C Rear/front?
Overcharging Battery/alternator From Ecu/ecm.
Codey Allen
FORD FREESTYLE
The A/C Is Working And Full Of Refrigerant But Barely...
Then When You Shut The Vehicle Off A Few Minutes Will Pass By Then It Makes A Loud Burping/fart Sounds Out From The Dash. This Will Happen 2...
Jr Payne
Low Idle And Random Shutting Off While Driving?
Low Idle Bubbling Noise And Does It While Driving If Stop At A Stop Sign.
Clarke94
Code P0175, Emissions System, Truck Jerked And Started...
While Traveling Between New Orleans And La In West Texas Currently. Before Leaving Nola Emissions System Code Came On P0175. Couldn’t Get...
Cresser116
HONDA RIDGELINE
Does My Car Require Only The Front Wheels Aligned Or...
I’m Confused.
Randon
Taillight And Running Light Not Working?
The Right Taillight And Running Light Not Working, But Brake Like And Blinker Work.
zlatta2016
CADILLAC ESCALADE ESV
When Car Starts, Runs Well, However Does Not Start...
I've Had This Car For A Month. I Had To Replace The Radiator, Spark Plugs And Wires, And Replaced The Transmission Line To The...
soyrosemarie
Will Not Start, Starter Does Not Turn?
When Turning The Key, The Starter Will Not Engage. We Replaced The Starter, And The Same Thing Occurred. We Checked Out The Old Starter...
SCXJ
1972
MERCEDES BENZ 250SE
Fuse Panel Problem?
I Bought The Truck Listed Above Xlt This Week. After Bringing It Home I Realized There Were No Brake Lights. Tested Fuse Was Dead: But Not A...
TysTruck
No Power To Half Of My Fuses
Bought A 1999 Ford Ranger Xlt This Week. After Bringing It Home Realized There Is No Brake Lights. Tested Fuse, Was Dead: But Not A Bad...
Tyler Lee2
Tyler Lee2
Has New Pump Paid A Mechanic To Put Freon And It Still...
So I Have A New Pump And It Has The Clutchless Compressor It Has That Solenoid But Anyways It Has 3 Volts Going Down To It And It Isn't...
Phil riehm
Broken Honda Accord 2009 Vsa Button
I Need Someone To Tell Me If I Can Use Wire To Turn It On And Off, Can Easely Open The Module, Have Much Tools And Pretty Good Mechanic
Phil420
Climate Control Panel Not Working?
The Air Conditioner Control Unit On My Wife's Vehicle Listed Above Sl Just Went Blank A While Back. No Lights On The Board, Can't...
Doug Sullivan
NISSAN ROGUE
Replacing Top Idler Pulley
Can Anyone Tell Me Where The Third Motor Mount Is Located? I Got The Front Passenger Top Mount And The Front Lower Center Mount The Engine...
JC-842
Replacing The Top Idler Pulley, Where Is The Third...
Can Anyone Tell Me Where The Third Motor Mount Is Located? I Got The Front Passenger Top Mount And The Front Lower Center Mount. The Engine...
JC-842
What Is This Hose?
This Hose Has A Pin Hole Leak.
Dowens1066
PONTIAC MONTANA
Rough Idle And Does Not Accelerate?
My Ignition Switch Broke A While Back, So I Have It Hotwired. I Poured Some Dirty Water Into The Gas Tank A Week Ago, It Started Running...
Mikelcamp
Engine Will Not Start?
So, A Friend Owed Us A Favor So Offered To Detail My Car Since She Had Supposedly Done This For A Living In The Past. Well, She Absolutely...
Megansaurus
MINI COOPER
My FIXD Computer Says I Have An Issue With The PO300...
I’ve Already Had My Spark Plugs Changed Seems To Run Better But I Still Have This Issue. What Could It Be Please? And What Price Is In My...
Rensanslady
HYUNDAI VELOSTER
Front And Rear Brake Does Not Release Completely?
Hello, I Badly Need A Help. A Few Days Back I Changed My Brake Booster Due To Brake Booster Issue. Now The First 10-15 Minutes Car Is...
Shahidul
FORD EDGE
Can The Hybrid Battery Be Recharged, Or Does It Have...
The Car Cuts On, But The Engine Doesn’t. I Noticed That The Hybrid Battery Isn’t Showing Any Signs Of Juice, Usually When You Start...
540Donuts
FORD FUSION HYBRID
580
581
582
