What Is The Oil Filter For Full Synthetic 5W-30
And What Size
Dirtydann
Code P2767?
I'm Back! Hey Ken, Well, It Was Driving Fine Went Probably 35/40 Miles In/out Of Traffic Today. I Changed The Fluid/filter In The...
Willie Hurlocker
DODGE MAGNUM
Prius P0A18 And P3013
Hi, My Car Jerks On And Off Especially When I Try To Speed Up. Also One Of The Fans Is Blowing A Lot More Than The Past. I Took To...
MMMMM
TOYOTA PRIUS
Codes 120308 And 118001?
I Have Been Struggling Alone For 1 Year To Fix These Codes. Ii Had An Engine Change. I Have Resolved 120308 Charge Air Pressure Too Low By...
Ashok Saini
BMW X3
Transmission Is A Little Sluggish When Shifting?
Transmission Is A Little Sluggish When Shifting, Not Bad But Noticeable. I Purchased Truck Do Not Know About Service Intervals On Service...
JC4
TOYOTA TACOMA
Intermittent Check Engine Light?
The First Time The Check Engine Light Came On Was At Highway Speed. The Car Jolted And Light Came In Shortly After. Light Remained On And...
95Celica
TOYOTA CELICA
What Are The Vacuum Pump Pulley Torque Specs?
Does Anyone Know The Torque Specs On The Vacuum Pump Pulley? I Installed A Reman Pump And The Pulley Is Chattering And My Belt Is Squealing.
Tilecruncher
FORD F-350
Fuel Pump Engages, But It Will Not Start?
I Replaced The Fuel Pump Twice Over The Course Of 3 Years. When I Turn The Key, I Can Hear The Fuel Pump Engaging. It Won't Start....
Aquigg79
GMC JIMMY
OBD Port Not Working?
I Can't Figure Out Which Fuse My Obd Port Is Connected To. I've Looked For A Cigarette Lighter Fuse And Every Other Fuse That I...
Galaxyal8230
Power Driver Seat Only Moves On One Side?
The Drivers Side Slide Seems To Move Forward And Reverse Until Passenger Side Slide On Seat Does Not Move At All Seat Racks Back And Forth...
Dnlsbk
CHRYSLER TOWN AND COUNTRY
Rough Riding?
Is There A Way To Tell If My Body Bushings Need To Be Replaced Or If It's My Shocks? I Can Feel Every Crack And Pebble On The Road!...
Willie Hurlocker
29 IMAGES
DODGE MAGNUM
Not Starting?
I Took My Truck To A “tuner” Because I Was Having Fuel Problems And Thought It Might Have Been My Pcm Since I Had Been Told I Needed To...
txzdk
Rear End Click, Click, Click Noise?
Positrac Limited Slip Differential, Backing Up Sounds Like Gears Slipping. Then Forward At Slower Speeds I Hear A Tick, Tick, Tick. It...
RichardOnzelle
Soft Brake Pedal When Started?
Replaced Rear Calipers, Pads, And Rotors. Blead System And Have Firm Pedal. After Starting The Engine Brake Pedal Goes To The Floor. ...
Elboww
HONDA HRV
Misfire And Codes Po113, Po128, Po351, Po356, And...
E150 Had Slight Misfire And No Codes. Replaced 6 Plugs And 1 Coil' Plus Thermostat And O-ring Gasket. The O-ring Was Not Aligned Right...
ANAHN
FORD E-SERIES VAN
Truck Jerks At High Speeds When Let Off The Gas...
My Truck Runs Fine In The City And At Lower Speeds, It Is When I Reach Around 50-75 Mph My Truck Will Randomly Jerk When I Release The Gas...
Santiago Peralez
The Engine Will Crank Over But Not Start?
Car Won't Start Throwing Code Filler Cup Under Pressure! Have Changed The Fuel Filter. Dropped Tank Checked Out Fuel Pump Security Light...
Misty Pollard
Front Brake Pad Kit?
Does The Audi Front Brake Pad Kit 8r0698151 Fit My Audi Q5? This Is The Vin: Wa1cgcfp2fa062186
Mrcrabs2006
AUDI SQ5
How To Match The Original K40?
I Have The Vehicle Listed Above Slk C230 Compressor, That I Believe Has A Bad K-40. Not Only Do I Believe It Is A Bad K-40 But I Think The...
Popofft0823
MERCEDES BENZ C230
While Driving Sometimes There Is An Inside Bird...
Inside As I Drive The Truck It Makes Sometimes A Squeak Chirping Sound Off And On. Goes High And Low Pitch. Sounds Like It Is Behind The...
nm71
LED Bulbs Dashboard/ Instrument Panel Replacement Not...
Today I Replaced The Indicator Light Bulbs On My Dashboard/ Instrument Panel With Led (1797 T5 Led Buld Dashboard Dash Lights - From Amazon...
ro83aa
TOYOTA RAV4
Replace Horn Wiring?
I Need To Replace The Ground Wire (in Center Of Steering Column), The Contact Popped Off The Wire. Does This Require Disassembling Of The...
Lwwilks
1973
JEEP CJ5
Swapped Over Differential And Now Differential Light...
Hi There, We Have Swapped Out The Differential As The Original Was Stuffed Swapped Out With A Secondhand Differential From 2012 Model. Now...
Mj04
HOLDEN CAPTIVA
Thermostat?
I Got My Van Back From A Mechanic Today. The Oil Cooler Was Replaced Because It Was Cracked. The Only Thing I’m Worried About Now Is The...
NKYWeather31
Intermittent Power Loss?
Truck Starts Up And Drives Just Fine. Then Randomly It Will Start To Not Accelerate. If The Clutch Is In, Then You Can Rev The Engine But...
Sam Pauley
NISSAN HARDBODY
570
571
572
