Hi I To Ask A Question........
I Have A 99 Suburban And I Went Out To Start It And The Battery Was Dead. I Quick Charged It And Left It Running. I Got Side Tracked And It...
dumbblonde
Intermittent Horn Blowing During Turn
I Have A 1995 Jetta, And Recently I Have Been Experiencing A Very Weird Problem. While Turning The Wheel, (mostly At Very Slow Speeds Like...
maccawolf
Suzuki Sidekick Overheating, Help?
I Have A 93 Sidekick Which Has Had A New Motor Just Recently Installed From A 2002 Car. It Has Just Started Over Heating The Last Couple...
lmatthew
SUZUKI OTHER
Noisy Tires On 99 Ford Explorer
My Front Tires Are Extremely Loud When I Take Off. When I Stop The Sound Stops, But Continues When I Start Moving. I Ran My Hands On The...
lterwin
1998 Chevrolet Tracker Turns Off When Decelerating!
Hello. I Have A 1998 Chevrolet Tracker. My Problem Is This: Whenever I Accelerate Real Fast, The Car Makes A Sound Like It's...
jmart
Grinding Noises
I Have A 96 Sl2 With A Manual Transmission With About 200000 Miles On It. I Get Two Grinding Noises. The First Started Happening A While...
Hinkster2000
HELP PLEASE!!! 1997 GMC Safari
My Van Was Running Fine And One Day Just Died In The Middile Of The Road. It Felt As Though I Had Run Out Of Gas Although The Gas Gauge...
driftaway13
GMC SAFARI
Oil On Sparkplug
I Have A 96 Sl2 With A Manual Transmission. I Have Several Things Wrong At Once But I'll Just Cover One Question At A Time. Recently My...
Hinkster2000
1991 Nissan Truck Smog Test Failure
Earlier I Had Asked A Question About My Truck Not Passing Smog Test, I Pulled The Plugs, And They Almost Look Brand New, However With The...
billf106
NISSAN TRUCK
Oil Leak
:( My Honda Odyssey 1995 When I Turn On The Engine, Oil Leak From Behind Oil Fillter. Is It Not From Oil Fillter Gasket. What Do I Need To...
davidnguyen
HONDA ODYSSEY
Lumina Heat And Transmission (1999)
Hi There! (1999 Lumina Sedan 3.1, 116,000 Miles.) My Questions Are: 1) Occasional Hard Shifting In And Out Of 1st Gear. Had...
cactusman
CHEVROLET LUMINA
OBDII Codes P0171 & P0174
I Own A 1995 Mustang V6 3.8 Liter And Recently My Check Engine Light Came On. I Borrowed A Scanner And The Codes That I Got Were P0171 And...
sponge27
Fuel Problem MX3
Hi, My Mx3 1.8 V6 Has What Seems To Be Fuel Starvation When It Turns Right At Just Under Half A Tank Of Petrol. Had New Fuel Lines Fitted...
Anne
MAZDA MX5
1996 Silverado Z71 (350) Transmission Question
I Was Driving The Other Day And My Abs System Started Going Crazy. After Turning Engine Off And On It Was Reset, But An Hour Later It Did...
DAVENMER
94 S 10 Blazer Transmission
I Have A 94 S 10 Blazer 4 Wd, I Am Replacing The Transmission Filter And Gasket. I Have Removed The Pan And Cleaned It, And Attached The...
sirloganmoore
Battery Drains
Hey I Have A 1986 Bmw 528e And The Battery Seems To Drain And I Was Wondering If You Guys Had Any Idea Wat That Might Be Thanx
Big O
BMW 528
Engine Knock
Hi - I Have A 2000 Toyota Corolla With The 1zzfe Engine With The Timing Chain. It Has 135k Miles On It And I Need An Expert. I Am Hearing...
tvan
2000 Explorer Front End Rattle
I Have A Clunking/rattling Going On Sometimes When I Go Over Bumps. It Seems Like It Happens More When Going Over Bumps Side To Side, Not...
tntjacques
1992 Mazda 929 Will Not Run.
Last Summer I Was Driving The Interstate, 70mph, And My Mazda 929 Just Quit Running. I Checked The Timing Belts, They Are Fine....
pjbruchs
MAZDA 929
Dodge Caravan Sometimes Doesn't Start
My 1996 Dodge Caravan Just Won't Start Sometimes - Every 3-4 Months It Is Dead As A Doornail. The Battery Always Checks Out, Jump Starting...
Ranger280
1989 Ford Tempo
I Just Got A 1989 Ford Tempo. It's Auotomatic And Runs Good, But The Front Right Tire Has Something Wrong. When I Drive It Makes The Whole...
jeremys18
FORD TEMPO
Rear Tires Wearing Too Quickly..why?
I Have A 1998 Contour Svt. I Purchased 4 Tires Had Them All Mounted And Balanced And Installed. Shortly Afterwards, The Rear Tires Seemed...
markmark69
Intermittant Starting
Hello My 2000 Kia Sportage All Of A Sudden Developed A Problem. It Has 69,500 Miles On It And It Runs Fine Shakes Slightly When Running...
J.P.
KIA OTHER
Air Intake Temp Sensor
Hi There I Was Just Wondering If Some One Could Please Tell Me Were The Air Intake Temp Sensor Is On My Holden Commodre Vr I Have Looked...
dareo69
1997 Dodge Ram 1500 4X2
How Does One Repair The Steering Locks For This Truck? The Truck Was Towed And The Driver Told Me That The Steering Did Not Lock. What...
jyeater
20176
20177
20178
20258
