Grand Am Question
Does The 94 4dr V6 Have Discs On All Fours Or Is It Front Disc And Rear Drums
ratz4
94 Pontiac Grand Am Brake Problem
When Stopping I Sometimes Have To Pump The Brakes, I Check The Master Cylinder And The Fluid Was Low So I Added To It But That Did Not...
ratz4
Looks Like Oil Starting To Mix With Coolant
I Have A 1997 S10 Blazer 4.3 V6 I Notice A Small Leak Two Or 3 Days Ago That Looks Like Water Pump But The Bigger Concern Is It Looks...
amarkshoto
2001 Pt Cruiser No Spark
I Have A 2001 Pt With A 2.4 Lt Engine It Will Not Start No Spark Unless I Unplug Cam Sensor Than It Will Run (poorly) As Soon As I Plug It...
thatsuitsu
1992 Dodge Daytona 2.5L
No Heat Coming Out Of The Heat Vents, Just Cold Air. We've Replaced The Thermostat, Water Pump And Coolant. We've Run Water Through The...
Joe Naffah
DODGE DAYTONA
Urn Signal Flasher Broke And I Want To Know Where It...
My Turn Signal Flasher Broke And I Want To Know Where It Is Located So I Can Fix It. Please Help
kitkat822000
1996 Toyota T-100 Pickup
Where Are The Horn Relays Located For This Vehicle?
Dirtygirl
TOYOTA PICKUP
1991 Mercury Capri Dies After A Few Miles
The Car Has A Mazda Engine/tranny 1988/1989 323 I Believe. It Has 140000 Miles And Has Run Great Until Now. Starts Fine And After A Few...
jfinternet
MAZDA 323
Manual Trans Fluid Type
I Was Told That The Fluid Type For My 97 Ranger Manual Trans Is Mercron Auto Trans Fluid. Is This Correct And What Weight Should The Fluid...
paullloyd
1997 Honda Accord LX
I Have A 1997 Honda Accord Lx. The Drivers Side Window Is Stuck In The Down Position. The Switch Will Not Work. The Other Window...
Ms May
96 Pontiac Sunfire Dead Battery
If My Car Isn't Started Every Day The Battery Goes Dead, Just Like Something Is Draining The Battery. I Brought It To A Mechanic And I Was...
nicole4c
PONTIAC SUNFIRE
2003 Ford Explorer ABS
I Had To Replace The Right Rear Caliper, Rotor And Brake Pads On My 2003 Ford Explorer, I Bled The Caliper And The Brake System Works As...
mikeguyver
You Are Doing A Great Job Mods!!! Read Me!
Did You Ever Get My Response To Your Last E-mail To Me? Waitin For That Call. :Wink:
mvannessjr
1981 Cadillac DeVille Brake Problem
I Own A 1981 Cadillac Deville With A V6. The Problem Is That The Brakes Are Hard And Will Not Stop Like They Should. Once In A While They...
rhstrat
1981
CADILLAC DEVILLE
Prelude Suspension Noise?
I Have A 2000 Prelude And Am Concerned About A Noise I Hear When Taking Off From A Stoplight. After Accelerating From A Complete Or Almost...
AuthorityPoison
HONDA PRELUDE
1990 Acura Legend: No Fire To Coil
Did Your Mechanic Check The Input Sensors?
Hitek
HONDA OTHER
89 Acura Integra
You Said You Have Fuel, How About Spark? 8)
Hitek
HONDA OTHER
2000 Silverado Won't Idle
2000 Silverado 4x4 5.3l Auto I Went Out To Start My Truck That Has Always Started Since I Bought It, And It Wouldn't Quite Fire. After A...
39DUCK
Heater Inop 1988 Chevrolet Pickup
Question For A 1988 Chevrolet 1/2 Pickup W/ Ac. 25 Amp Heater Fuse Blew Today While Selecting Blower From High Speed To Low Speed...
skiase
94 Camaro, Stalling Problems
I Have A 94 Camaro Z28, 5.7l 6-speed, And For The Past 2 Weeks My Car Has Been Running Funny. It Runs Good For The First 10 Minutes Or So...
crunch17
'98 5.4 Expedition Octane
I've Been Thinking About Running 89 Octane In My '98 5.4l Ex. Pros & Cons?
rjt1210
Rough Acceleration After A Ride
If I Go Out And Start My Car Up Right Now And Take It For A Ride It Will Run Good For About 5 Minutes And It Gradually Gets Worse And Worse...
violentgod1
Heater Core Replacement
No Easy Task It Is Accessed By Removing The Glove Box And Removing Any Other Interior Components To Gain Access. Remove The Heater Hoses...
Lovescars
Noisy Lifters?
87 Celebrity W/2.5 Eng. 97k Miles. The Car Runs Very Well, Good Power And 30 Mpg, No Misses, No Knocks But Sounds Like I Have Loose...
citizenmike
Backup Lights Stay On - Dodge 2500 Van
I Have A 1995 Dodge Ram 2500 Conversion Van, And For The Past Few Months, The Backup/reverse Lights Stay On When I'm Driving. I Can't...
dleffats
CHRYSLER VAN
20177
20178
20179
