96 Xjs Speedometer Problem
69500 Miles Speedometer Needle Is Pinned To The Right. I Was Removing Instrument Package To Send Speedometer Out For Repair. Hoever I...
lboiman
Changing The Oil
I Know This Is A Crazy Question But Im Changing The Oil In My 01 Isuzu Rodeo, And Well Either Im Blind Or Have Forgotten Everything I Know...
NVKITEN
What Is A ECT Or A EOT Sensor?
Ect Is An Engine Coolant Temperature Sensor. There Is A Pretty Complete List Of "auto Term Abbreviations" Linked To @ The Blue Bar To...
peppermrj
Which Torque Bit To Remove Caliper Bolt On A 94...
1994 Buick Lesabre Front Disc Brake Caliper What Size Torque Bit To Use To Remove Caliper Bolts(i Think It's T 50 But Want To Make Sure...
Norm's daughter
Lights
Thanks For The Site My Son Bought A 1996 Honda Civic Lx With 68,000 Miles On It. It Was Working Perfect. Now The Lights Do Not Work, (...
shannah927
1991 Oldsmobile Cutlass Ciera Mileage Approx. 150,000
I Just Recently Had My Spark Plugs Changed Because My Car Was Stalling Out Quite A Bit. Well, I Took It For A Test Drive After Spark Plugs...
jessicant
Door Latch
When I Pull On The Outside Door Handle To Open The Passenger Door, It Will Not Open. I Have Removed The Inside Door Frame And See A Rod...
CURLYGIRL2424
Headlights Won't Shut Off ?
Hello, I Have A 1998 Dodge Ram 1500. I Am Having Troubles Getting My Headlights To Shut Off. My Highbeam Indicator Light Is Staying On...
marutz
1991 Hyundai Scoop Fuel Filter
I Need To Replace My Fuel Filter In A 1991 Hyundai Scoop; Unfortunetly, Nobody Has A Spec Book Around Where I Live. Where Is The Fuel...
akoski
HYUNDAI OTHER
Acura 3.2 Tl 122500 Miles
Forgot To Mention That Here In Pa. In Order To Pass The Emmission Inspection (smog Test) The Gas Cap Must Be Tested. I Would Assume This To...
peppermrj
2000 Ford Ranger 4x4 Fuel System
Can Any Body Tell Me What Fuel Pump Driver Module Disabled Or Offline Means, Also Fuel Pump Control Out Of Self Test Range. I Got These...
nunavut
Removal Of Clutch Line 2000 Ford Ranger
I Can't Seem To Figure Out How To Get The Clutch Line Unplugged At The Transmission On A 2000 Ford Ranger. I Have A New Clutch And Internal...
Shadwick1
1994 Ford Econoline F150 5.8 L Motor
I Can't Figure Out Why My Gas Is Leaking Into The Oil And There Is A Lot Of White Smoke Coming Out Of The Tail Pipe. Can Someone Help?
amartinez
FORD E-SERIES VAN
Rear Main Seal On A 92 S10blazer 4.3 V6
I Was Driving Home And Started To Smell Oil. I Drove It Straight Home And Parked, Got Out And There Was A Steady Drip For A While Then Quit...
numlock187
CHEVROLET BLAZER
Converter Plugged?
Got A 94 Thunderbird 3.8 Supercharged, Replaced The Head Gasket Cause It Was Leaking, Wouldn't Start Afterwards, Towed It To The Garage...
MDWoggon
FORD THUNDERBIRD
1992 Grand Voyager
First Of All The Heater Wasnt Putting Out Any Heat. So I Put A New Thermostat In Did Everthing I Was Suposed To Do Refilled The Fluid, Let...
eric062674
HELP PLEASE
I Have A 92 Buick Regal. The Car Continously Dies.I Changed The Battery And Still The Same Thing Happens. When You Boost It It Is Fine Till...
Roxyfruvious
1999 Ford Contour Wont Start New Intake Gasket
Hi, I Just Changed An Intake Gasket On My 1999 Ford Contour Because Thats What The Ford Dealer Said Was Wrong. I Came Home From The Dealer...
ryan20021982
FORD CONTOUR
Prices
I Just Went Into A Tire / Car Repair Place And Had My Oil Changed. They Told Me While I Was Waiting That My Car Needed The Fluids Changed...
Munro
Raise The Idle
Where On A 1993 Honda Civic Lx Would I Raise The Idle? Throttle Body? Fuel Rail? Tranny Was Just Replaced And Has Idled Low Since. Think...
brandy1alexander
Idle Low, Stalling
I Have A 1993 Honda Civic Lx W/ 120,000 Miles. Bought It Used And It Has Been Nothing But Trouble. When I Purchased It, The Tranny Was...
brandy1alexander
3.5 Is Over Heating
I Have A 96 Intrepid And I Was Wondering If Any One Has Had This Problem. Its Over Heating But I Checked The Thermostat It Is Ok, I Thought...
rayjdawg
BMW 318 Engine Won't Start
Bmw 318 2003 32,000 Miles. Car Won't Start. As You Turn The Key There Is A Clicking Sound And The Lights Flash In Sync'. After You Stop...
Mike O'Keefe
1931
BMW 318
00 Ford Fiesta
While Driving My 00 Ford Fiesta, I Noticed A Very Loud Clicking Noise Which Became Louder The More I Accelerated. I'm Such A Girl And Don't...
tazk
Pontiac Gran Am 2.4 Quad 4-won't Start
My 2.4 Quad 4 Engine Cranks, But Won't Run. Engine Is Getting Fuel And Fire. When Trying To Start -the Engine Cranks, Then Will Run For...
unowho444
20124
20125
20126
