1998 Kia Sportage Timing Chain
I Have Been Told That My Timing Chain Has Broken But In Order To Fix It I Have To Replace The Motor Because When A Timing Chain Goes Out You...
bubbles4u2c
KIA OTHER
EGR Excessive Flow
1997 Ford F150 122,000 Miles. The Check Engine Light Is On And Reads "egr Excessive Flow". I Have Replaced The Valve And Cleared The Code...
mrhoda
Ford Taurus Door Lock Problems
Hi I Have Ford Taurus Se 1999 Model. Suddenly My Driver Side Door Lock/unlock Stopped Working With Remote And Inner Lock/unlock Switch....
chammama
Oil Pressure Switch
Can Anyone Tell Me Where I Can Find The Oil Pressure Swith On My 2000 Interpid 2.7l. Car Has About 96000km On It And The Oil Light Started...
intrepid
Taurus Won't Start
I Have A 1997 Taurus With A 1999 Sable Engine (car Milage 185000, Engine Milage, 70000). When I Turn The Key, The Car Won't Always...
phantaja
1997 Pontiac GP-GTP Stalling.
Car Ran Fine. Parked It, 4 Hrs Later Started It. It Stalled. Now It Will Run For 10 Seconds And Quits. If I Pump The Accelerator Rapidly...
michda
PONTIAC OTHER
Pontiac Aztek 2001: Key Wont Go Into Ignition
I Have A 2001 Pontiac Aztek, Which Was Working Fine Until A Few Weeks Ago. Now The Key Wont Go Into The Ignition. It Just Wont Go In, I...
slbemailaddress1000
Rear Brakes Won't Work
Hello I Have A Ford Mustang V6 3.8 Y1997 With Discs And No Abs. Now I Have A Problem To Get The Rear Brakes To Work. I've Put New Discs...
yellow
Starting Problem
Ok, Main Wire Coming From Battery Gets Full 12 Volts, When Cranked It Still Gets Full Voltage. So Heres The Breakdown, 1. Signal Wire...
CLE
Starting Problem 1991 CRX Si
My Car Acts Very Weird, Sometimes It Starts Right Up, Other Times It Does Not. I Replaced The Starter With A Junkyard One, And The Same...
CLE
HONDA CRX
2204 Ford Focus ..overseas ..no Dealer To Help Me
I Have A 2004 Ford Focus Se. We Live In Naples, Italy So I Can Not Take It To A Dealer To Get It Fixed Or Even Looked At. Just In The Past...
KristineEakins1
Ford F-150 Charging System
1987 Ford F-150, Just An Old Beater Truck Nothing Fancy! I Recently Purchased This Truck From A Friend. Just So Ya Know, The Rod That...
coffee40
1915
1997 Sable Stalls When Put Into Gear
Car Starts And Idles Fine But Dies When Put Into Any Gear. When I Try To Start It Again, I Have To Depress Gas Pedal And Pump It To Keep...
seattlemary
03 Grand Am GT Stalled In High Waters On The Road...
My 2003 Grand Am Gt Stalled Today While I Was Driving Over High Waters, I Didn't Realize They Were As High As They Were Until My Car...
alysaface
Downshifting Irregularly?
Hi, I Have A 1995 Saturn Sc1 Sohc. Just Recently I Was Driving To The Movies And I Came To A Stop Light. Normally When I Brake It...
Elementkng20
1995 DODGE GRANDCAREAVAN WONT STAY RUNNING
Hi, I Have A 1995 Dodge Grand Caravan 3.8 And When I Start It And Put It In Gear It Dies On Me, Won't Stay Running. But Starts With No...
GREATONE2006
2001 Ford Zx2--99802
? My Car Mil Light Came On. Coed Was P0340, P1383. Cam Pos, And Variable Cam Over Retard (bank 1 ) Ford. Timeing Belt Was Shot Also...
hitman2
Upgrade A Retro
I Have A 1982 Ford Econoline. Wanting To Go Deisel And 4wd. The Quote I Got Was 5k For The 4wd And Lift ( Ihave 2wd ) And Want To Save Some...
lemurbells
95 Chrysler Cirrus Acceleration Problems
I Have A 1995 Chrysler Cirrus Lxi. I Recently Got It Running Again And Now It's Doing Something Really Strange. When I Press The Gas, It...
bohannon9675
CHRYSLER CIRRUS
Replacing Motor Mounts?
2.2 S10 Truck - I Need To Replace The Motor Mounts. What Is The Procedure To Do This Please? I Am Handy With Dyi Automotive Jobs But I Have...
MoJo Nassau
2002 Chevy Caviler 72,000 Miles,backup Lights Don't...
I Have Replaced The Bulbs And Checked Thje Fuse And The Lights Still Don't Work. Someone Told Me It Was The Backup Switch But When I Tried...
Robert Hypes
OLDS CUTLESS CIERA WON'T START
1988 Cutless Ciera Ran Earlier Today But Would Not Start Later. Thought Battery Was Bad So Replaced With New One Still Nothing. No Noise...
RUESNANNY
Car Problems
I Have Been Having Sum Problems With My Car = Replaced Battery Twice New Plugs And Still Doesnt Seem To Run Properly.I Am A Woman And As U...
miles
VAUXHALL OTHER
Spark Plugs Problems After Change
1995 Gmc Seirra 128000 Miles. I Just Changed My Spark Plugs And Wires. I Gapped Them Right I Put Them In Right Just Like I Was Told It...
kevinhurst06
IGNITION TUMBLER
I Have A 1991 Chevy Caprice With Approx 188,000 Miles On It. My Problem Is This.I Have To Change Out The Ignition "tumbler" And Have No...
RLCOOK
20123
20124
20125
