REPAIR GUIDES
BECOME A MEMBER
Sign up with Facebook
OR
I agree to the
user agreement
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
Home
Dodge
Caravan
Engine
Symptoms
Misfire
Slight engine miss
VIPER7788
MEMBER
2009 DODGE CARAVAN
3.3L
V6
2WD
AUTOMATIC
103,000 MILES
The heads, throttle body, water pump, ignition coil, and transmission have been changed. I have bad gas mileage. Could it be the injectors?
Do you
have the same problem?
Tuesday, February 5th, 2019 AT 7:27 AM
EXPERT
Good morning,
I would start with a compression test to be sure the engine has no internal damage.
As far as the injectors, yes, they should be professionally cleaned. Additives have no effect on cleaning.
https://www.2carpros.com/articles/how-fuel-injection-systems-work
SPONSORED LINKS
Tuesday, February 5th, 2019 AT 9:06 AM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
2005 Dodge Caravan Car Is Missing And Starting To...
Please Give Soulution To My Car Missing And Starting To Backfire
Asked by
zellvon
1 ANSWER
2005
DODGE CARAVAN
VIDEO
How to Tell Which Cylinder is Misfiring!
Instructional repair video
GUIDE
Misfire
Easy step by step guide on how to troubleshoot and repair an automotive engine cylinder misfire P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307 and P0308, though ...
2002 Dodge Caravan Vehicle Not Running Correct
I Recently Hit A Deer And The Van Ran After The Accident. I Have Now Just Put A Radiator And New Bumper On. But Now When I Try To Start It...
Asked by
amanda9996
1 ANSWER
2002
DODGE CARAVAN
2000 Dodge Caravan 3.0l Engine Miss
2000 Dodge Caravan 3.0l. Engine Miss. Installed New Plugs, Wires, Fuel Filter And Crank Position Sensor
Asked by
kiknrox4x@hotmail.com
1 ANSWER
2000
DODGE CARAVAN
2000 Dodge Caravan 3.8 Engine Missing And Sputtering
I Have A 2000 Dodge Grand Caravan With A 3.8 Engine. I Stop And Filled Up The Gas Tank. When I Started The Van At The Gas Station It...
Asked by
rbulva
1 ANSWER
2000
DODGE CARAVAN
2005 Dodge Caravan Engine Missing
Engine Performance Problem 2005 Dodge Caravan 6 Cyl Front Wheel Drive Automatic When Driving The Engines Seems To Be Missing Or...
Asked by
windypinesd
1 ANSWER
2005
DODGE CARAVAN
VIEW MORE
Recommended Guides
ADVERTISMENT
Code Read Retrieval/Clear Mercedes Benz
Topdon OBD2 Scanner Review - This thing rocks
Help us make this site better
Online car repair manuals
