Dash board lights out?
JANYIAH
  • 2008 FORD EXPLORER
  • 14,000 MILES
The light on the dash board is out where the numbers re for the miles and the speed. What kind of fuses and where do you put them in.
Tuesday, February 19th, 2013 AT 10:45 PM
  • 52,797 POSTS
Ok, check the fuse #23 in the interior fuse panel (below), if they are ok, then the cluster has failed and needs to be replaced here is a guide and a video being changed on a similar car.
and
https://youtu.be/_HEC44xENxw
Wednesday, February 20th, 2013 AT 1:25 AM
JANYIAH
What is the fuse thank you!
Wednesday, February 20th, 2013 AT 5:42 AM
  • 31,937 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Wednesday, February 20th, 2013 AT 11:04 AM
MARKCHILES
  • 2003 FORD EXPLORER
  • 6 CYL
  • 70,000 MILES
The instrument panel lights wont come on at night, and I cant figure out which fuse needs to be replaced to make the lights work, (the lights where the speedometer is located)
Saturday, December 19th, 2020 AT 9:26 AM (Merged)
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated
Check fuse #16 in underhood fuse box .. also check that the dimmer switch is working correctly !
https://www.2carpros.com/forum/automotive_pictures/266999_exp_9.jpg
ACE21777
  • 4.0L
  • 6 CYL
  • 4WD
  • 233,000 MILES
Taillights, parking lights and dash lights not working None of these are working.
  • 52,797 POSTS
Good morning,
I attached a wiring diagram for you to view. I also attached the fuse box diagram for the location of the fuse.
Verify power to the fuse to be sure power is available.
RKELLY63
  • 2002 FORD EXPLORER
  • 4.0L
  • 6 CYL
  • 4WD
  • 159,000 MILES
I have no parking lights, interior lights and dash lights after trying to install radio and connected illumination ground improperly. Need to know fuse number and location.
Saturday, December 19th, 2020 AT 9:29 AM (Merged)
STEVE W.
  • 13,038 POSTS
Fuse 16 in the junction box under the hood or fuse 17 in the junction box behind the dash. Depends on if it is early or late production. Both are 15 Amp.
PONCHS33
  • 1999 FORD EXPLORER
  • 14,000 MILES
I'm trying fix the dash bored light I found 7 relays under the dash bored I'm trying to find what are those for I Chang the light blob's all. I Chang the cage its still not working I change all the fuse and relays and light how.
Saturday, December 19th, 2020 AT 9:31 AM (Merged)
HMAC300
  • 48,601 POSTS
There is only a dimmer for the dash lights. If they get power then it may be a bad ground or bad dash. See picalso make sure your dash dimmer switch isn't all theway down.
JOSEPH ACCARDO
  • 6 CYL
  • 4WD
  • 240,000 MILES
1999 Ford Explorer Dashboard lights 60% are not lit
  • 108,355 POSTS
Have you checked wiring to the rear of the cluster to see if there is anything loose or disconnected? Also, if you have to replace the bulbs, the cluster needs removed to access them.
HONDATECH74
  • 34 POSTS
  • 6 CYL
  • 4WD
  • 140,700 MILES
The lights for the instrument cluster and heater controls do not come on when the headlights are turned on. I'm thinking it could be the light switch or dimmer switch. Can you help me track this problem down?
  • 108,355 POSTS
Hi:
It could be the switch, a bad ground, or a body control module (BCM). Try disconnecting the battery for about 10 minutes to see if the BCM resets. If not, check under the dash to make sure plugs to the dash are tight. Also, check for disconnected ground straps.
Let me know what you find.
HONDATECH74
  • 34 POSTS
I disconnected the battery and reconnected it, the plugs are all connected properly and, all of the ground straps seem ok.
Lights still don't come on.
HELPING YOU
  • 100 POSTS
Hi, assuming you mean "illumination", not "digital displays", you'll need a wiring diagram (or a like vehicle) and figure out where the circuit's open. Likely the "dimming" portion.
  • 108,355 POSTS
Hi:
My guess (not being there) is either the switch is bad or the BCM has malfunctioned. Have the BCM tested at a shop that has the proper test equipment. If it is ok, then chances are it's the switch.
MAXBEAR2334
  • 1997 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 106,778 MILES
The DashBoard lights are out on a 1997 Ford Explorer Sport 2 Door. I have looked at all the fuses and they are good. Which fuse controls the dashboard lights? How do I replace the Dash Board Lights?
Saturday, December 19th, 2020 AT 9:33 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
HI
If fuse #7 good then most likely faulty dimmer module left side dash. On module TERM 5 black/red wire should have voltage to power lamps. Do couristy lamps work?
Let me know
Thanks for donate
