Vehicle Revs Can't Go Beyond 3000
Vehicle Can't Go Beyond 3000 When You Accerarete
Siwila
MITSUBISHI PAJERO
Where Is The Water Pump Located?
I’m Needing Location Of Water Pump.
Welderchic
PONTIAC G6
After Replacing The IACV The Accelerator Sticks?
I Noticed One Day While Park Had The Defrost On The Vehicle Started Idling Down To Almost To Where It Shut Off, The Battery Light Came On...
SFC96-18
How To Fix Service Stability Message?
My Truck Runs Fine, But I Can Tell In The Brake Pedal That Something Isn’t Right And Then I Get A Notification On The Instrument Panel To...
Gallujef
CHEVROLET AVALANCHE
Fuel Pump Not Engaging After Engine Swap?
I've Changed Motors In My Vehicle Listed Above, I Have Run Into A Problem After The Exchange The Fuel Pump Doesn't Want To Engage....
Shane Crabtree
HYUNDAI AZERA
Boost Not Engage
Hi. I Had A Engine Swap. Old Was Scrapped. The Car Is Starting, Engine Sounds Good, Is Drivable But Boost Is Not Working At All. Sensor...
Speed1985
CHEVROLET CAPTIVA
Engine Cranks, Will Not Start?
I Try To Start My Car. It Turns Over Everything Works As It Should Except It Won’t Start.
Timothy Casso
Filling The Transmission Fluid?
Need To Know The Quantity Of Fluid And Where The Overflow Is Located To Remove To Know When It's Full Of Transmission Fluid. Not The Ss...
azdanno04
EPS Power Steering Not Working (with Power Steering...
Last Week I Had Both Front Tie Rods Were Replaced And Aligned. This Thursday, Upon Morning Start Up, The "service Power Steering"...
andreworleans
Engine Shut Off While Driving, Will Not Start?
Was Driving Down The Highway At 70 When The Engine Shut Off. Now All I Get Is A Click And Won't Turn Over At All. Shows Codes For All...
Jeremy13
AUDI A4
Brakes Lock Up After Changing Master Cylinder?
Changed Master Cylinder After Soft Brakes. The Problem Was Fixed And Tested Around The Auto Shop, And It Seemed Great. 15 Minutes Later On...
mazdaguy808
Wheel Making A Loud Popping Sound, Almost Like Popcorn...
I Noticed My Passenger Wheel Started Making A Popping Sound A Few Days Ago. The Sound Got Worse Overtime And I Replaced The Cv Joint, But...
Lunachris88
MITSUBISHI LANCER
Can A Remote Keyless Entry Be Added To This Truck?
Just Bought This Truck. It Has Power Door Locks And Windows But, Rpo Code Does Not Show Equipped With Remote Keyless Entry. Can I Add It?...
1JDTrader
CHEVROLET 1500
The A/C Does Not Come On, Clutch Does Not Engage?
A/c Pump Isn't Seized. Fuse 13 And 27 Good. Can't Find Relay Switch? If Not Relay What Else Should I Check And How?
mike decelle
TOYOTA AVALON
Codes C320, P030, P0172, P0175, And P0302, Hard Start...
My Truck Has A Rough Start, Idles Really Rough Stalls Out I Have Codes C3201, P0301, P0172, P0175, P0302. I've Changed The Spark...
Kelsey Allen
Puddle Of Oil Under A Car That Has Been Sitting For A...
The Car Has Been Broken Down For A While After Engine Fire. A Few Months After Fire In The Winter Went To Work On The Car After A Hard...
Jasonruth9
HYUNDAI ELANTRA
Vacuum Lines Diagram Needed?
I Recently Removed My Vacuum Lines For A Valve Cover Replacement And Did Not Make Them And Some Broke. I Need A Diagram For The Vacuum Lines...
Jawalker
Rear Driver Side Turn Signal And Stop Lights Are Not...
The Driver's Side Turn Signal And Stop Light Were Not Working. Got It Working Intermittently By Messing With Pigtail Connections. Fuses...
diesel360
Rear Brake Pad Replacement?
I Need To Change The Brake Pad But I'm Not Sure How To Drain Brake Fluid Because Of The Weird Shape Reservoir. Can't Suck It Out...
rwalbroehl
Code P301, Engine Light On And Misfiring?
Recently I Put In A New Alternator, New Ecm/pcm. I’ve Changed The Coils And Plugs Numerous Times, But My Engine Light Keeps Popping On...
JustBlessed
Transmission Not Shifting, Codes P1745, P0933, And...
The Transmission Is Not Shifting, And I Have A Few Codes Popped Up: P1745, P0933, P0869. What Needs To Be Done?
Kameel Halloul
22 IMAGES
Codes C3201, P0301, P0172, P0175, P0302?
My Truck Has A Rough Start, Idle Really Rough Stalls Out. I Have Codes C3201, P0301, P0172, P0175, P0302. I've Changed The Spark...
Kelsey Allen
How To Diagnose Cruise Control Issues And How To...
Hi, I'm Having Issues With My Cruise Control. I Was Able To Find The Most Common Reasons Why It Wouldn't Work Which Are "module...
Haley Young
Car Can't Start
When You Turn Ignition Switch On There Are No Lights On The Dash Board And The Bell The Key Is Ringing
Siwila
MITSUBISHI PAJERO
Car Can't Start
Siwila
MITSUBISHI PAJERO
689
690
691
