RAP Fuse Panel?
When I Have The Rap Panel Plugged In My Car It Does Not Turn Over And All Of My Gauges Like Gas, Prnd, And Stuff Also Quit Working. When I...
angelclark3788
A/C Will Not Turn On After Battery Was Disconnected?
Hi, The Other Day I Hit A Bump And My Whole Car Shuddered, So I Pulled Over And Checked Under The Hood And Noticed The Battery Had Come...
Sam Wagner
Tips To Change My Transmission?
I Need To Change The Transmission Of The Vehicle Listed Above Sxt. Is There Something Tips Or Not To Do Specific For That Vehicle? I Already...
gennyfurry
36 IMAGES
2020 Chrysler Pacifica Brake Isses
I Had My Rear Brakes Changed And The Person That Did It Did Not Program Them When He Finished. So When He Went For A Test Ride The Left...
tu_nene_jimmy
CHRYSLER PACIFICA
Shifter Locked And No Start?
Shifter Is Stuck In Park And The Lights Dim But The Starter Doesn't Respond When The Key Is Turned. A Beeper Sounds When The Key Is...
Seldomswift
JAGUAR S-TYPE
How Much Torque Is Applied To The Plates Presser Bolts...
I'm Replacing My Car's Clutch. My Question Is, How Much Torque Apply For Plates Presser Bolts And Bolts To Put Transmission And...
mmmmmttttt
CHEVROLET AVEO
Not Starting, Could It Be The Fuel Pump?
I Thought The Fuel Pump Went Out. Replaced The Fuel Pump, Pickup Still Won’t Start. I Am Getting Power To The Fuel Pump, Would Anything...
Brianlawrence00
CHEVROLET CHEYENNE
After Replacing The Transmission Fluid And Filter, The...
After Changing Transmission Fluid And Filter Truck Won't Come Out Of Park.
Mossman_62
Smoking Under The Hood And Got Extremely Loud?
My Car Keeps Smoking From Under The Hood, It Looks Like It's Coming From Somewhere Behind My Motor. My Car Got Extremely Loud Running...
Kimmy429
CHEVROLET LUMINA
Thin White Steam From Exhaust Even After Engine Is...
Hi I Just Bought A Used Charger. And I Noticed There Is Thin White Steam Coming From Exhaust Even After Engine Is Warmed Up And Its Clearly...
Amandeep789
Misfire And Fan Problem?
I Have A Code Come Up With Imbalance In Cylinder 1, But Have Been Told It's Not A Injector Or Cylinder Problem, And My Fan Problem Is...
Smudger smith
OPEL INSIGNIA
Over Heating
My Car Is Blowing Back Out Reservoir Currently Changed The Thermostat But With Original So Older One Had Nest In It And Pulled Thought All...
Tammy Parks
DODGE STRATUS
Overheating?
The Car Just Started Blowing Antifreeze Back Out Of The Reservoir. I Changed Thermostat But It Was The Original So Back To Older One Had A...
Tammy Parks
DODGE STRATUS
Aftermarket Stereo Installation Issue?
I Bought A Pioneer Sph-10bt Stereo To Put In My Car Listed Above, Which Does Have The Factory Amp, But It Does Not Have A Bose System. The...
kttkfam7
CADILLAC DEVILLE
Need Upstream O2 Sensor (bank2) Wiring Diagram?
The Connector For Upstream O2 Sensor (bank2) Was Cut Off Due To A Recent Accident. Can Someone Help Me With The Layout Of The Connector?...
habeebahm
Bad Abs (i Think)
Braking Pedal Effort Required To Stop Vehicle Is Excessive. "Check Engine" Light Is On. Dashboard Message Is 'abs Is Not Available"....
amfamble
JAGUAR XJ8
Engine Cranks But Does Not Start, There Is No Spark To...
I Was Driving The Car All Day, No Problems At All, The Car Has Always Started First Time Every Time. I Filled Up With Fuel, Parked It And...
CTAKIS
HOLDEN BARINA
A/C Compressor And Cooling Fan Not Working?
Cooling Fan Doesn’t Work, And A/c Compressor Doesn’t Engage.
marcel00s
BUICK CENTURY
Radio Wiring Diagram Needed?
I Need A Wire Diagram For My Car Stereo (stock). I Have The Car Listed Above With The Denso Dnns008 (gm 15263106) Stereo Cd Dvd Navigation...
CarlSP
22 IMAGES
Timing Belt Broke
Timing Belt Broke, We Replaced The Thermostat, Belt, Plugs And Wires But The Truck Loses Power In 4th And 5th Gear And Revs Really High...
Jamiegilliam06
MAZDA B2500
Code P0455, Slow To Start Intermittently Rough Initial...
Hello And Thank You For Your Time, My Vehicle Listed Above Is A Rough Start 75% Of The Time. I Will Get In It To Go Somewhere, And The...
El_Ogan
Car Makes A Single "Click" Sound When I Try To Crank...
Anytime I Attempt To Crank My Car It Makes A Single "click" Then It Makes Another Sound When I Release The Key. I Took The Starter...
rojoknight
After Replacing A Broken Timing Belt, The Engine Loses...
The Engine Losing Power In 4-5 Gear And Idles High When Clutch Is In, Just Replaced Broken Timing Belt.
Jamiegilliam06
MAZDA B2500
Car Makes A Single "Click" Sound When I Try To...
When I Try To Crank My Car It Makes A Single Click When I Try To Crank It And It Makes Another Sound When I Disengage It (i Have A Video If...
rojoknight
Replacing Transmission Fluid
I Am Wanting To Change The Transmission Fluid And Filter On My Car But I Am Having Trouble Trying To Find The "over Flow" Bolt". I'm...
Gooniefreak76
NISSAN MURANO
683
684
685
