Rear Brake Shoes Repalcement?
Putting New Brake Drums And Brake Shoes On Rear Of My Truck. It Came With Two-inch Brake Shoes I Put On 2.50 Brake Shoes. Now I'm...
Craig Aden
Will Not Start Unless It Is Jump Started?
I Had The Starter And Solenoid Checked And They Are Both Good. Replaced The Battery Because Of A Dead Cell In It And Still Cannot Start...
Brenda Mcgraw
No Brake Pedal Pressure?
I Replaced A Line From The Abs Block To The Rear Of The Truck And There Is Fluid In All The Calipers But No Pedal Pressure Or Brakes. I...
Jeff Herman
17 IMAGES
Smoking Out The Intake
I Went To Turn My Truck On It Made A Loud Pop And Started Smoking Out My Air Intake
JG12
Steering?
When You Speed Up A Bit- Wheel Jersey To One Side- When You Slow Down- Wheel Jersey To Other Side- Not Really Bad But Is Noticeable...
VicRuss64
NISSAN ROGUE
Code P0480, Radiator Fans Will Not Turn On?
Hello! I Am Having An Issue With My Truck Listed Above. The Radiator Fans Will Not Kick On And I Got An Error Code P0480. If I Did...
Gocussj5
Radiator Assembly?
I Am Having To Replace A Part On My Radiator And I'm Trying To Figure Out What That Part Is Called. It Looks Like A Rubber Cap At The...
hpena28
SATURN L300
Vehicle Vibrates/shakes?
The Vehicle Listed Above Is A Jrd Mocel. Served By Two Mechanics One A Jrd Mechanic From Japan. Codes Came Up For Ignition Coil And O2...
MasterGraff
NISSAN X-TRAIL
Code P41, Shuts Off While Driving?
Doesn’t Matter If I'm On A Hill, Or Not, On The Freeway Or Street, Driving Or Stopped At A Light, It’s Happened Everywhere. I...
RavensRamVan
DODGE VAN
Shut Off While Driving Would Not Restart?
Hi, How Are You All? Three Days Ago, It Shut Down On Me On The Highway. And Wouldn’t Start Back Up, It’ll Just Click Once. One Day...
Nhines10
A/C Vents Not Working Properly?
The Ac/heater Blows Just Fine, But Only Through The Defroster And Through The Back Vents Slightly But Not At All Through The Front Facing...
Tmartinez4
BUICK RENDEZVOUS
Engine Swap?
Will A 2015 Kia Optima 2.4 Gdi Engine For A 2011 Hyundai Sonata 2.4 Gdi?
Tgreen05
KIA OPTIMA
Throttle Body Issue?
Problem With Body Idle.
mfknqueenb
Shuts Off While Driving And Idling?
Replaced Fuel Pump And Still Doing It.
Houston.harper1996
Transmission Problem
99 Grand Caravan Sport, Replaced The Sensors And Boxes For The Tranny And It Still Will Not Fully Shift Into 2nd Or Reverse It's...
Mike Ryan2
Just Died
Just Died In The Driveway And The Starter Won’t Even Click. New Battery And Starter. Is Good. What Could It Be
Goldkey0070
When Shifting The Transmission Into Drive Or Reverse...
I Start It And Idles Fine. I Put It In Drive Or Reverse And The Jerk Is Very Hard. Then The Truck Shuts Off But Will Crank Right Back Up And...
Kenmo
Fog Light Wiring?
A Couple Weeks Ago I Ran Over A Piece Of Shredded Tire In The Road. It Flipped Up And Busted Out My Driver Side Fog Light (no Other Damage...
Brooklyn Hearn
Fog Light Wiring?
A Couple Of Weeks Ago I Ran Over A Piece Of Shredded Tire In The Road. It Flipped Up And Busted Out My Driver Side Fog Light (no Other...
Brooklyn Hearn
Brake Pedal Goes To Floor When Car Is Running?
Replaced All 4 Calipers, Master Cylinder And Power Booster. Bleed Brakes. With Car Off Good Pedal. Start The Car And Pedal Goes To Floor.
thetank
CHRYSLER LHS
Car Starts But Sputters And Shuts Off When Out In...
Changed The Spark Plugs Thinking It Could Be That, But The Issue Persists.
aquellaaaa
Crank No Start?
So, I Parked My Truck The Other Day And Went To Leave Again. It Hasn't Started Again Since. I Replaced The Crank Sensor, Fuel Pump...
Cure4Salvation
Will Not Start, Possible Security System Issue?
I Am Not Able To Start My Suv Listed Above (xl Model). I Think It Is The Security Lockout System. Nothing Happens When I Turn The Key....
WWLittle
Start-up Troubles?
Four Days Ago, I Went To Fire It Up, And The Battery Unexpectedly Drained. Dash And Radio Came On But Didn't Have Enough To Turn It...
ZMeyers86
DEF Heater Removal And Installation Instructions...
I Need Guidance On Removal Of Def Tank And Replacement Of The Def Heater.
pcbh
38 IMAGES
682
683
684
