Every Time I Accelerate The Gas A Yellow Light Comes...
I Just Bought This Car 1 Month Ago. No Problems Until Yesterday And Every Time I Accelerate The Gas A Yellow Light Comes On That Says "...
LittleFlower78
Will Not Start Just Whirring Noise No Cranking Or...
Will Go With A Jump Start Then Once Engines Off Won't Start Again. Replaced Battery Still Nothing. Dashboard Lights All On, Electrics...
emma.s
FIAT 500L
All Power Cuts Off, And Does Not Even Attempt To Start...
My Car Battery Had To Be Jumped About 4 Times In A 2-week Period. Then I Replaced The Radiator Without Getting A New Battery. When I Went...
kerilynn.kp
LEXUS ES 350
Codes P3401, P3417, And P3433?
For Starters My Wife And I Purchased This Car On Facebook Marketplace. I Know Not Smart But We Did It. I Was Told The Car Only Needed A Map...
Arronstout
Truck Kind Of Advances Forward At Stop Light?
As I'm Sitting At A Light At Times But Not Always. The Truck Kind Of Advances Forward A Tad. It Only Happens After About 45 Seconds. I...
Hidden4321
19 IMAGES
Howling Noise While Driving?
This Evening, My Aunt Called Me Telling Me Her Car Is Making A Howling Sound. I Went To Check It Out And Can See That When Driving, It...
Jason Fessenden
The Starter Will Not Crank The Motor?
The Starter Will Not Crank The Motor. With The Key In Start Position I Get Power To The Hot Terminal Of The Starter But Nothing At The...
Jim Donovan
Will Not Start, Possible Fuel Filter Issue?
My Car Won't Start, The Symptoms Sound Like My Fuel Filter Needs To Be Replaced. Autozone Told Me The Fuel Filter For My Car Is Non-...
Mickimarie Puntigam
HONDA CRV
New ECM, Need Key Programmed
I Just Had A New Ecm Put In My 93 Cadillac Fleetwood, But The Key Needs To Be Reprogrammed To The New Computer. Is There A Way For Me To Do...
Wade Jones III
CADILLAC FLEETWOOD
P0420, And P0456 Codes, Engine Idles Super Rough.
2010 Dodge Avenger Sxt 2.4l Engine Idling Rough, Smells Like Gas A Little Bit. The Engine Vibrates Really Had When Idling, It Did Have A...
Veri Docu
DODGE AVENGER
Where Is The Fuse For License Plate Lights Located?
I've Replaced The Bulbs And They Still Won't Work. Looked In Manual And There Isn't A Specific Fuse Stating It's For License...
Ddave71
CHEVROLET TRAX
License Plate Light Fuse Location
I've Replaced Bulbs And Still Don't Work So I Looked In Owners Manual For The Fuse Related To This And Can't Find The Exact Fuse...
Ddave71
CHEVROLET TRAX
Cylinder Heads Interchangeable/swap?
Waiting For The Rear Cylinder Head To Get Back From Machine Shop, I Finally Found Out It Is Cracked, And Not Usable. So, While Searching...
mrtoneg
Where Is The Fuel Pump Relay Located?
The Truck Will Crank But It Won't Start. Check The Fuse Already For The Fuel Pump. The Fuel Pump Seems Like It's Humming Only After...
Bear#15
NISSAN TITAN
Engine Intermittently Shuts Off And On, Electrical/...
Engine Intermittently Shuts Off And On And Sometimes Has To Be Restarted Going Down The Road.
Ezarc Foc
DODGE VAN
Transmission
How Do Adjust Shifter Cable
Rick777
CHEVROLET METRO
Electrical Short? Cross Wired?
Battery Dies Every Night, Have To Boost To Start Next Day, Cant Figure Out Where The Short Is.
bssntt4444
Transmission Goes Into Gear, But The Car Will Not Move...
Shifts Into All Gears But Car Won't Move, Clutch Seems Fine.
Rick777
CHEVROLET METRO
Where Is The Temperature Sensor Located?
I Need The Location Of The Coolant Temperature Sensor. Can You Please Give Some Pics So I Can Find It?
safelady
After Replacing The Sensors And Boxes For The...
The Van Listed Above Is The Sport Model With168,000 Miles. I Replaced The Sensors And Boxes For The Transmission, And It Still Will Not...
Mike Ryan2
Engine Will Not Crank Over?
It Just Goes Click Once And That's It.
juliesacre
Engine Shuts Off On Long Idle?
I Have This Problem With My Car. When I Drive It Without Stopping Much, The Car Can Keep Running For Hours On End. But After Some Hours...
Aku
VOLKSWAGEN POLO
Security Lock? Engine Will Not Turn Over?
Car Won’t Turn Over. I Replaced The Ignition Lock Switch. Went Through The Relearn Process No Luck. Next Replaced The Bcm Did The Relearn...
Kevin Bergemann
Starting Issue
Only Cranks With Gas Pedal To The Floor And It Sputters For A Bit Then Evens Out And Run Ok, But If It Has Sat Over Night Or For A Few Hours...
Daniel Gonzales
I Have Some Acceleration Issues On My Car I Think Fuel Filter Has Clogged, But I Can’t Find The Fuel Filter, So Anyone Please Help To...
Selva Priyan
KIA SEPHIA
681
682
683
