Why Does My Car Not Drive Strait/smoother?
So, For Weeks Now My Car Goes Mostly Left. Slightly. The Bumps I Hit Move My Wheel, So I Know I Needed Some Work Done. In The Past 2 Years...
Ernieg89
Does This Vehicle Have An EGR Vacuum Solenoid?
Does The Vehicle Listed Above W Vin Have An Egr Vacuum Solenoid And If So, Where Is The Location? P1404 Code Came Up I Have Replaced The...
jokytaki99661
Slave Cylinder Leak
The Line Where The Clutch Line Connects To The Slave Cylinder Leaks All The Lines Are New And The Slave Cylinder Is New But The Line Leaks...
Mnauel
MAZDA MX5
Surging Idle Between 500-800 RPMs?
Mostly On Cold Start And Worse With Any Climate Controls On. I’ve Replaced The Idle Air Control Valve And The Throttle Position Sensor. I...
Joeyjol75
TOYOTA AVALON
No Power To Low Pressure Switch?
All Fuses And Relays Good. Controls All Light Up, Three Wires At Pressure Switch. Checked Each With A Test Light None Lit It Up.
Roy Jr Martinez
Roy Jr Martinez
Power Steering Rack Replacement Instructions Needed?
I Have Already Dropped The Power Steering Rack And Lowered The Subframe For Clearance, But I Can't Figure Out How To Fish It Out. If I...
maverick0923
44 IMAGES
2011 To 2008 5.7 Engine Swap
I Have A 2011 Ram 2500 With A 5.7 I Replaced It With A 2008 5.7 Thinking It'd Work I Have A 2011 Ecu And 2009 Wiring Harness It Cranks...
CodyandJackie
2011 To 2008 5.7 Engine Swap?
I Have The Truck Listed Above. I Replaced The Engine With A 2008 Ram 5.7. I Have A 2009 Wiring Harness And A 2011 Ecu. The Ecu Will Let The...
CodyandJackie
Head Gasket?
This Car Has Been Sitting Since January. I Went Out And Pulled The Dipstick, The Oil Was Milky. In The Past When I Was Driving It At...
ahartley
OLDSMOBILE 88
Front Wheel Vibration?
I Have Play Where My Outer Tie Rod Connects To Hole Slot In Steering Knuckle. Assume Area Causing Vibration Feedback Through Steering Wheel...
Tfit
RAM 1500
Hazards, Turn, And Brake Fuses All Blow?
This Vehicle Has A New Painless Performance Wiring Harness. I Just Finished Installing It. I Just Found Out Though That The Fuses For The...
jdfreeman97
1980
JEEP CJ7
Codes P144A And P1450?
Codes P144a And P1450, What Do They Mean And How Do I Fix It?
No Crank, No Start, Shut Off While Driving?
I Left My House And Had Driven Approximately 7 Miles When All Of A Sudden, I Noticed The Tachometer Had Dropped To Zero Signaling To Me I...
Karmadiver
Fuel Tank
I Have A 1989 Honda Civic Dx Haych That Only Has A 3.6-4.2 Gallon Gas Tank. I Havent Replaced The Tank And Dont Think A Previous Owner Has...
esaNinja
Overheating?
When I Took My Water Pump Off To Replace It, I Smelled Gas Mixes In The Water That Was In The Water Pump Housing, Why?
Sher85driver
CHEVROLET VENTURE
ABS Warning Lights Error Code - Cc-id 207?
Error Code - Cc-id 207 Lights On Dash - Abs, Emergency Brake And Traction Control. Same Issue As - Https://www.2carpros.com/questions/...
amaan2121
BMW 325I
Transmission Codes P07A3, P2872, P144A, And P1450?
I May Be Getting A Cheap Deal On This Car Which Has Codes. Have You Ever Seen These Codes Before? P07a3 P2872 P144a P1450
Engine Overheating, Water Pump And Thermostat Were...
My Water Pump And Thermostat Were Just Replaced Due To It Leaking Coolant, But The Engine Was Not Overheating At This Time. After The Water...
Hemijay718
DODGE DURANGO
I Have The Cab Off My Truck. I Have The Starter Hooked To The Solenoid. I Have The Solenoid Hooked To The Battery And Have The Battery...
mr.thunderbolt
1976
FORD F-100
Shifter Seems To Get Locked In Park
I Need To Use A Flathead To Push In The Detaont Button In Order To Free The Gear Selector And Don't Know If It's Machanical Or...
Jstein1776
Update VIN In Occupant Classification Module?
I Purchased A Salvaged The Vehicle Listed Above And It Was Missing The Front Passenger Side Seat. Under The Seat Resides The Ocm (occupant...
Airwreckc
JEEP COMMANDER
Trailer Taillights Not Working?
The Left Rear Taillight Has Power But When I Put The Bulb In It Turns Off?
rich scott
Every Time I Accelerate The Gas A Yellow Light Comes...
I Just Bought This Car 1 Month Ago. No Problems Until Yesterday And Every Time I Accelerate The Gas A Yellow Light Comes On That Says "...
LittleFlower78
Will Not Start Just Whirring Noise No Cranking Or...
Will Go With A Jump Start Then Once Engines Off Won't Start Again. Replaced Battery Still Nothing. Dashboard Lights All On, Electrics...
emma.s
FIAT 500L
680
681
682
