Car Starts But It Will Shut Off At A Stop Light?
My Car Will Start And Run Fine Until I Come To A Stop Or A Red Light. If I Turn The Air Conditioner On It Will Roughly Idle And Won't...
Madianna25
MITSUBISHI ENDEAVOR
Can This Key Fob Be Programmed To My Vehicle?
My Car Came With Only 1 Key Fob, A Friend's Accord Like Mine Got Totaled And I Got One Of That Car's Key Fob, Question Is Can This...
JOL
Codes P2401 And P2099?
Had P0299 Show Up First Replaced The Diverter Valve Then P2401 Showed Up And It Started To Not Drive As Fast. What Could Be The Issue?
amandaoviedo94
AUDI A4
Runs But Doesn't Drive Loosening Pressure
I Can Get The Truck Started In The Engine Runs Kind Of Spiders A Little Bit And When You Push On The Gas More Than Just Barely It Will Die
RyanM1990
Abs Pump Module Replacement?
My Question Is, I Have To Install A New Abs Pump Module Because On My Left Rear Speed Sensor I’m Not Getting Ground From My Module When I...
Hilo tom
TOYOTA PRIUS
Shutting Off Randomly?
My Vehicle Has Had The Fuel Pump Replaced, Catalytic Converter, The O2 Sensor Changed, Spark Plugs, And The Computer System Board Under...
angela.scheel
NISSAN VERSA
Oil Level On Dipstick Reading Low?
I Have Now Encountered This Problem After Doing An Oil Change For The Second Time. After Driving 4,000km After My Full Synthetic Oil Change...
Hyundaiguy77
HYUNDAI SANTA FE
Car Will Not Start?
About 2 Weeks Ago, I Drove My Car To A Friend's House, And Everything Was Fine. When I Came Out Later On To Go To The Store, I Turned...
Roastabotch
MITSUBISHI GALANT
Windshield Wipers Act Strangely?
The Other Day It Was Raining But The Wipers Would Not Turn On. Later They Started Working On Their Own, But I Could Not Turn Them Off No...
moundtown
Brake Pedal Goes To Floor?
Recently Bought Truck That Sat For A Very Long Time. Owned By An Older Gentleman, Actual Miles Are Verified. Needed A New Fuel Filter And...
Leath
Completely Replacing The A/C System, How Much Tag Oil...
Completely Replacing My A/c System And Want To Know How Much Tag Oil I Need To Add To The Compressor And The Dryer. Can You Please Tell Me?...
michaelmaxwell420559
CHRYSLER PT CRUISER
Engine Stalling While Shifting Into Gear?
I Just Put In A Transmission That I Got From The Junkyard Into My Truck. It Was Driving Fine For A Couple Test Drives Then It Just Started...
Silverlife1
Brake Pedal Goes To The Floor?
I Replaced The Mater Cylnder Due To Having No Brake Pressure And After Replacement I Bleed The Brakes 4 Times To Make Sure All The Air Is...
e46kid
CV Axle Replacement?
So, I'm Trying To Replace My Cv Axle But There Is A Part I'm Seeing On Other Cv Axles That Mine Does Not Have, And I Am Trying To...
zlilleodden
CHEVROLET VOLT
Windshield Wipers Not Working, There Is A Clicking...
Whenever I Go To Use The Front Windshield Wipers No Windshield Wiper Fluid Comes Out And The Wipers Themselves Make This Horrible "...
wakingdd14
A/C Air Not Flowing Correctly?
I Was Having Problems With My A/c Only Blowing Through The Bottom Vents At The Feet. I Have Replaced All Actuators And Still Only Blows At...
Yeezus00
INFINITI G37
After Replacing The Brakes, The Brake Pedal Still Goes...
I Recently Replaced My Brake Calipers And The Pads And Today I Replaced The Master Cylinder. However, My Pedal Is Still Going To The Floor...
Melissa Acosta
JEEP PATRIOT
Left Rear Parking Lights Are Not Working?
The Left Rear Parking Lights Are Inop. I Request A Wiring Diagram. Thank You.
pmech
Grinding When Turning Left?
I Have The Truck Listed Above Lariat (non-heritage). This Is A Problem I Have Been Fighting For A While. I Get A Sound That Sounds Like...
JasonNailen
Shut Off While Driving And Will Not Start?
I Was Driving To The Store And Got About A Half Mile From My House And The Car Quit Running. It'll Turn Over But Will Not Start Back Up...
TonyCG72
SATURN ION
Front Driver Side Tire Hard To Spin, Bearing Hub?
The Front Driver Side Wheel Is To Spin When The Vehicle Is Off Ground. Replaced Caliper, Rotor And Brake Pads And It Still Hard To Spin By...
chrisbuckley110
Strange Metal Grinding/rattling Noise While Driving?
While I Am Driving And Only Accelerating Above 50 Mph, There's A Metal Rattling/grinding Noise That's Loud And Lasts About 3...
illeromm
Do You Have An Engine Replacement Video?
Faulty Engine And I Was Wondering If You Have A Video Showing The Replacement Of Engine. Thank You
Monty Poonia
NISSAN NAVARA
Code 82, No Spark?
Brand New Distributor. Brand New Coil. But I Cannot Get An Rpm Signal To The Ecm. Tried Also Replacing Ignition Control Module And Still No...
William Jarman
GMC TRUCK
Ticking Sound After Engine Has Warmed?
A Tick Like Dead Cylinder Tick. Good Compression, Getting Fuel, Spark Plug Wires Work, Plugs Look Good, No Codes, No Exhaust Leaks. It...
Cowboycadi
CADILLAC ESCALADE EXT
656
657
658
