Replacing Two Belts
I Can't Access The Nut On The Tensioner Pulley. The Space Is Too Small For A Regular Serpentine Belt Replacement Kit. Would A Zero Off...
wishicouldfixmycar
A/C Blend Door Actuator New Replacement Does Not Move?
I Have Cold Air Passenger Side Heat Drivers' Side So As I Saw On U-tube Ordered Blend Door Actuator. Hooked It Up And The Center That...
Dale Putman
BUICK LESABRE
A/C Intermittently Blowing Hot Air?
The A/c Get Cold After Hot Intermittently Even On The Freeway. What Can Be The Causes?
Yazidan
Transmission Not Shifting Properly?
Hello, My Car My Car Either Goes In Reverse But Not Drive And Vice Versa. The Battery Light Comes On And My Car Doesn't Shift Into 3rd...
Gbergeron
ACURA TL
Step By Step Process For Changing Transmission Fluid...
I Don't Know What Steps To Take To Change The Transmission Fluid. I Know Some Vehicles You Have To Leave It In Neutral And Flat Level...
ervinjames2428
Fuse Box Diagram Needed?
Some Fuses Are Missing In The Fuse Box. I Could Not Find Diagram In Owner's Manual. Looking For Diagram For Under The Hood And Under The...
Steveo416
VOLKSWAGEN JETTA
This Car Has Been Sitting For Six Years, Will Not...
The Car Has A 3.4 V6. It Has Been Sitting For About 6 Years. I Replaced The Fuel Pump And Filter And Gas. It Is Getting About 45 Psi On...
Camc61
PONTIAC FIREBIRD
Replacing Sway Bar Links?
Being Told That Replacing 1 Sway Bar Link Is Safe To Do. I Don't Think It's Safe To Just Change One Side. Could Someone Let Me Know...
Jones Tiffany
FORD FIVE HUNDRED
Code P048013, Fan Not Turning On?
My Coolant Fan Does Not Work. I Have Got Code P048013: The Output Of Electric Fan 1 Has An Electrical Fault Or An Open Circuit. There Is An...
Shuker1
MERCEDES BENZ ML350
Engine Swap?
I Have A 5.3 All-wheel Drive Where The Seats Motor, I'm Trying To Do An Engine Swap On It I Have Right Here A 5.3 Rear Wheel Drive Is...
Larry Nason
DODGE MAGNUM
Ignition Switch Problems?
When I Turn The Key To Start The Vehicle Starts Right Up, As Soon As I Release The Key It Dies. I Have Kept It Running By Holding The Key...
puzrock
Where Are The Headlights Located?
It's Not Really A Problem But I'm Trying To Find Where All The Lights For My Vehicle Listed Above. I Would Like To Know Where All My...
Arthur Miller Jr
OLDSMOBILE BRAVADA
A/c
The Fan Isn’t Spinning At All, I’ve Looked At Fuses Associated To It And I Just Can’t Figure The Problem Out.
Isaac Paredes
KIA RONDO
A/c
Isaac Paredes
KIA RONDO
A/c
Isaac Paredes
KIA RONDO
Where Is The Low Side For The A/C Trying To Make It...
Trying To Make It Blow Cold Air?
tyreacehouse1988
Will Not Stay Running On Its Own?
I Have Changed Throttle Body, Map, Crankshaft Position Sensor, Camshaft Position Sensor, Idle Control Sensor, Tps Sensor Temperature...
Charlani
JEEP LIBERTY
Relay To Solder In I Would Like To Bypass?
I've Pulled Out My Fuse Box And Identified Relay 302 As Being Bad. This Relay Is Intergraded Into The Central Junction Box/fuse Box And...
vernon3281
A/C Vent Will Not Switch To Front To Blow Air?
A/c Vent Does Not Switch To Front To Blow Air.
Demetrice24
The A/C Compress Clutch Stopped Working?
I Have The Truck Listed Above Z71. The A/c Light On The Control Indicates A/c Is On. I Can Bypass The Relay And The Clutch Engages, Now I...
whtwuzthat
What Are The Cylinder Head Torque Specs?
Need To Know Torque On Bolts To Head.
hepp5856
KIA SPECTRA
Unhooked Wires From Passenger Seat Airbag?
I Accidentally Unplugged The 2 Wires With Metal Pieces On The Ends That Slide Into The Yellow Airbag Port Under The Passenger Seat. The...
Mike Harper
HONDA CRV
Car Starts But It Will Shut Off At A Stop Light?
My Car Will Start And Run Fine Until I Come To A Stop Or A Red Light. If I Turn The Air Conditioner On It Will Roughly Idle And Won't...
Madianna25
MITSUBISHI ENDEAVOR
Can This Key Fob Be Programmed To My Vehicle?
My Car Came With Only 1 Key Fob, A Friend's Accord Like Mine Got Totaled And I Got One Of That Car's Key Fob, Question Is Can This...
JOL
Codes P2401 And P2099?
Had P0299 Show Up First Replaced The Diverter Valve Then P2401 Showed Up And It Started To Not Drive As Fast. What Could Be The Issue?
amandaoviedo94
AUDI A4
655
656
657
