Replaced The Starter Six Times In The Last Month, What...
In The Last Month I Have Had 6 Starters Go Out On Me. The First One (the Original) When We Took The Starter Apart Looked Like An Internal...
alimichelle90
Crank No Start Issue?
Battery Fully Charged. Hot Blue Spark In At Least One Cylinder. Have Not Checked Noid Light Injector Pulse. The Fuel Pump Runs And When...
Jeff Herman
25 IMAGES
HONDA CRV
Wiring
I Have A Short Somewhere That Is Affecting The A/c, Torque Converter, And The Battery. Do You Know Where I Need To Start Looking?
Melissa Acosta
Immobilizer/PCM/SSU Incodes?
I Am Repairing The Car Listed Above For A Customer Who Replaced Their Pcm, But I Am Running Into Issues With Sourcing Incodes For The Pcm...
Nicole's Auto
Squeals When Push The Gas Stops When I Let Off Gas
Acceleration Causes A Squeal Getting Louder As Igo Faster Completely Stopping When I Let Off Of The Gas Pedal. I've Already Checked The...
Melanie Dickerson Lyman
AC Pressure Sensor Location(s) On 2015 GMC Acadia
Cool Air Blows When Ac Is On But Not Colder Than 73deg (@73, Its Not Necessarily 'warm' Though Either.) Low Side Pressure Is 80...
Petrock
GMC ACADIA
Codes P0011, P0016, P0089, P2138 And P228D, Could This...
My Car Is Set Up For English Or French Only. I Was Driving And, On My Dash, German Came Up Then Back To English. The Next Day I Had A...
Doug Byers
Power Window Issue?
Front Passenger Side Window. The Window Goes Up And Down But Tilts. I Have The Door Panel Off And Don't Really See Anything Wrong Or Any...
bw74
BUICK REGAL
Fog Lights
Need To Wire In Oem Fog Lights
Jacob Duran
KIA SPECTRA
Where Is The Fuel Filter Location?
Changed The Fuel Pump In My Car, But I Can’t Find The Fuel Filter, Not Sure If It’s Underneath The Vehicle Or In The Fuel Tank.
Eric Meraz
Turbo Sounds Different ?
The Turbo Spool Has Sounded Different As Of Yesterday, I Noticed The Sound Not Doing The Normal “stu Stu” It Still Does It But It...
Camren Bolch
TOYOTA SUPRA
Turbo Sounds Different Than Normal
So I Noticed Yesterday That My Turbo Doesn’t Sound The Same As It Did Before, Like It Still Mildly Does The Stu Stu We All Know And Love...
Camren Bolch
TOYOTA SUPRA
White Smoke Coming From Left Side Exhaust?
About A Year Ago, Little Girl, Which Is The Car's Name, Started Not Starting. I Could Get Her To Go But As Soon As I Put Her In Drive...
Cara L Liesse
MERCURY COUGAR
Lost Key?
Lost The Key Need To Bypass It Where It Will Start.
Kendralynn
Code P0016 Engine Light?
The Car Runs Absolutely Perfectly. Starts Right Up, Idles Fine, And Makes No Noise. I Changed The Vvt Solenoid And The Cam Sensor Because...
daskurky
I Dropped Something Very Important Into The Handbrake...
Anyway, I'm Able To Retrieve The Item? Or Would It Have Dropped Out The Car? Can I Take The Cover Off Somehow?
Lonewolff
SCION TC
Transmission Will Not Shift Into Gear?
Started With Having To Put It Back In Park Several Times Before Going Into Gear. Now It Won't Go Into Gear At All. My Friend Has A...
Mike wunder
KIA FORTE
Acceleration And Fuel Issues?
A Few Weeks Ago, I Had An Oil Change And A/c Check From A Garage. They Spewed A/c Refrigerant Everywhere From A Broken Line Somewhere. Not...
starrgazer2
NISSAN FRONTIER
Where Is The Camshaft Position Sensor Located?
Please Where Is Camshaft Position Sensor Location On The Vehicle Listed Above G05 M50i N63b44d?
garry75
BMW M50
Wipers And Blinkers
My Wipers Don’t Work And My Blinkers Work But Only If I Mess With The Switch And Get It Right But It Don’t Stay On I Have To Keep...
rosalov
Car Will Not Start, No Error Code Shown?
Hello, My English Is Not Very Good, And I Hope I'll Be As Clear As Possible. I Bought A Car In February From A Secondhand Car Shop...
nasaiuh
The Front Left Caliper Is Scraping Tire Rim?
What Is Causing This Problem? Drive Train.
Charles Ewart
Squeal Noise After Running The A/C And Turning Off The...
When I Drive And Run My Air Conditioner And Stop And Cut The Engine Off I'll Hear A Squealing Kind Of Noise After The Vehicle Is Off...
chris001
Replacing Two Belts
I Can't Access The Nut On The Tensioner Pulley. The Space Is Too Small For A Regular Serpentine Belt Replacement Kit. Would A Zero Off...
wishicouldfixmycar
654
655
656
