Only Starts With Starter Fluid?
It Will Only Start If I Spray Starter Fluid In The Filter Box And Will Run Until Ether Is Burned Off And Other Times Will Stay Idling. I...
Darell Morrison
BMW 325I
Overheating?
The Car Listed Above Has A 2.0. Car Will Idle For 30-45 Minutes Before Overheating. When Driving, Car Will Overheat With 2-10 Miles. I...
dylanfrank
VOLKSWAGEN JETTA
Security Lock Light Steady On?
So Here We Go Haha, I Got Out Of My Truck The Other Night After Driving It, Then Got In It The Next Morning To Start Her Up And Nothing....
sinisterfivethree
20 IMAGES
A/C Does Not Blow Cold Air?
I'm Looking To Diagnose The Exact A/c Issue (at Least As Much As Possible Or Hear What To Do Next) With My Vehicle Listed Above Ex Model...
markryd
HONDA ODYSSEY
Vapor Lock Issues?
I Think I'm Having Some Vapor Lock Issues, And Was Wondering If You Could Help Me With A Fix? Truck Runs Great, But Lately, As The...
twebb101
1984
Most Dash Lights Are On And Speedometer Not Working?
So, I Just Changed The Radiator Fan And Shortly After Most Of My Dash Lights Came On And The Speedometer Wasn't Working. I Did The...
Meli Lynn
Front Shocks, What The Torque Spec On The Top Tendon...
I Need To Know What The Torque Spec On The Top Tendon And The 2 Bottoms Are. Thanks
Dan Oates
Done Light And Tadio
I Turned On The Dome Light. It Went Out And The Radio Stop Working.
tbull06
Does Not Start After Replacing The Timing Chain?
I Installed A Timing Chain. Afterward It Won't Start.
Michael Gonyou
Accelerating Hesitation?
Hi, While I Press The Gas Pedal There Is No Immediate Response Of Acceleration Increasing. After Keeping Press Pedal Sudden High...
khaliddvd
HYUNDAI TUCSON
How Can I Get It Out Of Antitheft Mode With No Key Fob...
Hello! So, My Wife Grabbed My Truck Key Instead Of The Murano Key And Stuck It In The Ignition And It Triggered The Antitheft System And...
MTLewis086
NISSAN MURANO
Transmission Not Shifting Into 3rd Properly
I Just Had A New Rebuilt Engine Installed. Afterwards It Would Shift Properly From 1st To 2nd But As I Continued To Accelerate It Would Not...
jamesdalbright
TOYOTA PICKUP
Power Steering Becomes Stiff And Sometimes The Engine...
My Car Right P/s On The Dashboard And The Steering Becomes Stiff And Sometimes The Engine Cuts Off Immediately. But That P/s Sign Won't...
Victor Gambiza
Brake Warning Light Stays On After Replacing Brake...
My Brake Warning Light Came On, So I Got The Pads And Rotors Replaced But The Light Is Still On And Won’t Turn Off. Fluid Is Also Full.
Crypticxcat
FORD C-MAX
Tapping Noise?
I Have Replaced All Pulleys, Water Pump, And Timing Belt, Etc. Noise Is Still There Even Louder, I Took Off Serpentine Belt And Noise...
mrbones057
HVAC No Air Coming At Any Blower Speed?
How Can I Tell If It's The Resistor Or The Blower Itself?
18 IMAGES
VOLVO S80
Where Is The Temperature Coolant Sensor Located?
Replacing Temperature Coolant Sensor. Removed Wiper Assembly, Braces, Cannot Find This! Terribly Frustrated. Can You Send Me A Pic Of...
debracook20
CADILLAC ATS
Side View Mirror, Switch Not Working?
The Side View Mirror Switch Located On The Driver Door Handle Does Not Work. I Have To Manually Adjust The Side View Mirrors.
lvargas
HUMMER H3
Code P0303, Misfire?
Got A P0303 Code, So Far, I Have Changed The Coil, Plugs, Plug Wires. Ran Fine After Sat For A Day Started Up And Threw The P0303 Code...
Djmeatman
JEEP WRANGLER
Grinding Noise When Starting Car?
Yes, It's Warm Weather So It's Not From The Cold. For The Past Month Or So, Sometimes When I Start The Car It Makes A Grinding...
ballen7
Will Crank And Slow To Start?
The Car Will Crank Just Fine, But It's Slow To Start. Once The Car Starts, There's A Bit Of Hesitation On Acceleration. One...
Tiankhy
18 IMAGES
CHRYSLER PACIFICA
ABS
Mercedes Sl550 Abs No Esp Connection
Swopat88
MERCEDES BENZ GL550
Codes P0717 And P0301, How To Fix It?
My Car Has A P0717 And A P0301 Code. I Replaced The Tcm Valve Body And The Output Speed Sensor. I'm Still Getting The P0717 Code And The...
cyphertc
Engine Stutters?
I Have A 2015 Vw Gti Autobahn. For A Week Now, The Car Stutters On Heavy Acceleration. This Happens Regardless Of Whether The Engine Is...
kkapes
VOLKSWAGEN GTI
Replacement Engine Cranks But Does Not Start?
Replaced Engine, The New Engine Will Not Crank Over, Power Tests Good At Starter But Don’t Have Anything On The Excite Wire. If I Supply...
Ollie224
644
645
646
