Codes P0339, P1298, And P0141, Long Start And Limp...
Turn The Key Fuel Pump Hums, Psi Is Above 40 Crank Delays And Then Runs. Replaced Crank And Cam Sensors Checked Wires From Sensors To Ecm...
Eton250
Nearly Positive It's A Clogged Fuel Filter, Just Had Complete Tune Up And Distributor Cap Replacement. Low Miles And Nothing Were Wrong...
Melinda Chaperlo
CHRYSLER SEBRING
The Clutch Line Keeps Popping Out Of The Transmission?
So, I Replaced It, But It Still Pops Out.
kygator7
Rear Differential, Is The Friction Reducer Required...
Is The Friction Reducer Required For My Truck? (Limited Slip)
Morganizer032
Engine No Start After Warm, Always Tough To Start?
Mostly The Engine Has Difficulty Starting. The Engine Won't Stay Running More Than A Minute Or Two. Then After Warm Engine The Engine...
Brent Brandon Rios
NISSAN FRONTIER
Manual Shift Cable Replacement/swap?
The Car Listed Above Is A Zx4 S Model. The Manual Shift Cable Broke At The Transmission, But The Part Is Discontinued For That Year. Would...
Amccain93
After Replacing The Brake Pads And Rotors, There Is A...
The Dealer Told Me It Was Time To Replace The Back Pads And Rotors. Went To Tires Plus And They Replaced The Back Rotors And Pads. There Was...
PHIL382948
Spark Plug Stripped?
I Am Doing A Tune Up On A Truck I Recently Bought. While Changing Out The Plugs And Coils I Am Having Issues With The Infamous Back...
Zedd04
Overheating
Due To Too Much Pressure Build Up In Cooling System
codey
CADILLAC DEVILLE
Wiring Harness Swap, For Heated/memory Seats?
We’re Trying To Retrofit A 2004 Tahoe Power Passenger Seat Into The Truck Listed Above. Bolts Up Fine As We Were Advised It Would, But...
Joe Fox
Ground Wiring And The Positive Wiring?
I Just Got Done Putting The Transmission Housing Back On And The Sensors Etc, But Towards The End When I Put The Starter Back In And...
azdanno04
Ignition Locking Cylinder?
Okay, Somebody Else Started Working On The Car But I Had To Finish It. Everything Went Well, But I Have 5 Wires That Go Into A Connector...
Kylebernstein
Wire Can I Tap Into To Provide Dimmable Lighting?
Hey Guys, I've Added The P9we4 Fold Warriors And Dic Mod To My Truck With The Oem Switches And Wiring Harness Out Of The 2002 Escalade...
Merkum901
CADILLAC ESCALADE
Parking Assistant, No Power?
Any Idea How I Should Approach The Upra System Not Having Any Power? I Shorted The Connector Under The Rear Seat To Put It In Diagnostic...
Merkum901
CADILLAC ESCALADE
Codes P0300, P0131, P0151, P1870, P0102, Will Not...
Truck Won't Start Or Will Stall Out After Start Or Giving It Throttle. Fuel Pressure Reads At 45 On Ignition Then Drops To 20. Replaced...
Danny Ledesma
No Crank, No Start, No Click, Nothing?
Around A Few Weeks Before This Happened, I Noticed A Delay Of A Couple Seconds From When I Turned The Key All The Way Over To The Time It...
marones916
No Spark, I Recently Changed The Timing And The Oil...
I Recently Changed The Timing And The Oil Pump And When I Got It All Back Together It Won't Start. It Cranks But No Start. I Changed The...
Billy Webster
How To Remove The Front Drive Shaft?
Changing Oxygen Sensors. Could I Get A Complete Guide On Changing All The Oxygen Sensors?
Mossman_62
Erratic Fuel Gauge?
It Would Jump From Reading Full, To Reading Empty, To Reading Correct. Most Of The Time It Read Empty. The Truck Ran Fine In Spite Of...
DGunn427
Crank No Start Issue?
My Van Has Run Perfectly Fine For The Past Few Days With The Only Minor Hiccup Being The Power Sometimes Cutting When I Try To Start It But...
DTClark
CHEVROLET EXPRESS
Cooling System Thermostat Housing?
I'm Trying To Remove The Multi Way Control Valve And After Removal Of Visible Bolts I Still Can't Seem To Wiggle It Free Of The...
MatthewJon
NISSAN TITAN
Cruise Control Fluctuates?
Once I Set My Cruise Control, Instead Of Staying At The Speed I Set It At It Fluctuates Up To 5-7 Miles Faster / Slower. Cruise Control Is...
Cwhite73
KIA SOUL
A/C Evaporator Core, Where Is It Located?
I Was Told I Have A Leak In My A/c Coil And An Estimate Of $1,600. I Have Researched And Everything I Found Says No Repair. So, I Wanted To...
Jjones72
TOYOTA AVALON
Engine Will Not Crank?
3500 Cummings 24 Valve Turbo Diesel. I Went Out To Go To Work Turned Key And Truck Turned Over Slow Like Drained Battery, Tried Again...
Brian st clair
Engine Noise?
Ever Heard This From A 6.4l Hemi Motor? Only Has 60,000 And Is Offered For Sale Dirt Cheap, But For Reason. Do These Have The Same Issues...
645
646
647
