Fuel Pump
I Got A New Fuel Pump For My 99 Gmc Yukon And The Electrical Plug Is Different. What Is The Schematic For The Four Pens In The New Plug...
Threethumbsone
Air Conditioner Only Works On Defrost?
I’m Replacing My Electrical Blend Door Actuator And Have It Taken Out. Right Now, The Only Way The A/c Will Work Is If The Switch On The...
Branstep653
Car
Went Down The Road And The Collier Pin From Clutch Pedal Came Out How To Fix It On My 2003 Honda Accord Ex
Kittykat87
Will Not Start After Running Out Of Gas?
I Was Driving While Not Paying Attention To My Gas Gauge And I Ran Out Of Gas. My Car Would Not Start After That, And I Replaced The Fuel...
44lopezm44
DODGE INTREPID
Coolant Bubbles / Boiling?
The Vehicle Listed Above Is An Stx, V6. Occasional Coolant Reservoir Overflow After Replacing Reservoir And Coolant Hose "t"...
rhartma4
DODGE JOURNEY
The Radiator Fans Stopped Working, A/C Does Not Engage...
I Have The Car Listed Above And My Radiator Fans Stopped Working. So, I Replaced Them And They Still Don’t Work. Neither When I’m...
torumalex7
PONTIAC G6
Battery Negative Or Positive Ground?
I'm Trying To Rewire The Battery On This Car And Would Like To Know Which Post Is Grounded.
Eridian
Replacing The Shocks For More Comfort?
The Truck Listed Above Is A K1500, Original Owner. This Truck Is All Original (stock). 4 Shocks In Front. Lumber Rack And Stock Heavy? Duty...
Randy Dresdner
1984
Where Is The Transmission Control Module Located?
Transmission Losing Connection To The Transmission Control Module. I Was Trying To Locate It So I Can Inspect The Connector And Wires To...
Stretchglobal
Clutch Pedal Goes To The Floor?
My Clutch Pedal Is Going All The Way To The Floor, And I Have To Fill Fluids Up At Least Three Times A Day, Especially In The Morning. My...
Diane42273
GMC CANYON
Injectors Have No Pulse, Not Getting Power To...
A Mechanic Put It On A Scanner, And It Got An Injector Code. I Changed The Injectors And Put New Ones In, But They Are Not Getting Any...
K Calderoni
CHEVROLET AVALANCHE
Serpentine Belt
Belt Sizes Bought A Belt At 76 Inches But Too Short
Williamlyons420
LINCOLN CONTINENTAL
Check Engine Light, Tractions Control, Codes
I Have A Dodge Journey, 2016. It Occasionally Stalls When I First Start It. More Often, When I'm In Reverse But Occasionally While In...
Vgoble83
DODGE JOURNEY
Radio And Touchscreen Not Working?
My Radio Doesn’t Work, I Can’t Hear Music, Just A Black Screen, It Turns On And Off To The Welcome Screen But That’s It. Do You...
Alex2004789
VOLKSWAGEN PASSAT
Check Charging System Message?
I Had To Redo Timing The Motor And Transmission Is A 2010. Replaced Timing Components With Ford Components From Dealership Since Timing Has...
happymimi5
After Replacing The Brakes And Rotors When Applying...
Changed Front Disc Brakes And Rotors. I Replaced The Rotors Twice. When I Apply The Brake Lightly From The Front End I Feel Vibration, The...
Chase156
NISSAN FRONTIER
How To Check If The Motor Mounts Are Bad?
When Starting There Is A Thump Coming From Under The Driver's Seat Or Maybe Just In General Under The Car. It Also Happens When I Turn...
Phillip Flores
HONDA S2000
Died While Driving. Cranks But Won't Start.
It Is Under Warranty. Towed Ho Dealership. Replaced The Battrry With The Same Outcome. Thought It Was The Alternator. Dealership Says It Is...
Vickie Ritchson
When I Turn The Key In The Ignition, I Get Zero...
Hello, So, I Have Not Turned The Car On For Maybe A Month And I Decided To Turn On The Car Today, But It Wouldn't Work. When I...
devsheth
I Need A Wiring Diagram For The Mass Air Flow Sensor...
The Plastic Connector Broke And I Purchased A New One. Now I Need Where To Place The Four Wires.
jkm091951
BMW 325I
Left Turn Signal Does Not Blink?
Left Turn Signal Not Working.
DK Newby
FORD EXPLORER SPORT TRAC
Transmission Output Shaft Seal Replacement?
I’m Replacing The Output Shaft Seal While Replacing The Cv Axle. There Is A Spring In The Seal, And I Need To Know Does The Side The...
Jason Spagnolia
TOYOTA SIENNA
Changed The Starter An Bought New Battery It Will...
Changed The Starter An Battery Checked The Alternator All Good But Still Clicks Line The Starter Not Good I Keep Clicking It An Eventually...
David cedillo
OLDSMOBILE ALERO
After Replacing The Water Pump, Head Gasket, And...
I Got My Head Gasket, Water Pump And Timing Chain Replaced, And My Car Will Not Start Now. It Will Crank But Won’t Turn Over. I Tried...
2010-Ford-Taurus-SHO
Foot Pedal For Parking Brake Goes To The Floor With No...
Adjusted Both Adjusters Same. Give Little Gas And Car Moves And Slowly Moves On Hill. Lu Changed The Brake Pad In Drum. Changed The Right...
darrall
CADILLAC ESCALADE
614
615
616
