I Turn The Alarm Off, And Now The Anti-theft Light Is...
The Vehicle Listed Above Is An Ex-l. I Left My Son In My Vehicle; I Did Not Lock It But Since I Took The Key I'm Assuming After A While...
Ebony JHarris
HONDA PILOT
Shut Off While Driving And Will Not Restart?
No Power To Plugs, Will Crank Wont Start. Shut Off While Driving. Checked Every Fuse.
Jason Sjolund
MITSUBISHI ECLIPSE
Diagrams Of All Of My Vacuum Hose Routings Needed?
Okay, So, I Figured Out What I Need Help With I'm Needing A Diagram That Shows Me All Of My Vacuum Hose Routings And Also One Showing...
Leyna07830
CADILLAC CTS
Labeled Diagram
Ok So I'm Now Noticing That I Seem To Have Hoses Not Connected So If I Could Get Help With A Diagram That Shows All Connectors And Hoses...
Leyna07830
CADILLAC CTS
Auto Headlights Warning Showing Headlights Flashing...
When Auto Headlights I Get A Warning Showing Headlights Flashing And A Beeping, All Lights Are Working Fine Though.
Stacy Schuth-Kreisher
KIA SPORTAGE
I Replaced The Crankshaft Position Sensor But It...
Not Long Enough To Actually Go Anywhere And Extremely Rough. If I Put The Old One Back In It Will Run. The Reason I Am Replacing It Is As...
Cgarske
Where Is The A/C Expansion Valve Located?
Ac Expansion Valve Location Needed.
stonesouls
PONTIAC VIBE
Brake Calipers Locking Up?
Brake Caliper Locking Up, Then Releases After Sitting For About Twenty Minutes.
Commanders
TOYOTA AVALON
Check Engine Light Code P0117, Engine Overheating?
It All Started With A Leaking Water Out Flange… -removed And Noticed Gasket And Housing Had Failed. Replaced And Filled With Coolant....
PedroV
CEL Code P0117, Engine Overheating
So It All Started With A Coolant Leak. -water Outlet Flange Had Failed Along With Gasket. Replaced Part With New Gasket And Sensor Included...
Pedro91
Fuel Cutoff Inertia Switch Or Connection To Fuel Pump
I Have Been Having Issues With Fuel Cutoff Inertia Switch Locate On Firewall On Passenger Side I Drive More Than 20 Miles And The Switch...
Mic Pilgrim
Engine Overheating, CEL Code P0117
So It All Started With A Coolant Leak On Water Outlet Housing, -removed It And Saw That The Gasket Had Ruptured And The Plastic Housing...
Pedro91
Brake Repair?
How Do You Get The Hourse Clip Off And Install New One
John Young2
Codes P0762 And P0700, Transmission/reverse?
My Vehicle Listed Above Had Had Its Transmission Replaced. The Guy Who Replaced It Did Not Connect Transmission Lines Near The Radiator Very...
Angie Hartsock
CADILLAC SRX
Vehicle Lacks Power And Blows Black Smoke?
Upon Rapid Acceleration The Vehicle Blows Black Smoke Until The Throttle Is Let Off. Initially The Rpms Jump About 1000 So I'm Assuming...
Jeff Herman
VOLKSWAGEN JETTA
Check Engine Code P0171?
I Started To Clean The Maf Sensor And When I Unplugged It There Was What Looked Like Oil In The Connection And Was Wanting To Find Out If...
Scarpenter85
Engine Cranks But Does Not Start, And Multiple Codes?
I'm Getting These P Errors: P0010, P0013, P0020, P0102, P0113, P0118, P0121, P0123, P0338, P0343, P0348, P0368, P0393...
Berrou
TOYOTA SEQUOIA
Electrical Issues?
I Just Purchased The Vehicle Listed Above, Titanium Edition, From The Dealership A Few Days Ago. I Bought It Knowing That It Had A Few...
Eric1400
Antifreeze Leak
Okay So I've Got A 2002 Dodge Ram 1500 5.9 L And I Believe It's Overheating Because It's Losing Fluid Out Of The Water Pump? It...
Jeep769
Camshaft Drive Gear?
Can't Find One.
chefdave 855g6
Nothing Happens When I Turn The Key?
Got In Car A Week Ago Turn The Key Nothing Happened. Two Days Ago, The Security Light Came On, Now Nothing. Where Do I Start? I Got New...
jtemple105
PONTIAC G6
Will Not Start, Where Is The Back-up Neutral Switch...
We Have Installed A New Computer, Synced New Keys, Run Diagnostics And The Car Still Will Not Start. We Think It Might Need A New Back-up...
Mwestfall1
LINCOLN NAVIGATOR
Will Not Start?
I Bought The Vehicle Listed Above That Was Sitting For 3-4 Years. Thought It Wouldn't Run Because Of The Fuel Pump. So, I Replaced It...
Kyrockdad
MERCEDES BENZ 190E
Need A Guide To Help Me Figure Out Why The Vehicle...
If You Could Please Help Me With A Repair Manual.
Leyna07830
CADILLAC CTS
Lost The Lug Nut Key?
I've Got Locking Lug Nuts And I Can't For The Life Of Me Find A Key To Fit It. Hoping You Can Help Me Figure Out Which Key Will Work...
Jenn VanHooser
MERCURY GRAND MARQUIS
615
616
617
