Squealing Noise Possible Bad Alternator, A/C...
Can't Seem To Catch A Break On My Vehicle Listed Above, Recently I Had To Replace The Timing Belt And Water Pump, I Replaced The...
siennawise
21 IMAGES
TOYOTA SIENNA
Where Is The Reverse Light Switch Located?
Reverse Light Switch Location.
dlg4339
Where Is The Starter Located?
Where Do I Find The Starter?
Dusty Malloy
DODGE STRATUS
Preventive Transmission Service?
I Have Heard Different Opinions And When To Service The Transmission Works Find And Driven Under Normal Driving Conditions. Thank You. Don...
don hoder
SUBARU FORESTER
Engine Turns Over. No Power To Fuel Pump?
Engine Turns Over. No Power To Fuel Pump. Relays Are Good Fuses Are Good With Power To Both. The Truck Shut Down One Day And Replaced The...
Alm102486
Body Damage, Hood And Passenger Side Headlight From...
Was In Accident. The Hood Latch Is Bent Inward, And The Car Hood Is Dented Upward. The Headlight Bulb Is Smashed But Should Be Replaceable...
Mcorozco
Pick Up Coil Found Loose Copper Wire?
So, I Had To Replace The Condenser. When I Put The Distributor Together And Started It Up, I Could Hear A Noise. Took It Apart And Found...
Duggan88
I Suspended The Back Of My Car And I Have Some...
Hello! I Don't Really Know Much About My Car Besides Basic Stuff, And I Have Some Questions. Basically, I Suspended The Back End Of My...
Andrei Tudora
VOLKSWAGEN GOLF
Rounded Alternator Nut?
I Have Tried A Bolt Extractor Set A Gator Grip Attempting To Hammer A Smaller Socket On It I Used Pb Blaster On It And Nothing Is Budging...
Misswimms77
NISSAN MURANO
Camshaft Choice?
69-70 Ford 302 Windsor Small Block Following 2carpros Youtube Rebuild Of Ford 302 And For The Cam Selection. I Chose A Milder Summit Cam...
Jeeprisk
1969
No Crank, No Start, Possible Immobilizer, ECU?
Ignition Wouldn't Turn With Second Key (rare Use, Couldn't Find My Keys, Used Many Times Before) Had Aftermarket Alarm/remote...
03RamColorado
Need Harness Side Of Plug Pin Out Identification To...
Upstream Sensor Need Info For Wire Colors On Harness Side Only Not Sensor At Plug Connection Truck Never Had Harness Side Plug Just Taped...
Jeromi73
Service Theft Deterrent, Tried Reprogramming Key, Did...
Okay So, A While Back Maybe 2015 I Lost My Keys And Fob To My Car, I Had A Locksmith Program A Key No Chip I Believe? It’s A 14r3. He...
chris45899
PONTIAC BONNEVILLE
Engine Will Not Stay Running?
My Car Cranks And Starts For About 3 Seconds And Shuts Off. I Noticed That It Doesn't Have A Pigtail Connected To The Oil Pressure...
Rico71
PONTIAC G6
Clicking And Clunking Noise On Left Turn And Braking?
I Have The Car Listed Above Ex Shy Of 400,000 Miles, That I'm Fixing, And I Can't For The Life Of Me Figure Out Where The Clicking...
yosabba
20 IMAGES
Brakes Will Not Pump Up?
Replaced Rotors, Master Cylinder Booster. My Question Is Bench Bled Master Cylinder We Get All Kinds Of Fluid Out Of 2 Of The 4 Ports...
Bill Paxson
How To Replace The Passenger Door?
How Can I Replace My Passenger Door And What Tools Will I Need To Get The Job Done?
Louai Hussein
Loss Of Power?
The Car Listed Above Is A Gt Model. Over The Last Month When Driving, The Car Will Randomly Lose Power, Then Power Will Come Back After A...
Shaun Dawick
SUBARU LEGACY
Grinding And Squealing Noises When Braking?
I’ve Been Hearing Grinding And Squealing Noises When Braking. The Mechanic Told Me That It Was My Rear Differential Causing This Issue I...
GodIsGood2Me2023
DODGE DURANGO
Add Transmission Fluid?
Isn’t There A Spot To Add Transmission Other Than The Driver Side Front Tire Being Removed And Adding It From There?
azdanno04
GEO PRIZM
Recently, A Client Called Me To Fix His Car Listed Above With A 1mz Engine That Cranked But Wasn't Starting. From The Onset, The...
David Davo Essien
26 IMAGES
TOYOTA AVALON
Where Is The Radiator Fan Fuse/relay Located?
Hi, My Check Engine Light Came On Due To Cooling Fan Speed Low Detection, And My Fan Doesn't Cut On. But Before Buying The Fan I Was...
Manuel Gutierrez
GMC ACADIA
Epc
Put Coil Overs On My Car And The Epc Light Came On. I Changed All The Wheel Speed Sensor. Put New Spark Plugs In. And The Epc Light Won’t...
damienperez601
VOLKSWAGEN JETTA
Engine Control Unit (ECU )does Not Power On? I Need...
Please Can I Have The Power And Ground Input To The Ecu. The Ecu Fuse Keeps Blowing Each Time I Cycle The Key To Acc Position. I Need The...
Andrin Atem
CHEVROLET TRAVERSE
Steering Wheel Hard To Turn After Changing A Flat Tire...
I Have The Vehicle Listed Above Sel, It Is My Wife's Truck So One Day She Got A Flat On The Front Right Side She Changed The Tire But...
weezy310
FORD EDGE
609
610
611
