Engine Noise?
This Morning After A Short Drive I Noticed My Car Was Making A Noise That Is Hard To Describe. Recently The Weather Has Heated Up And The...
Anthony Manthony
VOLKSWAGEN JETTA
Problems With Transmission Not Shifting When Driving...
A Few Weeks Ago, While Driving On The Highway After Getting Out Of Heavy Traffic, The Car Stopped Shifting From 2nd To 3rd And The Whole...
AJH53
HONDA CRV
A/C And Heat Blows The Same Temperature?
Hi, Recently My Air And Heat Blows The Same Temperature. The Blend Door Actuator Was Replaced And Still The Same. The Compressor Comes...
Melodie Walls
Not Able To Communicate With PCM?
I'm Currently Working To Figure Out If I Have A Bad Pcm Or A Power/ground Issue To The Pcm. I Need To Pinout For Main Power/ground For...
Tony423
16 IMAGES
Sometimes It Starts And Idles Fine And Sometimes It...
After Changing The Flywheel And Putting It Back Together I've Run Into The Following 1- Accelerator Pedal Is Uninstalled But Still My No...
Big Joe24$$
VOLVO XC90
This Part Fell From Under The Dash (drivers' Side...
This Vehicle Was Stolen Last Month. When Found, The Covers Under And Around The Steering Wheel Were Torn Off And Key Ignition Had Been...
scotty2650
HYUNDAI ELANTRA
Air Bag Light On, Interior, Bed Light Not Working, And...
Air Bag Light On. Interior And Bed Light Not Working. Ac Not Blowing Cold Air?
mandy coursey
Sometimes When You Push Down On The Accelerator...
Sometimes When You Push Down On The Accelerator Nothing Happens. There Is No Change In The Rpms, If I Continue To Press Down The Pedal And...
Ceile Brown
DODGE TRUCK
Battery Drainage
I Want To Know Causes And Soulutions To Why My Battery Keeps Draining, Its A Brand New Battery, And I Cant Test It With A Multimeter...
ryantait
Speedometer, Mile And Trip Reader Not Working?
Hello, I Just Bought The Vehicle Listed Above And The Speedometer And Mile And Trip Reader Also Do Not Work. Abs Light And "triangle...
Starsha
AUDI A4
What Are The ECM Terminal Pins Are Called, And Where...
I Need To Find Out What The Ecm Terminal Pins Are Called Where I Can Buy Them. I Have 2 Burned Out, We Have New Ecm And Connector All Pins...
Shawnawayne
17 IMAGES
PONTIAC G6
Ecm
Could You Tell Me Either What The Ecm Terminal Pins For My Car Is Or Where I Can Buy Them I Have 2 That Are Burned Have New Ecm And...
Shawnawayne
PONTIAC G6
Fuel Lift Pump?
This Is My Everyday Ride, Has The Cummins 5.9l. I Just Replaced The Lift Pump For The Second Time In Probably 10 Months. I Think It's A...
JBK76
Why Is My Truck Running Badly?
Anyone Know Why It’s Running So Bad? It’s My Project Truck, I’m Building A Rock Crawler Out Of It And Ls Swapping It But I Need...
Jdalton65
CHEVROLET COLORADO
When Driving The Rear Wheel Area Squeals?
Hello, So, When Driving The Rear Wheel Area Squeals. If I Had To Guess, It’s The Indicator Tab For My Brakes. Around The 7 Second...
brentulrich88
CHRYSLER VOYAGER
Door Chime Makes No Noise, Plus Turn Signal Makes No...
I Tried Looking Up The Location Of Chime Module But No Luck. It Is A Super Duty Diesel Truck.
Brandon Seagle
No Start?
Joe, Since I Am No Longer Working The Fuel System, I Thought I Would Start Fresh. Fuel- Good. Compression- Good. Spark- Good...
GCrow
1985
DODGE TRUCK
Keeps Overheating?
I Have Replaced The Water Pump, Thermostat, Radiator, Radiator Hoses, Plugs, Wires, Changed Oil, Flushed Radiator, And Hoses, And...
Tinamcabee
Fuel Injection Not Working?
I'm Getting Pulse To My Injectors, I've Got Great Spark, And Plenty Of Fuel, But All 4 Injectors Don't Seem To Spray? How...
Timothy Roberson
No Crank No Start
Trigger Wire In Starter Not Getting Power
Vicccc
CADILLAC ESCALADE ESV
Code P1698, Slow Acceleration Gauge Cycling?
Good Afternoon, My Vehicle Listed Above Quad Cab With An Automatic Transmission Has Developed A New Problem. It Started With The Door...
El_Ogan
$7E8, 7E9 And Loose Gas Cap Lights?
Title Summarizes Errors. Attempts At Fixing Include Replacing The Gas Cap And Air Filter. Thanks For Any Help!
mazdacanyon
MAZDA CX7
02 Sensors
Idling Ruff, Using Gas, No Power.( My Question Is How Many Up & How Many Down)
Lisa Daniel
I Need Distributor Wire Colors And Pin Locations?
Hi There I Have The Car Listed Above, Fs 2.0 Engine, Which Damaged The Male Plugs Which Plugs Into The Distributor. There Are Two Male...
Sizwe Amos
MAZDA 626
When I Open The Driver's Side Door The Chime...
Also, I Cannot Lock The Doors From The Inside And The Remote Won't Lock Them Either. I Have To Physically Lock The Doors From The...
mstormin919
MAZDA MILLENIA
608
609
610
