Barely Starts And When It Does It Misfires Really Bad?
My 2000 Chevy Blazer 4.3l Was Recently Stolen And Recovered The Ignition Cylinder Was Damaged With A Screw Driver. Also The Battery Was...
z28makanic
21 IMAGES
CHEVROLET BLAZER
Clunk Noise When Braking?
When I Hit The Brakes Going Slow, Either Forward Or Reverse Some Clunk Sound Comes From The Front End.
Elimak
A/C Is Not Blowing As Cold As I Think It Should?
The Compressor Is Engaging. I Have Vacuumed The System And Filled It. I Will Include A Photo Of My Current Gauge Reading At Outside...
Cwisnowski
Where Is The Headlight Relay Located?
The Headlights Are Not Working. Both The Low Beam And High Beams. Except If You Were To "flash" High Beams They Work. Have Changed...
tazkitykat
Taillights Not Working?
I Have Brake Lights But No Running Lights (they Have The Same Bulb Together) And I Don't Have Rear License Plate Lights.
Slytlyused
Shaking When Driving?
Recently My Car Is Really Wobbly/shaky When Driving The Faster I Go The Worse It Is. It Feels Like I'm Driving On A Bumpy Road Even...
SunEichin
SATURN VUE
Fuel Pump Wiring Issue
Please Please Send Me A Fuel System Wiring Diagram For This Truck. It Is Not Getting Enough Voltage To Run The Fuel Pump. So I Need To Trace...
jg110953
Pinout Diagram Needed?
I Need A Pinout Diagram + Wire Diagram For The Vehicle Listed Above, For The Wire Diagram. I Need It To Be Something Like Which Color Does...
Scion
SCION XB
Fault Code 120408 Paired With 101f01?
Hey! I Was Scrolling Through A Post That You Responded To And Found A Similarity Between My Problem And The Original Poster’s Problem...
Brayvic
BMW X3
Engine Wiring Harness Diagrams
1995 Chevy C1500 4.3 Tbi Vortec I Took The Engine Harness Off And Swapped Motors And Can’t Remember How The Harness Goes In And Can’...
Nwiley
CHEVROLET 1500
Check Engine Light On With Code B0951?
Hi, Have The B0951 Code Pop Up With The Check Engine Light And Cannot Find Any Reliable Info Online. Thoughts? Thank You! Eric
EEdwards2023
Code P0175?
Getting Code P0175, Gas Went Into The Oil Tank And Also Into Some Of The Plugs.
jeep1017
JEEP LIBERTY
Getting Code P0175?
Getting Code P0175 Gas Went Into Oil And Also Some Spark Plugs
jeep1017
JEEP LIBERTY
Car Jerks When The A/C Is On?
My Vehicle Will Jerk When I'm Driving With The A/c On, And It Will Also Jerk When I Am Stopped At An Intersection With The Car In Drive...
Derek Sherlock
Will Not Start?
Replaced The Battery To Starter, The Alternator, Spark Plugs, And Wires Car Still Will Not Start.
Jason0303
TOYOTA YARIS
The Front Seat Belt Will Not Retract?
The Seat Belt Front Is Not Retracted. So, I Opened And Too Many Small Pieces Got Loosen And I Don't Know How To Put Them Back. Someone...
carprosmechanic
TOYOTA SIENNA
Battery Issue?
Our Vehicle Listed Above Ran Perfectly With Absolutely No Problems When We Bought It, 13,000 Miles Ago, Except The Battery Went Bad. My...
QueenKotek
1984
DODGE DIPLOMAT
Start But No Start
So It Starts Then Dies N Then Half To Wait To Start It Back Up
Thank you
VOLKSWAGEN JETTA
After Using Seafoam Engine Clean Through The Intake...
I Put Seafoam Engine Clean Through The Intake, Was Running Good Before The Seafoam Now It Idles Fine. Try To Put It Into Reverse Or Drive...
Will1313
GMC JIMMY
Is It Okay To Hook Up A Battery Charger To Charge My...
I Am Just Curious If It Is Okay To Hook Up A Battery Charger To Charge My Battery Without Removing It.
Anita Troy
DODGE INTREPID
My Car Cuts Off When Making A Stops
My Car Cots Off When Not Hitting The Gas Or Making Stops At The Light I Have To Put It On Neutral For It To Stay On My Check Light Engine Is...
Arnulfo Arana
CADILLAC ATS
Terst
Test
Ken L
2022
DAIHATSU GRAN MAX
Steering Wheel And Brakes Locked
Let Me Preface By Saying A Few Weeks Ago I Was Driving A One Lane Road In The Mountains And I Ran The Car Off The Shoulder For A Second...
audlu
MITSUBISHI ECLIPSE
Air Cleaner Filter Hose?
I Changed The Alternator Yesterday. To Access The Belt, I Had To Remove The Air Cleaner Filter Box. When I Went To Put Things Back In...
coachlee17
DODGE NITRO
No Start Only Cranking?
My Car Was Losing Power When I Was Driving And Making Clicking Sounds, After Parking Suddenly It Started Cranking, Not Starting Up And Oil...
garry.phiri
TOYOTA STARLET
591
592
593
