It Idles At 2,000 RPMs It Used To Idle At 800 RPMs ?
I Changed All Four 02 Sensors, The Fuel Pump, The Tps And Put All New Ignition Coils, Spark, Plug, Wires And Spark Plugs. Before All...
Jason Breland
KIA SORENTO
While Removing The CV Axle About 2 Quarts Of...
I Changed A Cv Axle The Other Day. I Did Everything Like It Should Be Done. When I Took The Old Axle Out Of The Transmission, About 2...
Oldguymechanic65
CHEVROLET SPARK
Pv 436 Purge Valve/solenoid Location?
I Need To Locate And Replace The Purge Valve/ Solenoid On The Van Listed Above Made In February.
JediJesus
Gauges Are Bouncing, The Air Bag Light Flashes After...
The Truck Has Been Sitting For A Good While. I Finally Went To Move It And It Wouldn't Start. Went And Just For A New Battery And It...
Zandra Daniel
We Changed The Fuel Pump The Reply, Not Starting?
Lee Tant
Clutch
Why Did My Pedal Go All The Way Up To The Dash
April Maddox
1977
CHEVROLET CHEYENNE
Charging Or Starter ?
New Battery To The Truck. Truck Went Out Due To Bad Terminals That Connected To Battery. A Few Days After Replacing And Running Truck...
Tim Lee
Transmission Replacement Issue?
I Have The Truck Listed Above Long Bed With A 4.3 L V6 4l60e Transmission One Piece Casing 6 Bolt Pattern, It Has Gone Out On Me. I Have A...
Jbradley333
CHEVROLET 1500
Transmission Not Working Properly After Being In An...
The Car Had Been Hit, Front Center, Replaced Hood, Right Fender. Starts Up Put In Drive, No Go, Drop To Low Engages, Went For Ride...
kjos
Code P0336, Runs Good Then Shuts Off After It Gets...
When I First Crank It Up After Sitting Overnight It Runs Good And When It Warms Up It Will Not Crank Back Up. I Have Texted The Fuel...
William901
Vibration Under The Hood?
Engine Runs Quiet And Smoothly Until I Turn On The Blower Motor Fan, Whether Using Air Conditioner Or Not. I Know It Is Not The Blower...
sav04mach
Car Pulls Left When Braking?
When I Brake The Car Pulls To The Left, But Only The First 2 Or Three Times, Then The Brakes Work Fine. What Could Be Wrong? Have...
donjyoung
How To Conduct A Security System Reset?
My Theft System Got Triggered Now It Won't Start. It Won't Do Nothing Has A Flashing Light On The Dash. How Do I Reset This So I'...
Cathywilley488
DODGE DURANGO
After Lock Cylinder Replacement, Do I Need To Program...
My Car Key Will Not Turn Inside The Key Slot. When I Insert The Key, The Immobilizer Recognizes The Key, But The Ignition Lock Cylinder...
Annielu
17 IMAGES
LEXUS GX 470
Starter Issuse, Crank No Start
Was Drivin Down The Road The Truck Cut Off Possible Smoke Frim Temanils, Had It Towed Home Brand New Starter, Alternatoer, Battery...
April Maddox
1974
CHEVROLET CHEYENNE
Battery Issue?
I Got My Battery Tested And It Read 400. At That Time My Car Had Been Sitting For A Couple Of Hours, Then I Drove To Get It Tested Again...
Hakeem1870
CHRYSLER LE BARON
Fuel Pump Issue?
I Fuel Pressure Tested My Car And I Turned The Key But Didn’t Start It And I Git 10 Psi… Then I Started My Vehicle And Got 45 Psi… I...
Hakeem1870
CHRYSLER LE BARON
A/C Climate Control Buttons Not Working Properly?
Hi There. Bear With Me. The Other Morning On My Way To Work My Climate Control Buttons Started Going Wacky. By That I Mean Kind Of Doing...
Papahood
19 IMAGES
2022
Would Replacing The Computer Also Reset The...
I'm Pretty Sure The Immobilizer Is Activated In My Car. Also, It Was Running Weird Before That. Shifting Weird, Bad Gas Mileage...
DawnHoover
LEXUS RX 300
Will Start And Run But Falters On Acceleration?
Originally Quit On The Road But Started After A While. Have Replaced Fuel Filter, Distributor Cap And Rotor, And Plug Wires. Hard Starting...
Jayburd
Ignition Relay Not Receiving Signal, Not Starting?
Hello, To Be Succinct, My Vehicle Isn't Starting. (: I Am Able To Jump The Relay With A Paperclip, And It Fires Up. So, The...
westonadams
P0783 Code
Where Are The Solenoids Located And Will I Need To Drop The Transmission.
Chyanne Sheriff
When I Go To Inspection All My O2 And Catalyst...
Hi, I Have A Problem As Far As When I Go To Inspection All My O2 And Catalyst Monitors Will Not Complete A Drive Cycle. I Put A New Battery...
Jeff Newinski
What Size Is The Rear Differential?
I've Been Looking Everywhere And Cannot Find Out What Size My Rear Differential Is. I Have Not Yet Opened It Up But Might Have To. I Was...
olivereric423
Code P0406?
I Have Been Fighting A P0406, I Did Not Find Any Damage On The Wire Harness, And I Have Replaced Both The Erg Valve And Tube.
Glenn Henderson
586
587
588
