No Interior Lights, Head Unit, Clock, MPG, Keyless...
I Believe The Issue Came From A Bad Wire Harness For A New Head Unit. I Purchased A Premade Harness For My Year Car And The Type Of Head...
Tyler Kirk Hoover
SUBARU FORESTER
How To Remove The Top Serpentine Idler Pulley?
Hello, Can Someone Please Tell Me How To Remove The Top Idler Pulley? It Appears To Be Attached With A Single Bolt/ Fastener. The Problem...
JC-842
Car Immediately Smoking Like A Barbecue After Having...
Originally I Stopped Driving My Car Because It Would Require Hitting The Gas Many Times Just To Get Up To 20 Or 30 Mph After A Red Light (...
Road Traveler
OLDSMOBILE 88
Will Not Start?
Our Friend Tried To Put A Brake Adjuster On And Could Not. The Next Day It Would Not Start; It Turned Over, No Lights Or Electric. I Put A...
jtmongo
MERCURY MOUNTAINEER
The Cooling Fans Only Come On When The Temperature...
The Cooling Fans Only Come On When The Temperature Sensor Is Unplugged?
Badfuse459
Boost Loss After 1st Start?
I Have Had A Reoccurring Issue With My Vehicle Listed Above Quattro, Where When I Start It In The Morning It Runs Fine At A Good 10lbs Of...
l04f127
24 IMAGES
AUDI A4
Fault In Can Communications With N73 EZS Control...
My Car Has Gear Shift Level Disappeared From Ic, The Ac Condition Unavailable On Can Bus Means Not Running, Parktronic Does Not Working No...
Alaeddin Ibrahim Ben Gharbia
MERCEDES BENZ C200
Where Is The VSS Located?
Need To Replace The Vehicle Speed Sensor.
Don Loveless
SATURN L300
Vehicle Speed Censor
Where Is The Vss Located So I Can Replace It?
Don Loveless
SATURN L300
Air Conditioning Freon Low?
My A/c Air Isn’t Very Cold, Could I Buy A Freon To Fill Myself? Thanks
Lindalinda
SATURN VUE
Window Motor.
My Passenger Window Wasn't Working At All And Stuckin Up Position. I Changed The Window Motor And Assembly. Now Window Goes Down But...
jbanks82x
MERCURY GRAND MARQUIS
Window To Go Down Now But Will Not Go Up?
The Window Wasn't Working At All. I Changed The Motor And The Whole Assembly. Got The Window To Go Down Now But Won't Go Up.
jbanks82x
A/C Blowing Hot Air?
When We Turn On Our Car It Starts Normally, But The A/c Is Blowing Hot Air. My Husband Checked To See If It Needed To Be Recharged And That...
SarahSapp21
How Many O2 Sensors Are There For My Car?
Looking To See How Many O2 Sensors Are There.
Anthony Cooper
MITSUBISHI GALANT
2002 Expedetion
Need To Change Inside Ac Filter
Gary Brand
I Need To Find A Ac Bypass Belt For The Chevy
Ac Went Out
courtneyp
Anti-theft System Was Triggered And After Replacing...
Anti-theft System Was Triggered And After Replacing The Battery With A New One The Dashboard Lights Are Flickering The Radio Will Not Turn...
firesign13
CHEVROLET SPARK
A/C Blows Hot In Extreme Outside Temperatures?
The A/c Blows Cold When Outside Temperatures Are Below 90 Degrees. About 90 It Blows Hot Air. The Cabin Filter Was Just Changed, And The...
huntr02
GMC ACADIA
Code P0335, Where Is The Crankshaft Position Sensor A...
Could Someone Please Help Me Find The Location Of The Crankshaft Position Sensor A? It Is Showing A P0335.
Jay005
Replace Neutral Safety Switch 2008 Subaru Outback
I Am Trying To Replace The Neutral Safety Switch On My 2008 Outback And Don't Know Where To Start. I Cannot Seem To Find Videos Or...
Daburton84
SUBARU OUTBACK
Headlights Come On By Themselves?
My Lights Turn On, On Their Own, That Includes The Windshield Wipers If I Leave The Dial On And The Odometer Doesn't Work As Well As...
Hakeem1870
CHRYSLER LE BARON
Code P0722, Where Is The Output Shaft Speed Sensor...
I Got The Error Code P0722, Says To Replace The Output Shaft Speed Sensor. I Cannot Find Where That Is Located On This Car. Please Help Me...
Crystal1983
Blend Door Popping
On Initial Start U, I Can Hear A Blend Door Popping. Sometimes It Will Blow Cold Out The Passenger Side And Hot On Drivers Side Or Vice...
Dcwhite230
RAM 1500
Hard Steering When Turning?
Hi, When I Turn Either Left Or Right It Takes A Little Bit More Effort And Is A Little Harder.
Koubear
24 IMAGES
Engine Oil Overfill?
I Have Just Changed The Oil In My Vehicle And Although I Measured The Recommended Amount (3.7 Quarts) As I Poured From A 5 Quart Jug...
PhreeBird
HONDA CRX
582
583
584
