Oil Pan Replacement.
I Have Already Replaced The Pan And Gasket And Catch Screen But I Can't Figure Out What I'm Doing Wrong I've Tried And Tried...
Dirtydann
Transmission
Where Is The Transmission Control Module On A 2012 Chrysler C300
Kandy L Munn
Pulley Orientation
Can Someone Tell Me Which Side Of The Pulley Faces The Engine Before I Put This Thing Back Together? I See A Video And The. Opened/...
JC-842
Can Someone Tell Me Which Side Of The Pulley Faces The...
I Saw A Video And The Opened/recessed Side Is Facing Out Instead Of In. Are Different Years Install Different? I'd Swear The Pulley Was...
JC-842
Broken Left Front Coil Spring?
The Vehicle Height Dropped About One Inch Due To A Broken Left Front Coil Spring. The Break Is About 2 Inches Up From The Bottom Of The Coil...
drix60
Instrument Panel Not Lighting Up, No Power To Fuse?
Hello, This Was Next On My List Of Things To Repair On My Car Listed Above S55, It Has A 428cj And Runs Great. There Are Some Interior...
Davem16
1966
MERCURY MONTEREY
New Headlights Swap To HID?
I'm Looking To Upgrade My Stock Hid Headlights To Something Brighter And Throw More Light. Wanted To Get Some Recommendations On If I...
adamandshara
How Much Co2 Is Kept From Emitting Into The Atmosphere...
No Where Have I Found Any Figures As To How Much Co2 Emissions Are Reduced By The Evap System. Even Your Page Doesn't Answer Simple...
jblood1943
TIPM G Cord Wires?
I Recently Bought A New G Cord For My Tipm, And The New Cord Has 15 Wires And The Old One Has 16. Additionally, The Wires Don't Match...
Donald Scruggs
PCM Pinout Needed?
I Need A Pcm Pinout For The Vehicle Listed Above Crossroads 2wd. I Have Been Fighting Low Voltage And Have Replaced The Battery, Alternator...
Cdf108
DODGE JOURNEY
Start, Then No Start
Can Start Truck Go And Turn Off Then Will Not Start. Wait 5 Minutes It Will Start. Hit And Miss When It Starts. Battery Good, And Terminals...
Deborah Pedigo
Intermittent Not Starting Issue?
Go Out And Try To Start, Start Right Up, Turn It Off And Will Not Restart, Wait 5 Minutes And It Starts. Hit And Miss On The Starting....
Deborah Pedigo
Electric Condenser Fan Will Not Turn On When Air...
Fuses Are All Good. I Pulled The Connectors On The Tipm And Saw No Corrosion. If I Bypass The High-speed Relay Which Is On The Horn Bracket...
Jerry Williams2
RAM 1500
Let The Clutch Out And It Would Hardly Move I Could...
I Was Towing A Car, And My Motor Shut Off. My Truck Would Not Start I Waited For A Few And It Started Up But I Could Let The Clutch Out And...
lynn_riddle
RAM 1500
Codes P0157, P0158 And P0441?
Hello Everyone, I Have The Above Codes With My Vehicle Listed Above. I Got It At An Auction. When I Scanned The Vehicles, I Got The...
Agbo Henry Chidiebere
LEXUS ES 350
Turn Signals Turn On At Same Time And Do Not Flash?
Hi, Been Awhile But Here I Am Again In Need Of Some Wisdom. Changed Front Turn Signals To Led On My Truck Listed Above 1500. Now When I Hit...
Epiphany101
1966
GMC TRUCK
Clutch Cable Not Working, Also Transmission Shifter...
My Clutch Cable Is To The Floor After Trying To Bypass My Shifting Problem. The Car Will Go Into Gear When The Car Is Off But Not When Car...
P tone
CHEVROLET CRUZE
Engine Will Not Crank When Hot?
The Car Listed Above Is A Gta Model. The Car Will Crank Over And Start When It Is The First Start Of The Day Or After Letting Car Cool Off...
sixty6gto
PONTIAC TRANS AM
Motor
Has No Power Going Up Hills And Ears Alot Of Gasoline. Very Poor Power For A V-8 It Starts Great It Idles Great It Never Back Fires...
CHEVROLET BLAZER
Ticking Noise Coming From The Engine?
When I Turn On The Car The Ticking Starts Right Away And Continues While Idling, When I Press Down On The Throttle The Speed Of The Ticking...
No_Sleep
18 IMAGES
LEXUS GS 300
I Turn The Key To Start It Only Makes A Clicking Noise...
Parked The Car At Night Came Out In The Morning And It Won't Start. It Has Power When I Turn The Key To Start It Only Makes A Clicking...
Deeohgee414
No Crank No Start After Ignition Key Cylinder...
I Drilled Out The Old Ignition Switch And Replaced It With A New Switch From O'reilly's And Ordered One From Car-part. Com To Have A...
Whatwarranty
Intermittent Issue Of Engine Not Cranking?
I Drive My Car For A While, Park It, And Then Come Back To It, The Key Would Turn All The Way, All The Electricity In The Car Would Come...
carguytrav
BMW 740
When The Brake Is Applied There Is Push Back And A...
Smell Was Coming From Front Of Car And Smoke Caliper Was Freezing, Replaced It Only On Left Front. Then When The Brake Applied There Was...
Tisha Strock-Allen
Check Engine Light And 4Lo Blinking After Driving For...
Hello Sir. My Vehicle Listed Above Kdj150 Is Showing Me Check Engine And 4lo Light After I Drive It For About 70kms. I Got It Diagnosed...
Noor Ansari
TOYOTA LAND CRUISER PRADO
576
577
578
