Codes P0087, Limp Mode?
About 5 Days Ago The Car Started Going Into Limp Mode. At First There Were No Warning Lights, And Therefore No Codes. Finally Got A P0087...
Randiromero83
Stuck In Limp Mode?
I Changed The Oil, Sensors, And Solenoid. Checked Wires And Fuses. Restarted Battery. Showing No Codes And No Lights.
Soreheart
CHRYSLER TOWN AND COUNTRY
Code P0018?
Cutting Out, Lost Acceleration, Then Cut Off. Wouldn't Crank For About 30 Minutes. Checked. Oil And It Looked Like Chocolate Milk.
Calvin Wideman
FORD EDGE
Reaches Normal Temperature Then Loses Acceleration...
There Is No Check Engine Light At All, Works Fine In The Morning, And In The Afternoon (live In Az) And It Is Over 100° Outside, The...
Brandi Volenec
Engine Not Turning Over
The Engine Cranks Over But Is Not Starting
Rich Miller
Turn Signal And Brake Lights Are Not Working?
The Hazard Flashers Do Work. Replaced The Multi-function Switch Already Checked The Fuses As Well. Any Suggestions Or Direction Of Where To...
Chiefautoparts
A/C Wiring Diagram/video Needed?
Field Mice Ate My A/c Wires. I Can't Find Any Video That Shows How To Rewire The A/c Wires, Or Where They Go To Or Come From. Do You...
bill0507
CHEVROLET SONIC
Warning Lights
Replaced Upper A Arm On Right Side. My Abs Abd Esc Light S On? Can I Reset?
Sonya lena
KIA SORENTO
Intermittent Not Starting Issue?
It Starts Then Quits Or Doesn't Start At All. I Changed Fuel Pump, Oil Pressure Sensor, And Map Sensor. Any Ideas As To What Is...
raynew50
Turbocharger Actuator
Hi! I'm Working On A Turbocharger Actuator Replacement On A Garret Turbine, Hella Actuator. I Want To Find Out If, After Replacement...
Valatcarpros
MERCEDES BENZ SPRINTER
Engine Will Not Crank Or Start?
My Transmission Fuse Which Is F15 Keeps Blowing As Soon As I Put One In It Automatically Blows And My Vehicle Will Not Start. It Will Not...
Jr Payne
Overheating, How To Replace The Thermostat?
Need Steps To Changing Out The Thermostat Please!
Beasty1983$
How Tight Is The Bolts Need To Be
I Don't Want To Strip Them
Dirtydann
Overheating
How To Change Thermostat
Beasty1983
Overheating
Yes Can You Give Me The Steps In Order To Change My Thermostat Plz Thank You
BEASTY83
Noisy Engine Between 40-70 MPH?
When I Reach Around 40 Mph The Car Gets Really Noisy. Not Rattling Or Anything Like That. Just Sounds Loud. After 70 Mph It Quiets Down. I...
Kelly Pearson
RENAULT CLIO
Ignition Switch Is Stuck Open?
If My Switch Is Stuck Open And Won't Lock With The Key, Do I Need A New Ignition Switch?
mimizlove
When Started The ABS AND ESC Lights Stay On?
Replaced Upper A Arm On Right Side With Ball Joint When Started It Abs And Esc Lights Stay On?
Sonya lena
KIA SORENTO
Blower Motor
I Have An Infinity Fx45 2006 Model I Replaced The Blower Motor Blower Relay And The Ac Amp Unit Still No Air Blowing Please Help An Infinity...
Robbie001
INFINITI FX45
Blower Motor Not Working?
I Cannot Get The Blower Motor To Work. I Replaced The Blower Motor Itself, The Blower Relay, And The Ac Amp. I Don't Know What Else To...
Robbie001
INFINITI FX45
Inertia Switch Bypass?
I Broke My Circuit Breaker On My Positive Cable. How Can I Bypass The 4 Wires Coming Out Of It Until I Get A New One? It's My Only Car.
lorenzo76
SAAB 9-3
HVAC Control Panel Issue?
We Have A/c And Heat. Both Move And Work Well. The Blower Works. The Control To Move To Feet Or Defrost Or Any Other Positions. Seems Stuck...
YaDog
No Crank No Start Issue?
Nothing Happens When I Turn The Key. The Battery Is Good.
ronanderson50
WON'T START
No Response Of Any Kind When I Turn The Key. The Battery Is Good.
Ron Anderson
Won't Start.
When I Turn The Key Nothing Happens. No Sound, No Radio, Nothing. It Is Like There Is No Battery In It. I Took The Battery, A Napa...
Ron Anderson
574
575
576
