Brake Lights Not Working
I Have A 1987 Corvette That Is Having Issues With The Wiring I Believe I’m Not Sure Though. So I Went In And Changed The Brake Lights And...
Egolder
CHEVROLET CORVETTE
Brake Lights Not Working?
I Have The Car Listed Above That’s Having Brake Light Problems. The Turn Signals Work And So Do The Hazards. But Cruise Control Doesn’t...
Egolder
CHEVROLET CORVETTE
Can The Lockup Solenoid B Be Replaced Without Removing...
I Just Want To Know If Lockup Solenoid “b” Can Be Replaced Without Taking Out My Transmission. I Want To Do It Myself Instead Of Taking...
Booh97
ACURA TL
Codes P1274 And P1283?
Hello, I Am Having The Same Problem As Https://www.2carpros.com/questions/p1283-nightmare But I Am Getting The Code For Both. I Have The...
Tbratt11
NISSAN 350Z
Coolant Leak?
When Waiting At A Traffic Light I Notice My Temperature Starts To Creep Up. But Once I Either Start To Drive Or Rev The Engine A Little And...
Gordie473
HYUNDAI SANTA FE
Why Do The Lights Under The Tachometer And Temperature...
Hey Guys, I’ve Been Experiencing Some Issues With My Car And Was Wondering If Y’all Could Help Me Out With Why The Lights Under The...
Ryan Levingston
Repair Information For Other Countries?
I Am Currently Working With A Customer In Cambodia. Do Any Of You Guys Have Any Resources That You Use And Wouldn't Mind Sharing To Help...
Brendon S
Sirius Satellite Radio Quit Working?
My Radio Works On Am, Fm And Cd Player. Satellite Just Stopped. I Contacted Sirius And They Cannot Help. Radio Won’t Accept Refresh...
Holister
VOLKSWAGEN BEETLE
Failed Satellite Radio
The Radio Works On Am, Fm & Cd Player. It Won’t Receive The Satellite Signal Refresh. Sirius Has Said Nothing They Can Do On Their End...
Holister
VOLKSWAGEN BEETLE
Cranks But No Start?
All Sensors Have Been Replaced, The Crankshaft Angle Sensor In The Distributor Has Been Replaced. But Can't Find The Crankshaft Sensor...
Van Ossie Peter
Cluster Needles And Blinkers Are Not Working Properly?
The Needles On The Cluster Won't Move And The Turn Signals Won't Work Unless I Turn On Hazard Button. All Fuses Are Good.
Caseyl1990
I Replaced My Radiator The Transmission Line, The...
The Clip Broke I Got A New One I Can't Get It To Go Together It Won't Clip Together. Do I Need To Push Harder?
Walter Ganly
Wire Diagram For Wires That Plug Into My Speed Idle...
Not Sure Which Wires Is Hot And Which Ground And Which Wires Controls Actuator Motor To Open And Close
David jaglowski
Speed Idle Actuator Motor
My Original Wire Harness Has 4 Wires And The Plug For My Speed Control Actuator Motor Has Different Color Wires I Need To Know How To Wire...
David jaglowski
How To Reset The Immobilizer?
How Do You Reset The Immobilizer? Cranks But Won’t Start, Flashing Key Indicator On All Keys/fibs, Good Fuses And Battery And Starter!
susieL
ACURA MDX
Where Is The Auxiliary Power Fuse Located?
So, I Can Change It. Main Power Fuse.
lcahill53
CHEVROLET COLORADO
Won't Start.
When I Turn The Key Nothing Happens. No Sounds Or Lights Etc. I Took The Battery To Napa And It Is Good.
Ron Anderson
Won't Start.
When I Turn The Key Nothing Happens. No Sounds, No Radio, Lights, Etc. I Took The Battery Out And Took It To Napa (it Is A Napa) They...
Ron Anderson
Clicking/Chugging Intermittently?
Good Evening, And To Start I Appreciate Your Help In This Matter. So, This Is Going To Be A Lengthy And Most Likely Confusing Explanation...
El_Ogan
While Driving, First, Second And Fourth Gears Would...
Last Week My 1997 Toyota Hilux (ta.V.V) Had A Strange Fault / Issue Develop. When Driving, The 1st, 2nd And 4th Gear Would...
Ryan Severn
TOYOTA TACOMA
Oil In Coolant?
My Heads Warped And I Resurfaced Them And I Am Replacing The Head Gaskets. There Was A Lot Of Oil In The Coolant And I'm Wondering If I...
Nate1134
DODGE CHALLENGER
Will Not Start?
My Car Started Fine Yesterday Went Out Today It Will Turn Over But Not Start This Morning This Evening It Won't Even Turn Over. What...
Shawnawayne
VOLKSWAGEN PASSAT
Where Is The Downstream Oxygen Sensor Plug Located?
I'm Trying To Find O2 Sensor Plug That's Inside The Car And For Some Reason I Can't Find It. If Somebody Can Give Me A Picture...
Anthony Cooper
MITSUBISHI GALANT
How To Find Out What Is Wrong
I Have A 1988 Dodge Dakota V6 3.9 L That Runs For 20 Minutes And Then Just Cuts Out Even Know The Ignition Is On How Do I Find Out What’s...
Jordan king
StableTrek Needs Servicing?
This Popped Up In Message Center “reduce Engine Power”. Now The Car Won’t Start And When I Put A Code Reader On It All Kinds Of Codes...
CAM61
GMC TERRAIN
575
576
577
