99 Rodeo CV Boot And Ball Joint Question
My '99 Rodeo 4x4 Has 136,000 Miles On It. It Is All Stock With No Lift Kits Or Other. I Noticed That The Outer Cv Boots Are Cracking A Bit...
jimmyc
97 Chevy Truck NO Spark
My 1997 Chevy Ct1500 5.0 Has No Spark. It Died On The Road Towed It Home Turns Over No Start.I Have Checked All Fuses, Checked Power To...
LB3
Check Engine Light
Where Is The Obd On A 1991 Mazda Mx-6 Dx? I Was Told To Get The Codes For The Check Engine Light I Have To Use A Jumper Because That Year...
rtracy
MAZDA MX5
Vw 2000 Jetta A/C Not Working.
Ok. A Few Months Ago, I Noticed A Strange Sound Whenever I Had My Ac On, It Turned Out To Be My Accessory Fan Under The Hood.( I Think...
phat99civic
Problem With O2 Sensor
The Check Engine Light On. I Had The Local Autoparts Store To Run A Scan And It Showed That Bank 2 Oxygen Sensor Heater Circuit Had...
Bransatt72
67 Galaxie
I Own A 67 Galaxie With A 289, Auto-glide Tranny. I Am Attempting To Restore-mod, But I Am Having A Difficult Time Trying To Get The...
detacinst
1967
1998 Ford Ranger - Door Adjar Light Will Not Turn Off
I Have A 98 Ford Ranger Xlt With 75000 Miles. It Seems That When It Rains Or Snows, My Door Adjar Light Will Pop On And Will Not Turn Off...
andu10
Car Will Not Start
As I Was Driving, Just Stopped. I Checked The Timing And The Timing Belt And They Seem To Be Ok. The Car Tries But Does Not Turn Over. I...
ixball1
2002 Explorer - Key Fob & Pad Not Working...
Around 35k Miles I Was At The Grocery Store With Just My Key Fob. When I Went To Unlock The Truck There Was No Response What So Ever. The...
aportinga
Protege Fanbelt Noise...Overheating...Help!
I Own A 2002 Protege. After Having Timing Belt And Water Pump Replaced, A Recurring High Pitched Fanbelt Squeal (incredibly Loud) Began To...
Doug
MAZDA PROTEGE
I Started To Notice My Steering Wheel Jerk To The...
Hey, I Have A Serious Problem With My Steering. I Actually Have A History With It. I'll Start Off Saying About 4 Months Ago, I...
ehenriquez
Unkown Part Name
Hi, I Have A 1993 Escort And There Is A Pice That Broke Off The Other Day On The Back Wheel And It Kind Of Looks Like A Fork At One End And...
raperman
1988 S10 Blazer 2.5l - No Fuel Spray While Cranking
I Have A 1988 S10 Blazer 2.5l That Will Not Cold Start Most Of The Time. When It Is Acting Up There Will Be No Fuel Spray From The Injector...
bvsnook
There Are Some Rattling,slipping,and Grating Noises...
There Are Some Rattling, Slipping, And Grating Noises Coming From The Driveline/suspension/steering. Its Very Intermittent And Comes And...
arkangel357
Fuel Pump Replacement
What Would It Cost Me To Have A Fuel Pump And Filter Replaced?
x_zieba
1997 Suburban Humming Sound From Rear
1997 Gmc Surburban With 87k And 5.7l. The Humming Is Present Only When The Engine Is Running, But Does Not Change Pitch With Engine Rpm....
bluesbro
Delta 88- Poultergiests Take Over Gas Tank On Curves
I Have A 1994 Delta 88 With An Intermittant Problem. When I Am Going In A Clockwise Circle- Entering Or Leaving The Expressway- Or Sometimes...
GardenDmpls
Mazda 626 Cronos Check Engine Light Flashing
Few Weeks Ago I Had A Solid Check Engine Light. Around That Time I Was Putting Cheap Gas(87). One Day My Car Started Missing While Driving...
scorpio612
1962
MAZDA 626
All Of The Sudden My Abs Light Came On My Traction...
All Of The Sudden My Abs Light Came On My Traction Control Doesn't Work And My Heater/ac Is Stuck At A Low Heat (it's Digital And It...
scottyb79
CHRYSLER LHS
Won't Shift To 4th Gear Automatic Transmission
I Have An Automatic Transmission Mazda Mx3 And The Hold Light Comes On And It Won't Shift To 4th Gear. Need Help. Any Idea What It Could Be?
emerson.tan
MAZDA MX5
2000 Bonneville Coolant Leak... Around Fuel Injectors...
I Have A 2000 Supercharged Bonneville With About 90k Miles. I Have Noticed A Coolant Leak Over The Course Of The Past Few Months That Has...
sc2000
PONTIAC BONNEVILLE
97 Intrepid Wiper And Headlight Problem
Have 2 Seperate Problems With My 97 Intrepid, But Maybe They Are Related. The Bright Headlights Came On Without The Switch Being Turned...
xanadu
DODGE INTREPID
1991 Chevy S-10 4.3 V6
I Have A 1991 S-10 170,000 Miles My Problem Is When It Gets Hot It Misses Not At An Idle Just When Your Going Down The Highway And You...
marshall
No Power To Radio And Power Windows - '97 ParkAve
I Have A 1997 Park Avenue Which The Radio And Power Windows (all 4) Stopped Working At The Same Time. I Have Checked Fuses, Rap Relay And...
indytex1
Having Problem With The Instruments Cluster And The...
However I Am Having Problem With The Instruments Cluster And The Automatic Door Lock. The Speedometer, The Mph, The Fuel, Temperature...
decostemg2
20253
20254
20255
20260
