Stalling Out
I Love My Car. It Just Started To Give Me A Problem. At An Idle It Stalls Out Or Sometimes Feels Like It Is Going To Stall Out. Can Anyone...
lisa07882
Honda Accord Lx 1999 Seat Belt Alarm Does Not Work
The Seat Belt Alarm Does Not Work. I Don't See The Indicator On The Dash Board Display. Also, The Break Lamp Indicator On Dash Board Is...
ramjiayala
Clutch Or Transmission
According To Many Other Problems My Car Is Having. It Makes This Grinding Noise When I Let The Clutch Go Too Fast On First Gear Or Even Let...
NOAHthepimp
Acura 3.2 TL 1999 Car Alarm Goes Off Randomly
Hi My Acura 3.2 Tl (1999) Model Car Alarm Goes Off Suddenly, Sometimes After 2 Hours Or Sometimes After 15 Minutes. It Will Go On For 1...
ket000
Trouble With Door.
I Recently Brole My Driver Side Window In Cold Weather. I'm Trying To Get The Door Panel Off Of It But Unsucessful. Does Anyone Know How...
kouba93
Water Leaking Into Car
I Have A 2002 Jetta And Water Has Been Leaking Into The Driver And Most Recently The Passenger Floorboards. I Have Checked The Sunroof...
bmxgrle
Lifters & Valve Noise
I Bought A 99 Malibu That Has "lifter"? Noise. A Mechanic Told Me It Appears To Be The Exhaust Lifters; I Buy The Lifters, He...
deardeva
1993 Probe Transmission Trouble
Having Trouble With A Probe Transmission Completely Rebuilt The Mechanical Portion And Replaced The Pump. But Still Not Getting Enough...
godbear839
Is The Shop Ripping Me Off?
Ths Is A Follow Up On The Last Post About Mitt Eclipse '96 Clutch I Am New To Manual Transmission So I Forgot To Check The Brake Fluid...
NOAHthepimp
My Car Won't Start!
I Drove It 400 Miles Last Night To La With Out Any Problems. I Went To Drive It This Morning And It Would Not Start. I Cleaned The Battery...
Aaron Farley
Oil Pan Problem: 1988 Honda Accord LXi
Hi, My Name Is Heather And I Have A Problem With My Honda. I Went To Go Get A Routine Oil Change At A Local Tuffy Auto, And They Came To...
Heatherr
2002 Jetta Wheel Vibration Felt Through Gas Pedal
2002 Jetta Turbo, 76,000 Miles, Transmission Less Than 1 Year Old, Front Wheel Drive, Both Front Tires Brand New, But R F Tire Recently...
dvlsfn30
Vapor Comes Out Of The Hood On My 91 Cavalier
My 1991 Cavalier (2.2l With Non-functioning A/c If It Matters) Creates Some Smoke/steam/vapor Sometimes - But Not All The Time - When I Am...
boat21x
!985 Vandura Fuse Panel Addition
I Would Like Know How To Add A Curciut To My Fuse Panel. I Am Adding A New Stereo And It Requires A Constant Hot Line. The Old Stereo Did...
JumpingJack
Help - No Brakes!
It Has Aprox 75 000 Km On It. The Guy I Bought It From Told Me The Brakes Needed To Be Bled Because He Had Done Some Work On Them. That Didn...
canadianmaiden
02 Taurus,interior Water Leak
My 02 Taurus Has 75k Miles And Until Recently Has Been Trouble Free. Everytime I Use The A/c Water Leaks, No Flows Into The Passenger...
dmarcos1
93 Chevy S10 Blazer Runs Crappy. 4.3 Vortec
I Got This Truck For 100 Bucks, Great Condition, The Guy Said The Motor Was Locked Up, I Took It Home, It Wasnt, A Batt. Cable Was...
smokinfloyd4.3
Saturn Car Unusual Problem
I Bought A 94 Saturn Coupe From A Friend. He Has Installed A 1996 Saturn Motor In It. The Car Doesnt Run To Its Full Potential By A Long...
maillouxcj
Heat Only Works On High In My Caravan How Do I Fix...
Heat Only Works On High In My Caravan How Do I Fix This?
KFORD1
88 GMC S15 Jimmy Vibration
I Have An 88 Gmc S15 Jimmy With A 2.8l, It Has Around 165,000. Maybe A Month Ago Or So, A Vibration Started When Reaching Speeds Of Around...
CoryRJanssen
GMC JIMMY
No Heat
Hello I Have A 93 Caravan I Replaced Thermostat Top Hose Mu Temp Gauge Goes To Hot Just Letting The Van Run My Question : Do You Think...
rickyc716
95 Lumina Transmission - Overdrive Bucking At Around...
I've Looked At All The Possible Solutions Your Website Has Offered (awesome Site By The Way!) And Have A Suspiscion That You're Going To...
johno
1995 Astro Intermittent Failure
I Have A 1995 Chevy Astro (2wd) With 180,000 Miles, 4.3l. Overall It Runs Very Well. Runs Strong, Uses Virtually No Oil, Etc. (Full...
rholloway
1999 Toyota 4runner Emergency Break Light Warning...
I Have A 1999 Toyota 4runner. The Emergency Break Warning Light Stays On Even Though The Break Is Not On. After Driving For A While The...
lzktgr
1990 Toyota Camry Retrctable Drivers Side Seat Belt
My Drivers Side Seat Belt Will Not Retract When I Open The Door. The Passenger Side Works Ok. Any Ideas? Thanks Ed
EdH
20254
20255
20259
