Stuck In 4 Wheel-drive
:( My Husband Took My 1989 Toyota Landcruiser (238,355 Miles) To A Car Wash (where The Vehicle Rolls Through By Itself). When He Started...
pooh
TOYOTA LANDCRUISER
Same Problem Different Ideas 90 Chevy Wont Stay...
Ok Same Problem Starts But Wont Stay Started After A While It Dies Wont Start Easily And When It Is Started It Dies If Its Shifted Into Gear...
abercrombie8
JEEP CHEROKKE STALLS AT 1/4 Tank Of Gas
My 1999 Jepp Cherokee Starves For Gas At Between 1/4 And A Half Tank Of Gas. I Noticed This About Two Years Ago And As Long As I Keep It...
tomw
Dodge Intrepid Cooling System
I Have A 1998 Dodge Intrepid Es 3.2l V6 With 2xx, Xxx Miles. Car Runs Great, Except That While Sitting In Traffic Or Parked (running), The...
spawn
DODGE INTREPID
93 Chevy Van G20 Ignition
Can Anyone Tell Me The Position Of The Ignition Wires From The Distributor Cap To The Spark Plugs? I Changed The Spark Plugs, The...
chevyhenkie
95 Manual Honda Civic Clutch Problem
2 Days Ago My Honda's Clutch Started To Have Hardly Any Tension When I Pressed Down On It And It Caught Much Closer To The Floor Then Usual...
nanners
Annoying Squeek
I Have A 2002 Mercury Sable Gs With 50,000 Miles I Just Bought It About 2 Months Ago.( Good Car!)But A Few Days Ago I Heard A Intermitent...
raychris
2000 F 250 Overdrive
I Bought A 2000 F- 250 Diesel And The Overdrive Will Not Turn Off To Tow. Is There A Fuse For This? Where?
cc1792001
How Do You Change The Wheel Bearings On A 1995 Ford...
Can Someone Tell Me How Difficult It Is To Change The Front Wheel Bearning On A 1995 Ford Taurus. I've Been Told That In Order To Replace...
Juarez
Fast Idle
I Have '95 S10 Blazer 4.3- 2whl Drive, Idles Too Fast And While Driving Will Coast At 30mph. Very Hard On Gas, Can You Help. Thanks In...
kruzr
Intermittent Problem....Electrical????
I Have A 1997 Plymouth Grand Voyager Se That Has Developed An Intermittent Problem (3.0 Engine, 131000). Driving At Highway Speeds (i've...
jwcran
PLYMOUTH VOYAGER
89 Honda Civic, Pedal Down, Car Shuts Off
I Have A 89 Honda Civic Lx. Recently I Cleaned The Engine Becuase It Was Messy From A Previous Coolant Leak. Now It Starts Fine, And...
syedz7
I Need Help With Sensors And Relays
I Changed My 93 Civics Ignition Switch With Anoher Switch That Had A Relay On The Wiring, But My Stock Ignition Switch Didnt, Then I Was...
Ronie
Trouble Codes
1999 Ford Ranger With Trouble Code 153 O2 Sensor Wich Sensor Is It? The One Next To The Engine Or On The Catalytic Converter?
tex928
My Son Switched Wires Around
My Son Bought A 1986 Buick Hearse And Put Plugs And Wires On, But He Did Not Mark The Wires And Their Placement And Switched Them Around To...
twilley
Premium Gas
I Have A 2005 X3. It Says Premium Gas Only. Will My Warranty Be Voided If I Use A Lower Grade?
mary_larson
BMW OTHER
Creamy Substance In Oil - 86 Jetta
Yikes.I Have An 86 Jetta And Recently When I Went To Put Oil In It, When I Lifted The Cap There Was This Light Brown, Creamy (not Bubbly)...
AztralSoul
'95 Neon Losing Fuel Pressure
I Have A '95 Neon With Only 130 000 Km's, It Has Intermitent Problems While Driving, Seems To Be Getting More Frequent. Once A Day Now...
frenchy
CHRYSLER OTHER
Fuel Injector Fuse Blows PROBLEM SOLVED:
I Have A 1992 Grand Am And The Fuel Injector 20 Amp Fuse Blows, It Runs For A Bit But Out Of No Where It Blows. There Was One Time It Blew...
snuggles
1999 Chevy Suburban
I Surely Do Hope Someone Has Some Ideas Out There. My Husband And I Parked Our Newly Aquired Suburban In Our Driveway, And There It...
frustrated
Sable/Taurus Blower Motor Fan Switch
I Need To Know Where The Fan Switch For A 97 Mercury Sable Is. Behind The Dash But Where.I Have An Inop Blower Motor And Im Trying To Find...
GreaseMunke
Porsche 924 Wiring Question
I Have A Porshe 924 Practically Given To Me In A Basket With No Wires Or Hoses Hooked Up To It. I Can Now Get It Started, But When...
denny szekacs
PORSCHE OTHER
Change Radius Arm Bushings On A 1991 4x4 Ford Explorer
How Do U Get The Old Bushings Off And The New Ones On My Explorer
Stephen_dew1987
1992 Cadillac Fleetwood Brougham
I Have A 92 Cadillac Fleetwood Brougham (rwd) With 53,000 Miles And I Am Getting Alot Of Vabrating From The Rear Starting At 48 Miles Per...
Timbo48051
CADILLAC FLEETWOOD
Noise ? Wheels Ford Explorer 1998
Explorer 161,000 New Engine At About 90,000. Noise From Wheels (? Which One) While Driving At Parking Lot Speed(5-15mph). Goes Away When...
tolivero11
20193
20194
20195
