Fuel injector fuse blows PROBLEM SOLVED:
SNUGGLES
  • GMC
I have a 1992 grand am and the fuel injector 20 amp fuse blows, It runs for a bit but out of no where it blows. There was one time it blew and I replaced it and it ran for about 2km and blew again. I have tryed everything, fuel pump, traced wires, changed oil presure sensor, relay, and the ECM.
Can some please help me?
If you have an answer please e-mail it to me at
direct55@hotmail. Com
HURRAY: Problem Solved:
2.3L Eng. Wire harness that passes by transmission, gray wire to injectors shorts out againnst tranmission.
Thanks Anyway People. Doug.
Do you
have the same problem?
Sunday, January 29th, 2006 AT 2:10 PM
GREASEMUNKE
Try a higher amp fuse.
Monday, January 30th, 2006 AT 12:58 AM
Recommended Guides
