Van Wont Turn Over
My Van Had A Chugging Motion And I Thought It Was The Fuel Filter So I Change It Now It Wont Start It Will Roll Over But It Wont Fire Can...
howiep69
CHRYSLER VAN
WINSHIELD WIPER FLUID WON'T COME OUT
Can Anyone Help Me Out With This? My Windshield Wiper Fluid Will Not Squirt Out Anymore. It Seems Like It Wants To But Only A Little Comes...
YANAH
1999 4Runner Dash Lights
My In Dash Clock Doesn't Lightup At All Plus The Climate Control Screen Doesn't Illuminate Properly! Everything Else On The Dash Is Lit Fine...
rallen13
SHORT IN ENGINE
My 1990 Ford Bronco 2 Indicates A Short When I Check Between The Neg Posi And The Removed Neg Battery Clamp. This Shows A Full 12 Volts On...
LEON GRUSKIEWICZ
Axle Bearing On A 2000 Pontiac Grand Am
I Drive A 2000 Pontiac Ga And When I'm Driving A Here A Grinding Noise. Is This Grinding Noise A Bad Axle Bearing. My Abs Traction And...
lhoward30s
Spark Plug Seals/valve Cover Gasket On 95 Trooper 3.2L
I Recently Replaced The Plugs On My '95 Trooper 3.2l, Sohc (~100k Miles) In Reponse To Some Sluggish Performance. In Doing So, I Found...
jcklein
1994 F-150 Truck Cranks But Won't Start
What Do I Need To Check? My 1994 F-150 Cranks But Won't Start.
johnbrenda
Will Not Fire
Did Engine Swap On A 1996 Dodge Neon. None Of The Sensors Were The Same. Changed All Of The Sensors, Except The Cam Sensor.[S.O.C], Just...
froggy
CHRYSLER OTHER
Warped Brake Discs
Hello I've Been Having Problems With My 1999 Rover 220 Sdi. The Problems Started When I Clipped A Kerb And Bent The Passenger Side Front...
ijakk
LAND ROVER OTHER
Harmonic Balancer 87 Ford F250
Other Than Blasting Caps And Pneumatic Hammers Is There Any Other Tricks In Getting That Bolt Off The Balancer? Seems Like It Should Give...
mcginnesrj
4 Wheel Drive (not So Much)
99 Explorer Sport With The Sohc 4.0 The Shift Motor On My Transfer Case Was Bad.I Changed It. Now The Transfer Case Will Go Into 4wheel Low...
99Exploder
Rear Tire Locked
The Back Left Tire Spins Whie The Back Right Tire Is Dragged. Even When I Jacked The Car And Had The Truck In Neutral The Tire Still Had...
pthering
SUZUKI OTHER
Brake Service Instructions
I Was Wondering If Someone Could Tell Me How To Change The Brakes Of A 1985 Volks Cabriolet. I Also Wanted To Know Some Good Custom Sites To...
RIDDL3R
1985
99 Tahoe Wont Start :(
Hi All, Im New To This Site, But I Hope It Helps My Problem Here. I Have A 99 Tahoe With The 5.7l, And It Wont Start. It Will Crank Over...
mattd17
1993 Astro Won't Start Under 14 Volts
I Have A 93 Astro 4.3 W That Will Not Start Unless The System Voltage Is At Least 14 Volts. The Alternator And Ignition Module Have Just...
blane
1995 Ford Thunderbird
I Have A 1995 Ford Thunderbird And The Battery Light Is On. I Can Sit At A Stoplight And The Car Wont Die, But The Charge Meter Is Almost...
jbutler103
FORD THUNDERBIRD
1988 Subaru DL
What Causes Oil To Get Into The Carborator Through The Hose That Runs Between The Aircleaner And The Head? Could It Be Too Much Oil In The...
Idenholm
SUBARU OTHER
2001 Eclipse Thermostat
Can Someone Tell Me Where I Can Find A Copy Of An Owner's Manual For 2001 Eclipse? Also, Since I Don't Have My Manual, Can Someone Please...
Houston 2001 Eclipse
Where Is The Blower Motor?
I Don't Have The Owner's Manual And From What I've Read On Other's Forums, I Should Check My Blower Motor But; 1. Can't Locate It. 2. Don't...
pulsti
Windsheild Wipers
I Have 1984 Bmw 318i, The Wipers On Intermittant Run Continuously, When Switched Off They Do Not Return Home And Park, It Has A New...
beamer
BMW 318
Manual Fuel Pump For 350 Sbc
I Bought A Motor That Had Been Partly Disassembled. I Went To Put In The New Fuel Pump Because The Other Was Missing. I Cant Seem To Get The...
indcent
1935
1991 Eagle Summit
Perhaps Someone Can Help Me. I Purchased A Used 1991 Eagle Summit 6 Months Ago And Began Experiencing Problems With It About A Month After...
Abe907
EAGLE SUMMIT
1995 Grand Am - Service Engine Soon Light
I Have A 1995 Pointic Grand Am Se V6 Miles: 185,000. What Might Cause The Check Engine Light To Come On When You Are Driving At Highway...
GreatOne
1997 Plymouth Voyager Nightmare
I Key Tested My Voyager And Get A Code Of 61 I Looked Up The Code And It Said The Map Sensor Was The Problem For That Code, Would That Make...
kk3528
Check Engine Light
I Just Installed A Short Ram Intake On My 03 Eclipse Gt And Now My Check Engine Light Won't Go Off. I Already Disconnected The Battery And...
greenmellon
MITSUBISHI OTHER
20194
20195
20196
