91 Caprice Classic Transmission
I Changed The Transmission In My 91 Caprice, Put Fluid In The Transmission And The Only Gear That Works Is Park. If I Put It In Any Other...
krulak99
New Or Remanufactured Engine?
1998 Chevrolet Z-71 Pickup W/ 181,000 Miles On It. Found Antifreeze And Water In Oil, Gaskets And Everything Shot. Would You Go With A...
Ballgame
2002 Pontiac Firebird Convertible
My Car Vibrates At Exactly 50 Mph. Not 48 Not 52. I Had The Wheels Balanced Twice And It Did Not Help. Pontiac Has Now Had It For Two Days...
twofacelady
PONTIAC FIREBIRD
Gas Mileage - Advice Needed Please
Hi. I Have A 98 Civic Lx (manual Trans) With 192 000 Miles On It. It Was Getting At Least 37 Mpg Until My Check Engine Light Came On (code...
Louise
1990 Chevy Suburban Will Not Restart After Being...
I Have A 1990, 2500 Suburban Silverado With Approximately 139,000 Miles. The Vehicle Runs Fine And I Do Not Have Any Problems With...
harmonc
Seized Slider Pin
I Just Changed My Brake Pads On My 97 Monte Carlo. The Slider Pin On The Driver Side Is Seized Up So That The Caliper Has No Free Play. I...
thunderoad02
Chevy Celebrity-leaking Antifreeze
The Problem Is Replaced The Radiator And When I Put Antifreeze In When The Car Is Not Running It Comes Out Up Near The Starter Area By...
ishabug79
CHEVROLET CELEBRITY
Subaru Legacy 2002 Temp Gauge
Temperature Gauge Ran 1/4 Notch Higher Than Usual Both Idling And Driving. Checked Hoses To Radiator Next Morning When Car Was Cool - Hoses...
missynyou2
SUBARU OTHER
Thunderbird Battery Keeps Dying
I Just Got A 1991 Ford Thunderbird And The Battery Keeps Dying When I Shut Off The Engine The You Can Still Hear A Motor Running From The...
acuragurl04
FORD THUNDERBIRD
Honda Accord EX 1991 - Faint Whirring Noise
I Am Looking Into Buying A Used Honda. I Test Drove It And Drives Great, But Has A Slight Whirring Noise Coming From Engine. It Sounds Like...
pclarry
99 MBZ 230 Kompressor
After Only 99k Miles The Supercharger Is Deteriorating. This Was Diagnosed By The Dealership. Supposedly This Is Rare. Do You Have...
jhans
2000 Ford Ranger/Rough Idle After Starting
My 2000 Ford Ranger(6cyl) On Cold Starts Sometimes Won't Idle. On Cold Days When Starting The Rpms Rise To Approx. 1200 Then Drop Off To A...
dlemons
Moon Roof Repair
I Have A 1990 Acura Legend With A Severe Leak From The Moon Roof I Was Told There Are 4 Drain Tubes Two In The Rear And Two In The Front I...
bigccool
HONDA OTHER
Losing Oil
I Have A 94 Geo Prizm. I Recently Had A Complete Valve Job Done On It Along With Replacing All The Gaskets And The Timing Belt. Now It Seems...
acoop98blackcat
1997 Dodge Grand Caravan Issue
Yesterday We Started Up Our 1997 Dodge Grand Caravan (160k Miles) And Went To The Local Gas Station. After Filling Up We Started The Van...
Abbes
Odometer Not Working
About A Year And A Half Ago My Odometer And My Trip Odometer Quit Working. I Went To A Salvage Yard And Got Another One But It Quit Working...
acoop98blackcat
Fuel Leak Into Oil + White Smoke (Nissan Sunny FE)
Hi, I Have A Nissan Sunny Fe (1.4l), Year 1999. It Started To Show White Smoke From The Exhaust Pipe, And I Noticed That The Oil Level...
pacopass
NISSAN OTHER
Battery Won't Stay Charged
Have A 1990 Pontiac Sunbird Having Problem With The Battery Not Staying Charged. I Replaced The Altenator Starter And Battery And Something...
PyroKa
Under The Hood
While The Truck Is On Is It A Good Idea To Water It Down? If Not What Will Be The Damage To The Truck?
RWild04
Hypertech Programmer/ Problem With Engine
I Recently Changed The Setting On My Engine Computer Using A Hypertech Programmer. I Forgot To Unplug The Hypertech Programmer From The...
jro81
Fuel Injection Flush?
My 95 Taurus Seems To Have Problems Accelarating At Speeds Around 35-40 Mph. Someone Suggested A Fuel Injection Flush. I Have Never Had This...
rmk74
Intake Manifold Antifreeze Leak
My Mechanic Replaced The Exhaust Gaskets On My Chevy Tahoe. At Same Tiime A "board" (?) Was Replaced To Resolve A Blinker / Tail Light...
JB
2000 Chevrolet Camaro
2000 Camaro With 45,000 Miles. Have You Ever Seen A Reduced Power Light Coming On Once The Car Is Started And The Car Doesn't Seem To Want...
tbonerules
Code Scanner
Does Anyone Know Where I Could Find A Code Scanner For 1990 Mazda 626? Or Would I Be Better Off With An Obd Ii And Just Buy An Adapter To...
10foTuck
MAZDA 626
Keeps Blowing Mini Blade Fuse
2000 Malibu Blows Fuse For Lighter And Aux. Charger As Soon As You Install The Fuse What Could Be The Problem?
irish53
20192
20193
20194
