1987 Grand Marquis ( I Need Help Bad)
My 87 Grand Marquis Starts, Runs For A While Then Shuts Off And Hast To "cool Down" Before It Will Start Again. The Fuel Pump Is Not That...
Big C
Radiator Pressure
Why Is It That After My Tacoma Has Been On For Awhile I Can Remove The Radiator Cap And There Is No Pressure Coming From The Radiator.
cesarin75
Transmission Leak
I Have A 93 Honda Civic And My Transmission Is Leaking What Should I Do?
hiphop
Honda Civic 93
Hello Their I Have A 93 Honda Civic With 98,000 Miles On It And Should I Change My Tranmsion Oil? Some People Told Me That Is Bad If I...
hiphop
2002 Chevy Tahoe
I Have A 2002 Tahoe , I Drove Up To. San Diego From La Half Way There I Ran Out Of Gas I Pulled Over (freeway) I Put In 1(g)of Gas Car...
jolo1967
What Must I Do
I Own A 1987 Ford Range Pickup, I Recently Had A Fly Wheel And A New Clutch Put In, Since That Time When The Weather Is Cold The Truck...
angie_sparky_box
Installing A Timing Belt On A 92 Plymouth Voyager With...
What Are The Steps To Installing A Timing Belt On A 92 Plymouth Voyager With A 2.5?
badassbrandon
PLYMOUTH VOYAGER
Thick Smoke
My Car Is Is A Suzuki Swift, 93, 90000km. It Is Blowing Thick Smoke, Seemingly Only When Throttle Is Fully-open, But Not Necessarily At...
milescheifetz
SUZUKI OTHER
96 Lumina With 3.1
I Have A 96 Lumina With The 3.1 Engine. Recently I Had The Pvc Valve Replaced And The Radiator Flushed And Refilled. After Doing This I...
Bartman
Suv Shakes When I Apply The Brakes
I Have A 1991 Ford Explorer, When Im Driving On The Highway Around 60 To 70 Mph The Truck Shakes Lightly But When I Get Off The Highway On...
fordmstg65
Ford Taurus Preventitive Mantainence
I Have A 2000 Ford Taurus With 203,000 Miles On The 3.0l Vulkan Flex Fuel Ohv Engine. What Levels Of Pm Do You Believe In Or Recommend? I...
renegade343
Shut Off Switch
Where Is My Car Button To Press When You Have A Wreck And Your Car Won't Start
monisha jackson
Saturn
I Have A 1997 Saturn Sc2 With About 108,000 Miles On It. I Just Got It A Few Months Ago And I've Noticed That It Has A Lot Of Trouble...
petey
Vacume Shift Motor
How Do I Check The Vacume Shift Motor On A 2001 Dodge 1500 4wd? The Front Axles Are Not Disengaging When Shifted Into 2wd.
plumn69
DODGE OTHER
Coolant Spraying Out Reservoir & Temp Up &...
Okay, 1961 Chev Apache Pickup With 75,000 Miles. When I First Bought This Truck Its Aftermarket Temp Gauge Would Heat Up When First...
Nighttrain
Starting
My 91 Dodge Ramcharger 360 5.9 Liter Would Not Start This Morning. I Replaced The Starter But It Still Will Not Crank. The Battery Is Fully...
Cliff Jackson
Engine Dies While Slowing Down Or Idle
Dear Auto Expert, Make: Mercedes Benz Model: Ml320 Year: 2000 Mileage: 42000 Recently This Car's Engin Turns Off (or Die) While...
goodautoservicesite
MERCEDES BENZ OTHER
91 Ford Tempo Auto W/ 220kms
I Have A 91 Tempo Auto W/ 220 Kms The Idle Is Up And Down (erratic) And It Ocassionally Stalls. I've Done Plugs, Wires, Cap, Rotor, O2...
joe hyatt
FORD TEMPO
96 VW Jetta Oil Leak
I Have A Major Oil Leak In A 96 Vw Jetta Gl. It Is Comming From The Fixture That The Oil Filter Screws Into. Below Is A Link To A Picture Of...
linker33
2002 Dodge Grand Caravan SE 3.3L V6 55K Miles
We Are Trying To Change The Power Steering Fluid Pump On A 2002 Dodge Grand Caravan. We Are Trying To Loosen The Belt Tensioner To Get The...
tlabree
Mercury Mountaineer Brake Problems
I've Had This Issue For About A Year On My 2000 Mountaineer And The Dealership And 4 Other Mechanics Can't Figure Out What It Is. When I'm...
QUICKSILVER
MERCURY MOUNTAINEER
98 Dodge Grand Caravan
None Of The Lighter/power Outlets Work. I Have Visually Checked Each Fuse In The Main Fuse Block, But All Seem Ok. Is There Somewhere Else...
james_howard_2
Clanking Noise In 1995 Civic
Recently, Whenever I Make A Right Hand Turn Whether I Am Braking Or Not I Hear A Clanking Or Knocking Noise Emanating From The Back Of The...
TeddyCooper
1999tracer
Explosion Through The Throttle Body What Could Cause It
casperl
High Idle Problem
1994 Camaro, Automatic, 3.4 Engine, 130,000 Miles When Starting My Camaro It Idles At 2,000 Rpm And Slowly Raises To 2,500 Where It...
a79bigbertha
20161
20162
20163
